Page 79 of 128 FirstFirst ... 2969777879808189 ... LastLast
Results 3,121 to 3,160 of 5119
  1. #3121
    Veteran Member Three Rings jachien's Avatar
    Nov 12 2012
    Cerritos CA
    Quote Originally Posted by ntsantos View Post
    I've ran against Will the last time we both posted slips in the 1/4 mile thread. He ran 11.3x and I ran 11.7x. The biggest drawback of the ZF is the 6400 rpm Rev limit and no launch control. I haven't seen anything less than a 1.7x 60ft. APR is supposed to be coming out with a ZF TCU tune. I hoping that will even things out more with you DSG guys. I'll just need to go on a 500lb diet.
    Oh wow. I think the weight difference might make a bigger improvement over the increased rev limit. But the tcu tune would be easier to do.
    2013 B8.5 S5 - Dual Pulley 189mm/57mm. EPL E85 Dual Pulley/DSG flash. Autotech HPFP. APR B8 Heat Exchanger. Injen Intake. Deleted Mufflers. 034 Street Motor Mounts. 034 Driveline Mount Inserts. KW HAS + H&R F:20mm/R:25mm wheel spacers. S6 Brake Conversion
  2. #3122
    Quote Originally Posted by jachien View Post
    I don't know how severe the sputtering issue is. There's only a handful of us even running full e85 that are vocal. And then even fewer having sputtering issues. So the pool of data is really small and I don't know if there's such person out there with e85 tune and a manual transmission. Tony or chris would obviously know better about that information. But seems everyone that has sputter is a b8.5 dsg to my knowledge.
    Ps: how well is the zf holding up? I loved the idea of the dsg when I bought the car. Was the reason I got it in the first place. Have you raced a dsg car with similar mods? Would be curious of outcome.
    This...
    Yes the pool is small I'm assuming. I run full. Dsg. No sputtering. If the alcohol gets anywhere above 85, I'll throw lean. Wonder if there are any B8.5's that are having zero issues?
  3. #3123
    May 20 2012
    Chicago, IL
    I think I am going to switch to 93 stage 1 from E85 stage 1 so I am not locked to gas stations for a road trip. What's the process to do this? Will I notice anything weird? What's the latest 93 stage 1?
    Thanks,
    Matthew
  4. #3124
    Established Member Three Rings 303 Spartan's Avatar
    Aug 16 2016
    2014 Audi S4 & 2016 Mazda CX5
    Parker, CO
    Quote Originally Posted by SDV325 View Post
    I will have the TCU flashed tonight. Haven't heard much about the adapt process for the TCU, could you elaborate a little?
    I'm curious about this "adapt process" for the TCU tune as well. I flashed the TCU tune along with the ECU tune exactly as Chris instructed and haven't had any issues. However, now I'm curious if I missed a step to eek out some even better performance.
    '14 Estoril Blue S4 / EPL Stage 2 ECU & TCU
    DSG | ADS | Sport Diff | B&O | Tech Pkg | VMR V710 19x8.5 et35
  5. #3125
    Senior Member Three Rings cjw's Avatar
    Aug 11 2015
    Alberta
    It's been posted several times in this thread.
    2013 Lava Grey S4 S-Tronic
    Injen, EPL DP (3.2 ratio) +TCU, Magnaflow Catback Back to Stock, PLM HX
  6. #3126
    Established Member Two Rings Stana071's Avatar
    Oct 27 2012
    2005 audi a4 3.0
    Windsor, on
    First time tuner,and all I can say is that EPL's stage 1,91 octane tune is amazing. Feels like a different car im driving.
    Flashed yesterday and already feel the difference!!
