Page 14 of 16 FirstFirst ... 41213141516 LastLast
Results 521 to 560 of 630
  1. #521
    May 01 2011
    east coast
    Hello everyone! New A6 3.0 driver here (previously B7 RS4).
    I have a couple of noob questions:
    1. If I want to warm up the car do I just leave the key in the car, get out of the car, and let it run? What if I take the key with me? Will it still run but just keep beeping inside?
    2. Any way to keep the MMI screen up but turned off? I know I can just fold it down but when it's time to park it takes a few seconds to come back up so would like to keep it up but turned off since I don't really use it besides when I'm parking.
    3. In the manual it says the parking brake will release automatically if the accelerator is pressed and the car moves forward. Does this work with going in reverse?
    4. Is it possible to install auto open/close trunk on a non-prestige A6? any aftermarket options?
    5. Looks like the heated seat setting on the driver's seat is memorized for the next time but not the passenger side. Any way to have the settings come back when the passenger returns to the vehicle?
    I think that's in for now.
    Established Member Three Rings G_Wagon's Avatar
    Jan 21 2017
    Cabbagetown, Atlanta, GA USA
    Does anyone know the significance of the green tire valve stem caps on certain Audis???
  3. #523
    Sep 28 2009
    suburb
    nitrogen in the tires instead of air.
    Audi S7
  4. #524
    Dec 30 2017
    Georgia
    What can be done to maximize the power in my A7? I know I can go EPL stage 2, but what else can be done. Would it at all be possible to get 500 Horsepower from a 2012 Prestige?
  5. #525
    Apr 19 2016
    mn
    Quote Originally Posted by jaehoppa View Post
    1. take the key, it'll keep running (until it runs out of gas afaik). you can push a button on the steering wheel to shut off the beeping (i use the arrows on the left side of the wheel...others may work too).
    2. no
    3. not sure, but there's a button next to the shifter to release the parking brake ;)
    4. holding down the trunk button on the remote opens the trunk. depending on the year you may have the "kick your foot under the bumper" thing on your car, but it doesn't seem to work very well from what I've read (mine doesn't have it). retrofit of motorized closing has been done, but it seems more spendy & time consuming than it was worth (to me). Or is that not what you mean?
    5. no
    -cody
    13 A6 3.0
  6. #526
    Dec 10 2017
    Quote Originally Posted by slocody View Post
    2. no
    5. no
    -cody
    thanks for all the replies!
  7. #527
    Dec 10 2017
    Is it possible to drive the C7 A6 (2016) with the parking brake engaged by mistake? or will the car automatically disengage it when the car moves forward?
    I swear today I parked the car and put the shifter in P and notices that the parking brake was already engaged (red light on). I didn't feel any resistance while driving just before that. Maybe it's a glitch? or is there a setting where the car automatically engages Parking brake automatically when shifter is moved to P?
  8. #528
    Active Member Three Rings
    Jan 02 2018
    El Paso, TX
    You can do any of what you mentioned via coding. In addition, you can set how easy you want the parking brake to release when getting on the gas pedal. It's on the parking brake module. There're 3 settings: easy, normal, and hard. Default is normal, and I left it like that. I tried to disable the requirement of having the seatbelt fastened, but couldn't do it on my 2018 (it's a different security code than 7.0 cars, and a VW master tech commented on VCDS it cannot be done anymore). Having said that, yesterday I disabled the 'seatbelt warning chimes', and now not even the seatbelt dash light comes on (I didn't want that), so maybe the parking brake now releases without the seatbelt anyway. Ha ha. I almost never use the parking brake myself (always try to park on flat ground, and no need for it), but will try to release it automatically without the seatbelt next time just for kicks. You can also make it engage automatically when selecting P on that same module. And if parking is engaged, no way in hell you'd be able to drive with it, so don't worry about that. If you don't have your seatbelt and it doesn't release automatically, you're not going to move, or barely, so don't worry driving with it engaged. It's not going to happen. If you have the seatbelt on, it'll always release automatically. Hope this helps. By the way, I'm going to go back to the module and see if I can just disable the audible warning, but leave the dash light in case I forget to buckle up. Right now it's like if the car didn't come with seatbelts at all. Ha ha. Oh, and I also saw a menu where you can adjust the clamping force of the parking brake; I think it was on the super long drop-down menu of module 5F, but don't remember exactly. No need for that unless it isn't enough for you. On my other cars, you can set it harder by just holding the parking button up again; the longer you hold it the harder it clamps. So far I've never had the need for that. Hope this helps.
