Results 1 to 21 of 21
    Senior Member Four Rings b7_Andy's Avatar
    Jul 18 2015
    B7 Center Console Latch Replacement
    *EDIT*
    Here are links that will fix the pictures that have been taken down by photobucket:
    Chrome:
    https://chrome.google.com/webstore/d...fegnfnflicjjgj
    Firefox:
    http://redirect.viglink.com/?format=...mbedded-fix%2F
    I've seen a lot of guys on here replacing their entire lids because the latch on the center console breaks, so I'm creating this DIY as a $5 alternative that also allows you to keep your nice high quality leather too. So all you'll need materials wise is the latch (which you can find on eBay for ~$5):
    I got mine off eBay and I think it was a B6 or A6 latch, it still worked so I'm pretty sure any Audi with a flip up center console can all use the same latch. Also if you lost the metal clip you'll want to make sure you buy one with the latch:
    So lets get started!
    Step 1:
    Start by removing the lid from the center console. Push in one arm and wiggle it a little until the other arm comes out. The plastic can definitely flex enough to push one of the arms out of its slot. If you pushed in both at the same time, that might be too much...
    Step 2:
    Once you have the lid off you'll need to pop off the bottom plastic. You can use a flathead screw driver, but make sure its pretty wide as it needs some strength. I would recommend a rubber trim removal tool or anything of that sort. You'll start by slipping your tool between the plastic bottom and the leather on the side where the arms are. Stick the tool in there and pry the plastic up.
    It's going to take A LOT of force. The plastic surfaces have some sort of plastic sealant on them so it's going to sound like you're breaking or cracking the plastic... Trust me, you're not! If it makes you feel safe you can hit it with a heat gun on low to loosen up the bonds. It is plastic so not too much heat! As seen in the pictures below there are 8 mounting points so you have an idea of how and where it's going to separate. Once you've started to pop it up from the side with the arms, evenly work your way to the side with the latch. You can also see in the pictures the little bit of plastic sealant.
    WARNING! I'm pretty sure ONLY THE B7s have this lid design. So if you're doing this on an Audi that is not a B7, or has a center console different than the one seen in the pictures, I encourage you to research your specific body style as I am not responsible when your plastic lid breaks from separating it improperly.
    Step 3:
    If your metal clip stayed on (which it likely didn't), unhook it from from its mount and remove it. Also remove the remains of your plastic latch.
    Step 4:
    Install your new latch. Make sure the smooth part of the latch is on the same side as the smooth part of the plastic lid. You'll need to bend the latch a little to fit the mounting points in, but be careful... This is where the latch likes to break.
    Step 5:
    Now you'll need to install the metal clip, this is probably the hardest part of the replacement. Start by placing the ends of it where they mount on the latch.
    Then you'll need to stretch the clip to get it to hook onto the mounting point on the smooth side of the plastic lid. Some kind of hook tool is really helpful and just be patient. I used two hook tools and started with one on the side shown in the first picture to push the clip to the side of the plastic lid it needs to be on, and the second tool on the smooth side of the plastic lid to grab the clip and pull it back and over the mounting point seen in the second picture.
    Step 6:
    Now that the latch and clip are installed the rest is pretty easy. Reconnect the plastic part of the lid with the leather part of the lid. You don't need to put any kind of sealant on it. It will snap together and hold just fine, mine is still solid 6 months later.
    Step 7:
    Now reinstall your lid to the center console. I angled the lid a little to align the mounting points in the slots on one side and then pushed the other arm until it slid into the slots. Take your time and try not to bend both arms at the same time. Make sure the lid can move up and down with no resistance.
    And now you're done and are able to enjoy closing your center console lid for when you need to throw it up for easy access to the hand-brake during an urban drift sesh!
    Let me know if any part seems confusing or if I left something out...
    Feb 08 2012
    Dallas, GA
    Great write-up. I only wish I hadn't thrown out my original lid now. Oh well, the replacement I got is pretty decent--not perfect, but decent.