    Sent from my SM-G920W8 using Audizine mobile app
  7. #3127
    Nov 02 2016
    New England
    I can also confirm that:
    I'm having sporadic sputter on the newer update, even after reflash
    It doesn't show anything in the logs
    I have a DSG
    I just made the realization that it sounds like the DSG farting (So a fuel-cut like sound)
    DP 93 with anywhere between 0-3 gallons of E85 it does it
    Pulling some more logs, but it really seems like a DSG only issue that doesn't show anything in logs. No misfire, no knock, slight fuel rail pressure drop...and that's all.
    Anyone try another tune on the DSG to see if it goes away?
  8. #3128
    Veteran Member Three Rings SDV325's Avatar
    Jan 20 2014
    12' S4
    Calgary, AB
    Quote Originally Posted by 303 Spartan View Post
    For the most part just have a mixed driving style for 30-40 miles. Steady throttle, the odd step down and a few hard kick downs to really get it moving is what i did for the most part.
    Quote Originally Posted by Stana071 View Post
    The down low power is definitely noticeable now and the throttle response is much better. Its only been a few days since i have been flashed so looking forward to seeing what this thing can really do this weekend.
    2012 Audi S4 Prestige - Ibis White | Magma | DSG | Sport Diff | Carbon Inlays
    EPL STG 1 & TCU | Roc-Euro Intake | 034 TransInsert | RS4 Grille | ECS GEOMET Rotors | Stoptech Pads | CR-15 | Eurocode F/R sways | MOOG Endlinks | Alu Kreuz |
    2015 Toyota Rav4 - Family Wagon
    GC8 (sold): http://www.rs25.com/forums/f145/t136...d-my99-rs.html
  9. #3129
    Apr 19 2016
    PNW
    I've noticed this too. Driving in D drives like it is S mode now. I love it.
  10. #3130
    Senior Member Four Rings GRUMPY-S4's Avatar
    Nov 16 2015
    DFW
    Im on corn and so far so good. Havent had any sputtering issues.
  11. #3131
    Oct 27 2012
    2005 audi a4 3.0
    Windsor, on
    Il be even more thrilled if i notice more power in a few days. Unfortunately i dont have any way to measure any of this..its all in the "feel"
    So far no issues,my guess is since i have only the ECU tune due to the 6MT
  12. #3132
    Nov 12 2012
    Cerritos CA
    EPL B8/B8.5 Owners Discussion Thread
    Quote Originally Posted by GRUMPY-S4 View Post
    I think your corn is better than mine.
    Did a pull on a very long freeway on ramp yesterday. Got intermittent sputter in the high rpm range and then cel. Po171 or something like that. Cyl bank lean.
    Would a failing cat cause that? Out of curiosity I was monitoring my o2 secondaries on torque app and either they're out of phase or one of my cats just went bad.
  13. #3133
    Oct 14 2012
    Empty...for now...
    Malvern, PA
    I posted this originally in the "Questions you thought you were too stupid to ask..." thread but thought it might be relevant here, too.
    Disclaimer - My intent is not to call into question anything about the EPL tune, but since my car has the EPL Stage 1 tune I am looking for input from other owners.
    Past few months I've been noticing what I perceive to be delayed throttle activity, where there is some 'dead' travel in the accelerator pedal before the engine speed increases. I have noticed this is Comfort, Auto and Dynamic modes and the car is 6MT with the following engine/drivetrain modifications: EPL Stage 1 tune, ECS Luft-Technik intake, AWE Touring exhaust system, USP stainless steel clutch line (delay valve delete). I cannot prove it scientifically, but the butt dyno indicates that throttle response used to occur without any dead movement of the pedal, especially in Dynamic mode. The result is jerky starts from rest in 1st gear, and poorly timed shifts while driving. I swear the car feels relatively sluggish, too, but of course I cannot prove that.
    Anyone have any ideas what could be causing it and/or suggest the most logical order of un-modifying the car to see which (if any) of the above mods are contributing to the issue? My current train of thought is to flash back to stock and see if that makes a difference. If not, then swap the stock airbox back in.