    2018 S6 mythos black/black; S sport package, driver assistance package, 20" black optic package, carbon atlas, Audi rings, all-weather mats, 35/20% tint
  9. #529
    May 26 2016
    Chicago/IL
    Parking brake engages automatically if you have your car in drive (transmission in anything but P position) and open driver's door and disengages automatically if you have your seat-belt on, transmission in D/S or R and you start to drive.
  10. #530
    Jan 02 2018
    El Paso, TX
    Quote Originally Posted by AUDIofil View Post
    You'd be an idiot to get out of the car in D without the parking brake, so I don't consider that intrusive. On the contrary. But you can code the car to automatically apply the parking brake when tranny is put in P; that's what I meant, in case it wasn't clear. Most DCT cars don't have a parking pawl, so that's what happens every time tranny is put in 'P'. Our cars thankfully have a parking pawl, just like Porsches with a mechanical transmission lever. I don't know if the electronic shifters also have a parking feature or not, but Audis do, so maybe the Panamera with the electronic shifter does too. I really like a mechanical shifter, and a parking feature, so very happy to still have both here. As well as a DCT. I really don't like the new electronic shifters, videogame dashes, etc. It'll be a sad day if I'm not able to buy another new car like the S6, but it is what it is.
  11. #531
    May 26 2016
    Chicago/IL
    Quote Originally Posted by elptxjc View Post
    I agree that no driver should try to get out of the car before shifting transmission into P but I pointed out how it works. It's a safety measure and I like to see it's implemented. However you can for example be parking a car and open a door a little to check distance from a curb or parking line, etc. and then shift into P and wonder why parking brake is engaged.
  12. #532
    Veteran Member Four Rings p3u's Avatar
    Oct 02 2005
    Dallas
    Exactly. I've ran into the engaging under that circumstance many times. It's annoying, the threshold for going on should be over 5mph imho.
    C7 A6 3.0T, APR Stage 2+
    Dragy verified times:
    0-60mph 3.32s
    1/4 mile 11.46s @120.07mph
  13. #533
    Dec 10 2017
    I think that's exactly what happened with me.
    I was parking and wanted to check the distance to the curb so I opened the door a little to check and then put the car into P.
  14. #534
    Dec 10 2017
    I guess I would need a VAGCOM for this which I don't have.
    It would be nice to have the Parking brake engage automatically when the car is put into P because I use Parking brake all the time when parking.
  15. #535
    Dec 10 2017
    Another question,
    According to the manual, I should engage the parking brake before putting the car in P, instead of putting shifter into P and then engaging it.
    It's more natural for me to put the car in P and then engage the parking brake but I notice less movement after letting go of the brake pedal when I follow the manual and engage Parking brake before moving the shifter to P.
    I feel like more movement after the brake pedal is release = more strain on the car so I'm trying to engage the parking brake before shifting to P.
    Also, is it not a good idea to leave my foot on the brake pedal when I release the parking brake because it pushes up against it? Should I just not press the brake pedal when release the parking brake?
  16. #536
    Dec 10 2017
    so my A6 with black optics grill came with the front license plate bracket. If I remove it would the grill look weird with holes in it? Anyone have a photo of black optics grill with license plate frame removed?
  17. #537
    Veteran Member Four Rings Kevin1's Avatar
    Oct 19 2008
    Long Island
    I think it would look strange with the holes and no plate
    1 of 1 in the United States - 2015 A6 TDI Prestige with 19" Sports Package and Season Dedicated Tires - Oolong Gray Metalic, Nougat Brown Interior, Dark Brown Walnut Inlays, Black Headliner, Driver Assistance Package, Cold Weather Package, Night Vision Assistant with Pedestrian Detection. Summer - Michelin Pilot Super Sport. Winter - Yokohama Bluearth Winter V905. Eurocode Sway Bars and Links. XPEL Ultimate.
    RIP - 2005 A6 4.2 - (February 2005 - August 2014) (142,000 miles)
  18. #538
    Aug 11 2016
    CA
    Questions you thought were too dumb to ask
    Quote Originally Posted by audi_rs View Post
    What year? If facelift then yes it will need a filler plate. I put one on my A7 it was a pretty easy install. Helpful to have someone hold the plate while you install and remove parking sensors if you have them. If not even easier!
    This is my old 2016 A7 but I would expect the same.
  19. #539
    May 01 2011
    east coast
    thanks for the photo. yeah i guess that would look weird. i will just put the front plate on. thanks again.
  20. #540
    May 01 2011
    east coast
    I have a question about scheduled service.
    my next service (audi care) is at 25k miles.
    Do I have to go to a dealer within certain mileage in order for them to honor it? Can I go at like 28k miles for example?
