Page 8 of 9 FirstFirst ... 6789 LastLast
Results 281 to 320 of 330
  1. #281
    Veteran Member Four Rings Dutch_A6's Avatar
    Aug 19 2012
    Hyundai Tuscon
    Belleville, IL
    I know it's taken awhile, do you know which wire we're supposed to tap into to access the turn signal function? I saw the grounds and the white and red but not where the yellow is supposed to go. I should have my Bentley manual up and running tonight (whole other PITA).
    Sent from my Pixel XL using Tapatalk
    Black 2012 A7 Prestige
    Mod list has yet to begin
  2. #282
    Aug 19 2012
    Hyundai Tuscon
    Belleville, IL
    Good news, shop I brought the headlights to has them all wired up and plastic welded them back together and they're ready for pickup. Hopefully I'll be able to get them swapped out this weekend, I'm going to have to go through this thread with a fine toothed comb to see if there is anything I need to do with the connectors but I'm a step closer.
  3. #283
    Senior Member Three Rings 2010A6's Avatar
    Mar 10 2015
    Albany, NY
    I just set aside time this weekend to do this project finally. Can't find the boards -_-
  4. #284
    Aug 19 2012
    Hyundai Tuscon
    Belleville, IL
    Doh, only thing I was told by the shop was that a couple of the amber turn signal LEDs don't work but all the white LEDs do, at this point I just want it done so I'm not worrying about a couple of LEDs.
  5. #285
    Veteran Member Four Rings JPJ2007's Avatar
    Apr 15 2009
    Middle TN
    damn man thats messed up. I totally understand though, fuck it just get it installed and working.
    I'm extremely interested in this shop, Depending on how expensive it's tempting.
    My issue I'm still finding is any lights on ebay that are decent cost all have the tabs broken off. I know there are fixes but I'd rather not ghetto fix it.
    I also don't feel like spending $400 a headlight.
    If theres any good news on my end it's things are looking up and actually able to be setting money aside for this project now.
    This is the summer we all get this shit done. lol
    I've also given up on the MD2S 4.0 idea. I'm just going to swap the projectors for TRS EvoXr's and be happy. Direct swap for $150.
    2006 A6 3.2L Quattro S-Line (got my baby back)
  6. #286
    Aug 19 2012
    Hyundai Tuscon
    Belleville, IL
    I got swamped at work yesterday so I'm going to pick them up tonight, I'll post pics and let you know the cost of it all. They've been really good so far, even called me a couple times yesterday to discuss the process when they ran into snags. I think due to the plastic welding it's going to cost around $300 for the labor but I think at this point it's worth it to finish this up.
  7. #287
    May 20 2013
    yokohama/kanagawa/japan
    just to remind you that EVO requires x2 adapters for each. (AMP > D2S BALLAST ADAPTERS & D2S > AMP BALLAST ADAPTERS).
    also need to find a space for your igniter which I could not find.
    So, I decided not to do projector swap, instead i did clear lends.
    -tishi
  8. #288
    Jul 17 2011
    Sin City, USA
    Quote Originally Posted by JPJ2007 View Post
    Audi actually sells the tab repair kit. $60 IIRC so not ghetto fix; OEM baby!
    '09 C6.5 A6
  9. #289
    Aug 19 2012
    Hyundai Tuscon
    Belleville, IL
    So it cost a bit more than I thought but I couldn't be happier with the service and the quality of the work. Here they are all out back together, spoke with the shop owner who did the work and he said he tested everything thru the OEM connector and everything worked on the board including the turn signal function when the main turn signal was used.
    He plastic welded the light housing back together then used sealant on top of that to make sure it was water tight again. As you know using a hot knife to cut this open left a good gap so the fact that it's together and looks like nothing is out of place impressed me. Hopefully I'll be able to find the time this weekend to take the bumper off and put them in.
  10. #290
    Veteran Member Three Rings ichi d's Avatar
    May 10 2013
    T.O.
    wow how much did it cost and i cant wait to see pics.
    C6.5 / S-Line /APR Stage II
  11. #291
    Aug 19 2012
    Hyundai Tuscon
    Belleville, IL
    All the labor was in the plastic welding and checking all the wires since the pics from the LED board website didn't have directions only pictures so he had to check everything as he went. Total was $400 which I know is a bit costly and more than I thought it would be but then again I know it was correctly wired and sealed up. Would have been much easier if we could have easily baked these lights open but it it's what it is. As soon as I get them installed I'll post pics and video but it might not be till next weekend as this weekend is pretty busy, I'm hoping maybe to sneak away on Sunday for a couple hours to finish this.
  12. #292
    Apr 15 2009
    Middle TN
    It's so tempting at 400 to just send them off and have them returned done. Man that's tempting. It's really not that much considering everything he did, and being the first time as you mentioned.
