Results 1 to 4 of 4
Thread: Rough start
    Established Member Two Rings bigwilly1267's Avatar
    Jun 10 2015
    Virgina
    Rough start
    I have an 2008 Audi S5. I had the engine replaced and now when I put gas in my car I have to push the gas pedal to the floor in order for the car to start. I also get an EPC light that comes and goes. Where do I start checking for issues.
    Established Member Two Rings sfouRS's Avatar
    Jan 27 2013
    Bikes!
    Lehigh Valley, PA
    You're running 91-95 octane?
    My car will do that from time to time if I get cheaper gas. I try to run Wawa, Shell or Sunoco premium.
    Also, check plugs. Worth running premium plugs and changing them often.
    Senior Member Two Rings vwladz's Avatar
    May 08 2016
    A5 S-line,A4 B8.5, Miata
    North Miami
    If its hard to start after fueling the issue is purge valve that directs fuel vapors from tank to intake manifold
    South FL VW/Audi works
    https://www.instagram.com/tsemkov/
    Jun 10 2015
    Virgina
    I changed the purge valve two weeks ago
