Results 1 to 2 of 2
    Established Member Two Rings 029kid's Avatar
    Nov 13 2006
    Audi A4 2017 Avant 2.0 TFSI
    Oslo, Norway
    Need hlp recoding VCDS
    I got the following fault in VCDS.
    01512 - Control Module for Sliding Roof
    005 - No or Incorrect Basic Setting / Adaptation - Intermittent
    What values and where do i enter the correct values?
    The convenience open/close is not working anymore either.
    Is that related?
    Senior Member Three Rings GilliamOS's Avatar
    May 26 2015
    '13 A6 3.0T Prestige | 2007 Ford Escape
    America's Buttcrack, Iowa
    The factory manual has two different methods.
    For sedans:
    Switch on the ignition and close the doors. If necessary, close the sunroof.
    Pull the sunroof control switch and hold it in that position for 10 seconds.
    The sunroof panel will lift, it will open all the way and then it will close.
    * Keep pulling the sunroof switch during the adaptation process.
    * This completes the adaptation process.
    For Avant:
    "Use Vehicle Diagnostic Tester to code or perform an adaptation via Guided Functions or in Guided Fault Finding in diagnosis address 46 after replacing the Power Sunroof Control Module -J245- or Roof Shade Control Module -J394-.", with no further information.
    2013 A6 3.0T - Slightly better than poverty package.
    2009 A4 2.0T Avant
    2000 A4 1.8T
    1999 Millenia S
    1997 A4 1.8T
    1990 Maxima
    1987 Maxima
    1986 Golf Diesel