    So... So... tempting.
  13. #293
    Aug 19 2012
    Hyundai Tuscon
    Belleville, IL
    I'm really happy I called around and found a shop willing to do it that was right around the corner of the house, literally 4 min drive down the street. Now he's downer it once it would probably be easier the next time he does it though you have to factor in shipping since I'm outside of st Louis.
  14. #294
    Aug 19 2012
    Hyundai Tuscon
    Belleville, IL
    Though the next step is figuring out what pin in the harness need to be moved and then finding someone who can do it.
  15. #295
    Senior Member Two Rings Cobra357's Avatar
    Sep 13 2011
    VW Jetta
    Brooklyn
    I already sold them and actually sold them for $420 for the pair, I've the facelift with AFS and I operate it through my MMI.
    ALL MOTOR 3.2...................
  16. #296
    Apr 15 2009
    Middle TN
    Earlier in the thread someone made it work. I'd have to go back and dig up who it was.
    Looking on ebay looks like the driver side afs light is $250 for a broken one so I may have to do that. I really didn't want to lose my afs.
    I'm not sure I can swap it over easily....
    these guys did some work but haven't posted in years.
    https://www.audiworld.com/forums/a6-...750403/page17/
    I'm about to order the other headlight and im going to see if I can find a shop that will plastic weld mine back together.
    Do you care to tell me what shop you used? See if they've be interested in just welding mine back together and sealing them up properly, I can do the other work. Wonder what the cost would be.
  17. #297
    Sep 13 2011
    VW Jetta
    Brooklyn
    I order AFS in mine and I love my set up and it works through my MMI, I cancelled my switch back please let me know the outcome.
  18. #298
    Aug 19 2012
    Hyundai Tuscon
    Belleville, IL
    JPJ, shops website is www.schaeferautomotive.com the guy that did the work for me is named Ben and I believe he's the owner. The exact cost for me was $425 for doing the wiring and sealing them back up.
  19. #299
    Apr 15 2009
    Middle TN
    thanks, I emailed him a few questions about quotes.
    I'd be interested in him just sealing them back up real good.
  20. #300
    Aug 19 2012
    Hyundai Tuscon
    Belleville, IL
    Hope they can help, I just need to figure out there pin config and I can finally finish this.
  21. #301
    Apr 15 2009
    Middle TN
    So looking at ordering the projectors and TRS offers lens etching that doesn't effect light performance....
    this would be pretty badass to have done....
  22. #302
    Aug 19 2012
    Hyundai Tuscon
    Belleville, IL
    That looks pretty cool
  23. #303
    Apr 15 2009
    Middle TN
    It's an extra $50 from trs when you order the evo-xr projectors. Something I'll pony up for when I do order them. Eventually.
    hey, wasn't the pin config detailed somewhere in this thread? Someone got the lights working through the mmi on here.
  24. #304
    Aug 19 2012
    Hyundai Tuscon
    Belleville, IL
    I think it's on page 5 or 6, haven't gone through it in detail yet, it's 103 all week and I don't have a garage so for the time being I'm not doing anywhere outsider in the heat.
  25. #305
    Apr 15 2009
    Middle TN
    I never got an email back from the guy that did your headlights. Oh well.
    I see some front lenses are being sold online. that might be the way to go instead of cutting the back of the headlight. Cut the lens out, use a dremel to get the whole channel clean and then just reglue the headlight lens back on.
    The plus to this is that since it will be new butyl glue, it can be baked back off if an issue needed to be fixed.
    Maaaaaaybe found my path.
    $85
    http://www.ebay.com/itm/Audi-A6-6-20...BYkz4e&vxp=mtr
    $45
    http://www.ebay.com/itm/Pair-Car-Hea...5ZiAZ9&vxp=mtr
    Edit: Just bought the front lenses. I'm going to try this route. Since as long as I cut everything out, I can re seal them and also rebake them open if I ever need to fix anything.
    The only issue will be cutting the lens off, and then cutting out all the material in the channel where the front lens sits.
    Not sure why I didnt think about this before. Probably my best option.
  26. #306
    Aug 19 2012
    Hyundai Tuscon
    Belleville, IL
    Sorry to hear they didn't respond, that sounds like a solution. I'm just trying to figure out exactly which pin needs to be moved to make it work, I know it's the DRL pin however I just need to make sure which 1 it is and then find time my mechanic friends can do it
  27. #307
    Apr 15 2009
    Middle TN
    I just bought the lenses off ebay. This project may be moving forward. I'm ordering projectors on the credit card. fuck it. lol
    Did you find the other guy who got his to work? He posted the wires and pins I thought in this thread like half way through?