    2015 Daytona Gray S4
    Mods: S5 Peelers, Xpel Ultimate, 3M Color Stable Tint 35%, H&R Street Performance Coilovers, Euro Code Alu Kreuz, Eurocode Sway Bars+Endlinks, CR-15, Eurocode Meisterwerk ASTS, AWE Resonated Touring Exhaust, ECS Luft-Technik Intake, 034 Transmission Mount, HCX LED 3000k Fog Lights, E-codes, Apikol Rear Diff Mount
  14. #3134
    Stage 2 Banner Advertiser Four Rings Chris@EPL's Avatar
    Jun 23 2011
    Might be as simple as a Throttle Body Alignment and hopefully not a cleaning. If you flash the tuned file again after the flash is complete and the OK button pops up turn the car off and count to 10 or 20 before starting the car and it allows the car to do a full TB alignment. And new set of Spark plugs gapped to .026" would not hurt either. These cars are going through plugs sooner than the Audi OEM recommended changes as well.
    European Performance Labs
    http://www.facebook.com/EPLabs
    https://www.instagram.com/eplabs/
    (203-345-6499)
    Chris@eplabs.net
    Please feel free to contact us with any questions!!
  15. #3135
    Oct 14 2012
    Empty...for now...
    Malvern, PA
    Quote Originally Posted by Chris@EPL View Post
    Thanks for your quick feedback. I will follow your recommendation on re-flashing and letting the TB align, and will report back.
    I should have added that the car has 34500 miles so that is approaching the Audi recommended replacement interval. I think that's a DIY job that I could handle. Do you have any recommendations for brand/type of spark plugs for optimal performance with your tune?
  16. #3136
    Veteran Member Four Rings LittleDozer's Avatar
    Jan 21 2014
    C5 RS6, B8 A4 Avant, 2010 Yukon Denali
    Minneapolis, Minnesota
    Quote Originally Posted by xxdunnxx View Post
    I have a DSG
    It's not the DSG. If your car ran fine on the last file, Chris/Tony can make it available to you again.
    2004 Misano RS6 In Progress - Porsche GT3 Bosche Injectors / 3" Catless Downpipes / AMD Intercoolers / AMD E85 Tune / AMD 'Tip Chip' / KW V1 / Hotchkis F&R Sway / Moog End Links / Wagner Fog Delete / Flat Bottom Steering Wheel / Gunmetal TSW Bathurst 19x8.5 with 255 Indy 500s / 30% Tint 50% Windshield / Dension BT Module
    01E swap purchased, collecting the remainder of bits needed
    Gone and missed: Black Pearl C6 A6 4.2FSI, Full bolt-on Monsoon B8.5 S4
  17. #3137
    Veteran Member Four Rings p3u's Avatar
    Oct 02 2005
    Dallas
    I seem to be the only one that can run full e85 with zero issues. I get a lean code once in a while, but I just clear it and all is good. I'm also the only one with a ZF transmission, so I'm guessing this Sputter is a DSG thing. Unless my 3.0T is special.
    Sent from my SAMSUNG-SM-N915A using Tapatalk
    I'm finally running e85 DP without issues. It took a few months, but it's working.
    C7 A6 3.0T, APR Stage 2+, 189mm Fluidampr, Ported Supercharger, Autotech HPFP, Merc Quad Pass HX, RS7 airbox, 034 Motorsports hose, SQ5 21" Forged Wheels, 380mm SQ5 front brakes, 356mm S6 rear brakes, E-codes, RS6 Grill, RS6 Pedals, H&R Springs, center muffler delete, Magnaflow 120mm tips.