    Established Member Two Rings coulditb7's Avatar
    Nov 15 2014
    Wisconsin
    Link to the latch on eBay?
    Nov 15 2011
    A4 B6 Avant | A4 B7 Sedan
    Montreal | I sell in USD
    Items for Sale
    Nice DIY but the leather lid only came on S4's & RS4's (Maybe 3.2's) the rest of us have Vinyl lids.
    *****I sell in USD*****
    B6 Avant GTX2863R Motoza Tuned Aka the part hauler
    B7 Sedan Stage II HPFP Aka the retrofitted queen
    Jul 18 2015
    Quote Originally Posted by coulditb7 View Post
    There's a bunch on eBay and I didn't link any because the links always disappear, but here's a couple just for you
    http://www.ebay.com/itm/For-AUDI-A4-...xWN8GT&vxp=mtr
    And an aluminum one that will never break!
    http://www.ebay.com/itm/ALUMINIUM-Ar...lWgrWj&vxp=mtr
    Quote Originally Posted by Axis View Post
    Looking at a few pictures I noticed that some have leather and some are vinyl. Although I think the only difference is the material it's wrapped in, the lid still seems like it has the same base plastic.
    Veteran Member Three Rings Obsidian's Avatar
    Jun 16 2012
    '06 A4 2.0t
    Valley of the Sun
    This is also a great place to get a replacement latch from. Choose your color and everything on the cheap.
    Clicky!
    2006 Audi A4 2.0T / 6MT / Brilliant Black
    APR stg II / 034 Motorsport / aFe / Avus
    Jul 18 2015
    Quote Originally Posted by Obsidian View Post
    Clicky!
    I saw those too, they look pretty high quality
    Nov 01 2008
    I had mine 3D printed
    Apr 17 2012
    08 B7 A4 FSI, 09 MK5 2.5
    Bloomsburg, Pa
    Items for Sale
    Can choose your color here...
    http://www.banggood.com/Armrest-Lid-...n=auto-US&ebay
    2.99 plus shipping. I need a beige one so...
    Veteran Member Four Rings BenMTL's Avatar
    Dec 19 2012
    Europe
    Items for Sale
    Thanks for this disassembly guide at least OP.....But these $2-3 ebay latches just look too cheap and will probably break sooner than OEM. Too bad Audi doesn't have a unique part number for just the plastic latch and metal clip...
    I disassembled by OEM armrest to barebones, super glued and fixed all the broken plastic pieces, aligning everything back together, and now have a functioning armrest latch. Will be installing it back in the car tomorrow. Hope the super glue with hold it longer than these cheap chinese latches but if it doesn't, then I'll just opt out for these $20-30 complete replacement armrest covers.
    Note to other people looking to do this however....Don't bother taking it all apart if you don't have some kind of hook tool to put the metal retaining clip on again at the end....What a pain in the ass that step is, even with multiple small hooks on hand...
    Race: 2006 A4 2.0 T / Quattro + 6 Speed / JHM Stage 2 93 w/HPFP / Custom 3" Turbo back exhaust / AWE Boost Gauge / JHM Short Shifter + Intercooler / White CF Trim / S4 Door Blades / DTM Conversion / RS4 RSB / HFC
    Daily: 2012 Audi A7 3.0 TDI / Twin Turbo / True Sline / Quattro + 8 Speed ZF / HUD + ACC + Sunroof / APR Stage 1 / Eurocode Alu Kreuz + Mounts / 034 RSB
    Veteran Member Four Rings drewgold's Avatar
    Sep 21 2004
    1981 Kawasaki KZ440 and too many bikes and skis!
    Rocky Mountains, Canada
    Finally replaced my broken armrest latch. It has been broken since I got the car, finally gone are the days of people flipping it up and dumping the entire contents into my back seat!
