Results 1 to 12 of 12
Thread: 2.8 manual swap
    Oct 13 2016
    union nj
    2.8 manual swap
    Just a random thought if it is possible or not, I have a 2.8 30v v6 and I was wondering if I could do any type of manual swap or if an s4 trans would fit, I heard that the crank shafts don't match I'm wondering if theyes anything I can do
    Established Member Two Rings CoyneJ's Avatar
    Dec 29 2015
    99 A4 2.8 Quattro
    Illinois
    I'm pretty sure there is a swap for it and someone probably documented it and if you are going to do it I would suggest going through those threads and reading everything
    Oct 27 2010
    B8 A4, B5 A4 2.7t.
    Norwood, MA.
    Might as well 4.2 swap it while you're at it.
    Instagram- @Thisisastickup.
    -Stage 2 Unitronic 2010 A4, 6 speed manual, s4 interior/ exterior swap
    -2000 A4- 2.7t, 2.8 trans, S4 interior.
    -Gone- 2871r Elim B6 A4 AEB/METH/28PSI/USP BODY/ S4 interior.
    Established Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    00 A6 2.7T - 00 A4 2.8
    queens
    The cranks are identical from what I remember, might be wrong. You would need the entire swap kit or a parts car. Parts car would probably make more sense.
    Oct 13 2016
    union nj
    thanks guys, ive been looking for months and still cant find any diagrams or anything, B6Hate4 why do you say might as well do a 4.2? ive talked to a couple people who say the same
    Senior Member Four Rings Bordom's Avatar
    Dec 10 2013
    Pickering, Ontario, Canada
    The only difference in cranks is that the autos have a bushing to hold the torque converter. Remove that and you're good for manual
    Sent from my SM-G935W8 using Tapatalk
    S4's New Lease On Life
    2001.5 S4 6-spd
    Currently "Monster"
    IG: 24_et
    MODS: Revo Stg 1, 034 Billet Subframe Bushings, SSAC V2 Downpipes, Custom True Dual Exhaust, Forge 007 DVs,
    Oct 27 2010
    B8 A4, B5 A4 2.7t.
    Norwood, MA.
    Quote Originally Posted by cargovroom? View Post
    It's an easy enough swap, would make your car 100x more fun, it's cheap enough, and not THAT much more labor than you're already going to be doing.
    Veteran Member Four Rings down_n_dapper's Avatar
    Sep 13 2012
    Adelaide, AU
    I've done the exact swap you're looking for, its literally super easy. follow bikestai's guide or any 1.8 guide for that matter, just have to remove the bushing from the crank and you're good.
    Maintaining a 12 year old Audi is about as expensive as Charlie Sheen's coke habbit.
    98' Ming Blue B5 2.4L 30V AGA
    | Miro 111 8.5"+225/40/18 - 9.5"+235/40/18 | Depo Projector Retrofit |
    | Dynamat | JVC Headunit + 4" F +Jl 6" R + 10" Sub | ECS Snub | EFK | Oil Pressure Gauge | Beltline Wrap |
    | Rear Muffler Delete | 3" Tips|
    Oct 13 2016
    union nj
    would you happen to know a part number or anything that could point me in the right direction on that bushing? and what you think would be the best option to put on for the swap
    Veteran Member Three Rings DeltaAlpha9's Avatar
    Jan 03 2012
    '92 Acura Integra GS, '92 Acura Integra GS-R
    Edmonton Alberta, Canada
    You need to drive the bushing out of the auto crank to run a manual trans, not add it. And a 5 speed swap would probably be cheaper and easier to source due to the fact that there are more A4s running around than S4s.
    Senior Member Four Rings blitz2190's Avatar
    Jul 31 2014
    NH
    find something that is just smaller then the bushing like a wooden dowel, fill the bushing with grease and line up the dowel and tap it in with a hammer, it should push it out, also if you are doing a engine swap a 2.7 would be way better than 4.2, much more modding potential and fun with even a stage 1 on it. Look around an collect parts, the first time I did the swap with an 01e and 2.7 on my b6 I was able to source everything including the engine for about 1400 including timing belt kit.
    B6 2.7T Swap in Progress
    2.7T Swap Wiring Guide