  21. #541
    Jan 02 2018
    El Paso, TX
    I don't, but on my 2018 car there were just 4 ugly holes, not those huge ones a few posts above. Found the perfect plugs at PepBoys, but had to enlarge the holes for screws I had laying around (in case I ever have to reinstall the bracket), then cut the 'barbs' of the plugs with a knife until they went into the holes. But the plastic was a perfect match, and they resemble the parking sensors. Not ideal, but not bad enough to buy a new grille. He he. If you're interested, I may have the part number written somewhere. It's one of those little boxes with orange packaging inside. And yes, it sucks that freaking factory (or port) drills the freaking bumpers. Unbelievable. Stupid dealers shouldn't ask for that, since most customers don't want plates on such a beautiful car. But most importantly, the stupid plate bracket blocks cooling for the radiators, and THAT was what made me remove it. I was going to put a plate so I didn't have to mess with the holes, but no way I'd give up cooling ability in hot TX for a freaking plate. Ha ha. So found that solution.
  22. #542
    Established Member Four Rings OlyS6's Avatar
    Nov 22 2016
    Olympia, WA
    They'll honor it, although I wouldn't recommend waiting longer than the recommended intervals. (unless you're doing your own changes in-between dealership changes).
    2016 S6, mythos black, RS7 turbos, MRC inlets |AWE intake and touring exhaust| APR downpipes| AMS cooler| Eurocode sways, end-links, and AK | Audi CCB| HRE P103, 20x10 | RS6 grille| Neidfaktor CF mirrors, diffuser, and steering wheel| Blackvue dashcams| Escort Max CI 360 | RS6 LED headlights |Sound: Navtv Zen-v, Audiocontrol DM-810 DSP, JL HD900/5 driving JL10W3 sub and Focal KX3 up front. Rear; JL HD600/4 driving Focal KX2.
  23. #543
    Veteran Member Three Rings tenspeed's Avatar
    Dec 12 2011
    Honeoye NY
    You can go at any mileage. Make sure you get in at/before the two year mark for the brake fluid change. The previous owner failed to make it on time and I was denied the fluid change at my last Audi Care service because two years had not passed since the first change. Thanks Audi!
    2012 A7 3.0T Prestige, Ibis white/Nougat/Ash, 20" Sport, ACC, LED, HUD, Ferrada FR2 wheels, AWE Touring exhaust, Adam's Drag II rotors, BlackVue dash cams
    As I've grown older, I've learned that pleasing everyone is impossible,
    but pissing everyone off is a piece of cake
  24. #544
    Dec 10 2017
    Quote Originally Posted by tenspeed View Post
    My 25k miles service is due in 5k miles or June whichever comes first. I don't think brake fluid has been changed before by the original owner so I assume I can get it done at the 25k miles service?
  25. #545
    Veteran Member Three Rings VR2V8's Avatar
    Dec 20 2007
    Philly Area, PA
    2018 S6
    1) Driving to work this morning in dynamic mode (air suspension at factory low, but not VCDS lowered yet), coming around a curve and get a DIS warning. "Air suspension too low. Controlling ride height.".....not sure if that is word for word.
    -- It soon went away, so I assume everything is fine? It regained control so no ruptured bag or damaged sensor.
    -- I also assume this is to be expected since I was taking a curve at speed, compressing the air suspension more on one side? Is this something we just have to deal with when doing spirited driving?
    -- Does this store a soft code? I have yet to hook up my VCDS to this car and look at anything.
    -- What is the threshold for height deviation from factory calibration? I'm pretty sure the car wasn't too low, just that one or more corners were more than x% lower than the stored setting.
    2) Any better/cheaper working options for SIM card data plan for AudiConnect?
    -- Do I really need AudiConnect or a data connection? What would I be lacking? I let the free trial lapse on my B8.5 S4 and I don't really know what I lost.
    -- I really want to download the owner's manual to the MMI, but have no data. Other options are to import from SD card or USB. Where would I get the owners manual to put on SD or USB?
    '13 S4: P+, DSG, Ice Silver, Black/Black Alcantara, Nav, SD, B&O, Carbon
    Akebono Ceramics, AWE Boost Gauge, AWE/GIAC Stage 2 + DSG, AWE Touring Exhaust & Res DP's, BO Grille, CR-15, Deval CF Lip & Diffuser, Ecodes, Eurocode Alu Kreuz & Sways, Euro Visors, Folding Mirrors, H&R OE, Hoen Xenonmatch Fogs, Ocarbon Dash Trim, Retrofit Labs Signals, Roc-Euro Intake, TSW Bathurst 19x9.5 et39 & Michelin PSS, Underseat Bins, Warning Triangle
  26. #546
    Nov 18 2016
    Where the hell is the charcoal canister on a C7 S6?
    Other models its under the car near the spare tire area, but Im clueless on the S6.