    0-60mph 3.32s
    1/4 mile 11.46s @120.07mph (via dragy)
    Past B6 S4 Avant, C5 RS6 Stage 2+, B5 S4 Stage 3+, B6 S4, MKIV R32
  18. #3138
    Jun 23 2011
    Quote Originally Posted by SteveYem View Post
    Just stick with the stock NGK plugs gapped to .026"
    (203-345-6499)
    Chris@eplabs.net
  19. #3139
    Nov 02 2016
    New England
    Quote Originally Posted by LittleDozer View Post
    It's the same tune that I've had from the start. I reflashed it, gave it more time between pressing OK then starting it, and it seemed to not sputter. I think that was a coincidence, as some days are worse than others.
    I haven't had a chance to pull good logs yet but the crappy logs show all the usual.
    It just sounds like the ECU intervening since it's perfectly rythmic and not necessarily in line with revs. I'll get a video at some point unless it goes away again.
  20. #3140
    Jun 21 2015
    Eagan, Minnesota
    Quote Originally Posted by Bdangs11 View Post
    Any update on 8K5927156D TCU update?
    Any update?
    Current:
    2015 Dakota S4 DSG P+
    2015 Triumph Street Triple RX
    2011 TTS, 2012 Subaru STi, 2007 Subaru WRX, 2003 SVT Ford Focus
    2012 Ducati Streetfighter 848, 2009 Triumph Street Triple R
  21. #3141
    Apr 19 2017
    Houston
    Just installed my pulley and flashed the stage 2 tune on Sunday.
    Logged about 80 miles since and I've noticed my idle is slightly rougher than it was with the stage 1.
    Anyone else noticed this after moving to stage 2?
    Sent from my Pixel using Audizine mobile app
    My car.
    Stuff I've bolted to my car
    -Random Quote-
  22. #3142
    Established Member Three Rings scmtkings4's Avatar
    Oct 06 2016
    Brooklyn, NY
    I moved onto dual pulley straight from stage 1 and didnt really notice a rough idle
    Sent from my BBB100-1 using Audizine mobile app
    2014 S5
    AWE Touring Exhaust l ECS Intake l EPL Dual Pulley 93 l AMS Alpha Cooler
  23. #3143
    Oct 14 2012
    Empty...for now...
    Malvern, PA
    Do you see any problems using these NGK 94460KT plugs?
    https://www.ecstuning.com/b-ngk-part...f-six/94460kt/
  24. #3144
    Jun 23 2011
    Those plugs would be perfect and gap them to .026"
    (203-345-6499)
    Chris@eplabs.net
  25. #3145
    Jan 21 2014
    You'll get more sputter on days that the air is cooler/denser, that's why you notice it sometimes and other times don't. Logs won't show anything, needs direct memory access to see it. Has to do with when the injectors open (not how long they open).
  26. #3146
    Nov 12 2012
    Cerritos CA
    Do we know the injector duty cycle? For the guys that are e85 dual pulley, how close are we to the limit of what the injectors can handle?
  27. #3147
    Nov 02 2016
    New England
    So you're saying that this is normal due to the dense air or is it problematic?
    I'm pulling my plugs this Sunday to check the gaps. Would the denser air cause spark blow-out?
  28. #3148
    Jan 21 2014
    Not normal, shouldn't happen. Literally nothing you can do to fix it unless you've logged and shown it to be a misfire.
    If it's the sputter the rest of us get, Tony will need to tweak the tune for you.
  29. #3149
    Aug 05 2011
    LI, NY
    Just added 3gal of E85 with my normal 1/4 tank fill up. Damn feeeeeel the difference, I'm liking this. So much more responsive and smoother. Just have to add the Ethanol Content Analyzer to my P# gauge and I'll be good to go.
    2013 Audi S5 Estoril Blue w/ Panda Interior | ELP Stage 2 Dual Pulley | 183 Fluidampr/CTS Pulley | PLM HE | AWE Touring w/ Resonated Downpipes | ECS Luft-Technik Intake | H&R Coilovers | CR-15 | 03 Motorsports Mounts | Eurocode AluKruez | Eurocode USS Sway Bar | P3 Vent Gauge | oCarbon CF Dash | CF Inlays | RS5 Grill | RS5 MMI | RS5 Door Handles | Power Folding Mirrors | ECODES TBI
    Weekend Warriors - '97 Mitsubishi 3000GT VR4 / '96 Mitsubishi 3000GT VR4 Spyder
  30. #3150
    Nov 02 2016
    New England
    I'll do my best but no matter how many times I've logged and made it sputt- no misfires.
