Results 1 to 3 of 3
    Jan 10 2017
    Yeovil UK
    OEM Diverter Valve Failure?
    Hi guys
    My car has the 1.8t engine with 51000 miles on the clock, the oem diverter valve on it must be the original as far as I'm aware.
    Anyway is it possible for it to fail without there being a issue with the diaphragm. Such as the spring becoming weaker over the 9 Years its been in use?
    Causing it to open the Valve under less pressure than when it was new?
    Ramjam
    Jan 10 2017
    Yeovil UK
    Active Member Two Rings LokiAudi89's Avatar
    Apr 22 2016
    NY/capital region
    I'd say no man, I'm pretty sure mine was stock and had over 100k I went and bought a forge Dv anyways