  27. #547
    Active Member One Ring TechCom-Mike's Avatar
    Dec 18 2017
    Wilmington NC
    On the 2015 A6 navigation, is there a way to wipe out all Directory stored addresses in a single shot rather than picking through and plucking them out one by one?
  28. #548
    Established Member Two Rings Rlynch03's Avatar
    Oct 27 2017
    07 Acura MDX, 16 Dodge Durango Hemi
    Annapolis
  29. #549
    Oct 27 2017
    Annapolis
  30. #550
    Established Member Two Rings sickmade0331's Avatar
    Nov 11 2013
    Monroe Washington
    Quote Originally Posted by Rlynch03 View Post
    Your licence plate bracket is already remove!
    Last edited by sickmade0331; 02-14-2018 at 08:52 PM. Reason: I'm retarded forget my comment
  31. #551
    Nov 11 2013
    Monroe Washington
    Quote Originally Posted by sickmade0331 View Post
    Forget my comment I'm retarded!
  32. #552
    Dec 10 2017
    Quote Originally Posted by gta7 View Post
    My car is MY2016 with black optics so I guess it will look like yours in the photo after the bracket is removed.
    what's the filler plate? Is it the one Rlynch03 posted above?
  33. #553
    Oct 27 2017
    Annapolis
    I wonder that as well. I ordered new OEM Chrome Grill shown in the below picture that I had to pay extra for the Plate Delete (a ridiculously high amount extra).
  34. #554
    Jan 21 2017
    Anyone know when Audi started using these wheels?
    They are still using them on their 2018 cars...
  35. #555
    Active Member Two Rings MolonLabe300's Avatar
    Aug 16 2017
    Chattanooga
    If I install a Roc-Euro intake after I have had the APR S1 I will need to go back to my tuner and have them reflash the ECU again to show that the intake is installed?
    13 S6 APR ECU S1
    13 S6 APR S1, Milltek turbo back, roc-euro
  36. #556
    Jan 21 2017
    Quote Originally Posted by MolonLabe300 View Post
    13 S6 APR ECU S1
    No, thatís what the MAF sensor does, adjusts for different air flow
  37. #557
    Jan 21 2017
    Quote Originally Posted by G_Wagon View Post
    Yeah, crazy, thatís why I asked. I love them and I have them on my b8.5. I also love how they r still using them, makes my baby feel young
  38. #558
    Aug 16 2017
    Chattanooga
    Thanks. That is what I thought but got the question asked and wanted to make sure.
    13 S6 APR ECU S1
  39. #559
    Dec 10 2017
    When I get in my car and try to play music from Spotify thru bluetooth (automatically connects when I get in the car), the volume control says "Currently Unavailable" and I can't increase the volume.
    I would only go down or mute..it happens pretty much every time I get in the car and drive off and eventually I'm able to up the volume..
    Any idea why this is happening?
    Also, when listening to the radio is there a way to turn it off fully instead of muting or turning the volume knob all the way down? It seems like I can only mute it and not turn it off completely because I still see the radio station displayed in the center gauge.
    Thanks.
  40. #560
    Jan 02 2018
    El Paso, TX
    You should ALWAYS engage parking brake first, then release brake, to make sure car doesn't move, and THEN proceed to put tranny in P. On inclines, it usually takes a couple of inches of 'play' before car settles, and that could lock up the tranny if you set it in P before letting car settle. And that's exactly why you shouldn't put it in P first. And that goes for both manual and automatic cars. Parking brake always first, and when foot is off the brake and car not moving, then put it in gear, P, or whatever you want.
    Quote Originally Posted by VR2V8 View Post
    Man, that doesn't sound good. Has it happened again? I lowered my car via VCDS 15, but haven't pushed it at all in the twisties (plan to do that next week on a long trip). Hope that doesn't happen to me, especially now that it's lowered than factory (but still very acceptable, basically where it should be from the factory). Also curious if a soft code was lodged in there, or maybe just a temporary one, catching the air tank low in pressure or something. Hope that was the case, but please let us know the details. Thanks.
    I would only go down or mute..it happens pretty much every time I get in the car and drive off and eventually I'm able to up the volume.. Any idea why this is happening?
    Yep, I do, since exactly the same thing happened to me. I was charging my iPhone with the cable connected to one of the USB ports. For some reason, if you're not using 'Apple CarPlay', you can't use the USB port to charge it, because it messed up everything. I simply put a USB plug (make sure it's no more than 1A) on the 12V outlet next to the USB ports, and problem solved. By the way, always have Spotify at the highest volume when in BlueTooth mode, and also use the built-in equalizer in the settings menu (under Playback) to enhance the highs, and any other frequency you want. Hope this helps.