    Just emailed TRS in Atlanta checking compatability with the EvoX-R 2.0 projectors bolt pattern matching the 2009 A6 as well as the 2006 A6. So we'll see soon.
    Match or not im ordering their EvoX-R 2.0 they just released with the Etching service as well.
    https://www.theretrofitsource.com/co...-evox-r-2.html
    etching is $50
    https://www.theretrofitsource.com/me...action_4_1.jpg
    They have hundreds of designs, a few audi ones. I think the basic rings with maybe the honeycomb on the edging
  28. #308
    Aug 19 2012
    Hyundai Tuscon
    Belleville, IL
    I pm'd him, didn't get a response and have been to busy/lazy to go through the thread, prob try to do that this week.
  29. #309
    Apr 15 2009
    Middle TN
    Same, I'll go through it when I have the time.
  30. #310
    Apr 15 2009
    Middle TN
    Good News, I finally scored the other headlight I needed. Just purchased it on ebay. $140 Shipped for a Driver Side AFS model. So, Now I have a complete set of AFS 09+ LED lights.
    The Clear Lenses are on the way, as is the headlight now. I said fuck it and bought a mesh grill for the car too. :P
    So next step is to cut the lens off and start grinding out the permaseal/plastic lens inside of it to clear the channel out for the new lenses after the retrofit is complete.
    It's finally happening gentlemen.
  31. #311
    Apr 15 2009
    Middle TN
    Lenses are in!
    Still waiting for the other headlight.
  32. #312
    Active Member Two Rings ///Maestro's Avatar
    Aug 29 2017
    Michigan
    Lenses are in!
    Sub'd to see results. I've done a few retrofits in the past (3series BMW and 370z) but these headlights sound like a pain.
    It's crazy how expensive the rs6 lights are, do they come with the clear lenses?
  33. #313
    Aug 19 2012
    Hyundai Tuscon
    Belleville, IL
    Quote Originally Posted by ///Maestro View Post
    Well since I wrecked the car and didn't have time to install these headlights if anyone is interested in doing this conversion to their C6 I will sell my headlights for a reasonable offer. They're all wired up and sealed and were tested by the shop to work, they don't come with bulbs as I was just going to swap them from the old set. PM me if interested.
  34. #314
    Apr 15 2009
    Middle TN
    You had the boards installed right?
    Are you not getting back into a C6? ( I would totally upgrade to a C7! )
    PMed just for curiosity
  35. #315
    Aug 19 2012
    Hyundai Tuscon
    Belleville, IL
    PM'd you back, any questions just ask.
  36. #316
    Apr 15 2009
    Middle TN
    Ok thanks. If I didn't have lights and boards I'd be jumping on it.
  37. #317
    Aug 19 2012
    Hyundai Tuscon
    Belleville, IL
    No problem
  38. #318
    Apr 15 2009
    Middle TN
    Got a quote to have the lenses removed. $400.
    Since I bought extra lenses he said it would be less, but couldn't tell me how much less.
    So, I'm still going the diy route.
    In the middle of fixing an oil and coolant leak on the car and I'll be working on this project again. We're now over 1 year in the making. Sorry boys and girls.... I dropped the ball on this but... I'm coming back.
  39. #319
    Apr 15 2009
    Middle TN
    Quote Originally Posted by tishi View Post
    -tishi
    Hey, Just wanted to update that the evo xr 2 acepts D1S, D2S, and D3S bulbs. That should have us covered, but I'll double check which bulbs we have to run.
  40. #320
    Apr 15 2009
    Middle TN
    I got tired of all of my talk....
    SUCCESS!!
    After talking to a shop about the cost, 400 just to remove the lenses I just can't afford that. Hell, for 400 I can afford to make some mistakes and buy another set of lights.
    So I got the dremel out and went to it.
    I wanted to leave a shelf for me to have lens to pull on. As you can see, I cut out the center of the lens and then cut to the edge. I then heated the area with a heat gun and pulled, bent it up/down until the part of the plastic inside the channel broke and seperated allowing me to pull it out.
    This is definitely a big first step!
    Now I just need to repeat the process of cutting sections and heating and pulling them out of the channel.
    I would say this is the biggest step/progress on my end since I started this aside from finally scoring some lights at a decent price.
    I'll work on this one more tonight, and the other side in the next couple days.
    Now it's time to scrap the money together for the projectors, and etching service on the clear lenses. I'll be modifing the projectors when they get here. Shield drop, Custom FGL and filing down the cut off step so it's not a large step.
    Photos.
    I had to go back and cut around the led drl shroud screws which screw into the lens...
    Video of the cut before separating.
    https://flic.kr/p/22YoPig
    I was originally worried about all the dust... thats why I cut them open via a heat tool the firs time but that was just a mess. This was much easier! Just blow the dust out anyway....