    It's only when going into accel in only a section of the rev range. It just so happens to be the prime fun rev range.
  31. #3151
    Aug 16 2016
    Parker, CO
    Quote Originally Posted by oohnoo View Post
    Yeah, I've been pleasantly surprised with the difference 3gal E85 makes with the EPL tune as well. Especially with the 90+ degree heat we've been dealing with here. Chris told me I could use the 93 tune with a 3gal E85 mix (only have 91 octane here in CO). However, I opted to stick with the 91 tune and give the car a little more headroom with the extra octane, rather than trying to eek out a little more power.
  32. #3152
    Oct 06 2016
    Brooklyn, NY
    Where did you get e85 in the area?
    2014 S5
  33. #3153
    Veteran Member Three Rings tgsweat's Avatar
    Nov 05 2011
    maryland
    I have this exact issue with my GIAC DP tune. Around 4k if i get on it, it sputters a second or two before it starts to pull. Like above, it happens more when its cooler out. So annoying because thats the range i usually downshift to to accelerate. I've logged a million times and everything looks fine. I just had one of my cats replaced, so audi did the file update to address the cat issue which gave me a new stock file and GIAC seems to think their DP for the box code will fix my issue. We shall see.
  34. #3154
    Aug 05 2011
    LI, NY
    They're everywhere out here in LI. I have 3 stations within 2 miles of me.
    https://getethanol.com/ethanol-finde...bsite_20160915
    Also many phone apps available
    Quote Originally Posted by scmtkings4 View Post
  35. #3155
    Jan 21 2014
    Quote Originally Posted by tgsweat View Post
    Haha yep 4k in 3rd or 4th gear is the prime spot for sputter. Keep us posted.
  36. #3156
    Nov 02 2016
    New England
    So it's not just EPL? I wonder if APR does too...
    Dozer, did you get yours to go away completely with whatever adjustment Tony made?
  37. #3157
    Jan 21 2014
    The 93 update worked for me. The E85 update helped but it still sucks enough where I'm not using it.
  38. #3158
    Senior Member Three Rings maty360414's Avatar
    Oct 13 2015
    Orlando, FL
    Has anyone tried bringing the car in for service and gotten td1 flagged based on # of flashes stored in memory?
    '13 S4 - Phantom Black | DSG | H&R SSP | Vertini RF 1.3 | Sport Differential | Akebono Pads | ECS Trans Mount | ECS F/R Diff Mount
    ECS Drilled & Slotted Rotors | EPL DP | EPL TCU | JHM 187 Pulley | MercRacing HX/Divorced | 2 NonRes X-Pipe | Spoiler+Diffuser | Black Sidemarkers | LED's
    Michelin PS4S | Roc Euro Intake | RS Grill | 35% Window/TailLight Tint | Shadow Lights | Quattro License Frame | 5K Fog Lights | Vagcom Mods | 93/E85 11.5@117 MPH
  39. #3159
    Established Member Two Rings 00passat's Avatar
    Jul 31 2012
    2005 gmc sierra 2500hd 6.6 dirtymax
    Lancaster,ca
    Quote Originally Posted by maty360414 View Post
    Took mine in with 4 flashes on the counter and no issues, they did scan it for codes aswell.
    2014 S4 Dsg B&O , Sports Diff , Audi Side Assist, Carbon fiber Trim, 19' Peelers, Valentine One Hardwired ,Ecs tuning silicone inlet,Supercharger badges
  40. #3160
    Nov 10 2014
    Nope