    Huge thanks to @b7_Andy for this DIY, if it isn't already in the DIY section, this NEEDS to be!
    I ordered an aluminum latch off eBay, hopefully I'll never have to replace it again!
    Fitment was very good, it maybe sticks out a fraction more, or it possibly just seems that way due to the fact that it's aluminum and not black. I actually like the contrast and the fact that it matches the button on the ebrake handle.
    I did shave down a bit off of the edges on the arms of the latch as there were some raised edges from manufacturing, it fit fine, just wanted the latch to move as freely as possible. The latch also came with the spring! Sometimes the simple things are the most satisfying.
    2006 A4 Avant, 2.0TQM - JHM Stg 1 Tune - Unitronic HFC/3" Downpipe - 034 Street Motor/Trans Mounts - APR Snub Mount - S4 RSB - 034 Turbo Inlet Hose - JHM Short Shifter - Brembo Q5 Front Brakes w/ceramic pads - S4 Rear Brakes - Stock Sport Suspension - Black Alcantara Recaro Interior - Summer: 19" OEM S5 wheels, 19x8.5 ET32 w/ Conti DW tires - Winter: OEM 18" USP wheels, 18x8 ET43 w/ Nokian Hakkapeliitta studded tires - Dolphin Grey FTW!
    Dec 19 2012
    Europe
    Items for Sale
    How much did you pay for the alu latch drew? Seems your ebay listing is already gone...
    Sep 21 2004
    Quote Originally Posted by BenMTL View Post
    Paid $30 US with free shipping. I'd message the seller and see if he has more.
    Senior Member Four Rings JDillon15's Avatar
    Jul 11 2014
    Chicago, IL
    Items for Sale
    Clicky!
    I had one 3d printed from here and never ended up using it. I'd be willing to sell it if anyone wanted. Just Pm me.
    It's black
    sent from my phone
    Moro 06 A4 Quattro| Totaled
    Silver 06 A4 Quattro | Sold
    Legal Advisory for Mec's Cabinet Dec 2014-Present
    *Advised the shit out of legal situations
    *Succeeded like never before and rose to the top like a phoenix from ashes
    *Can Take a ZJ with a poker face
    Established Member Two Rings 1.8t's Avatar
    Jul 25 2008
    Toronto, Canada
    Quote Originally Posted by drewgold View Post
    Thanks for this! Just ordered :)
    Sprint Blue/Black B7 S4 Avant 6MT - KWV3, Catless Downpipes, Miltek Resonated Catback, Revo Tune, Hotchkis F & R Sway Bars, Flat Bottom Steering Wheel, RS4 Pedals, Ocarbon Trim, Ecs Snub mount, Michelin Ps2, OEM S5 Rotor Wheels, 6 Piston Brembo Calipers.
    Senior Member Four Rings Okedokey's Avatar
    Oct 24 2015
    Perth, WA
    Gotta ask, wtf are you guys doing with this that it breaks?
    My respray thread
    May 20 2014
    e92
    Just an FIY:
    I have done this repair with a cheap $2 arm rest lid latch off ebay.
    If you have lost the stock spring, you can use a paper clip instead of the stock spring. I never got that piece of spring when I bought my car, so I unbent a large paper clip into the shape of the spring. Its not as sturdy as the stock spring, but does the job of holding the armrest lid on the latch.
    Has been holding up for more than 6 months just fine. But my armrest leather has started disintegrating so, I ordered a cheap replica, on its way. Lets see if it fits.
    Nov 15 2011
    Items for Sale
    @drewgold creating needs, I ordered the plastic version last week but after seing your pictures I ordered the aluminium one.
    Dec 19 2012
    Europe
    Items for Sale
    Quote Originally Posted by Okedokey View Post
    Opening and closing our armrest lids...That is it. Hinges are made out of cheap plastic that deteriorates in strength over years and becomes brittle....
    Veteran Member Four Rings i3oricua's Avatar
    Sep 17 2006
    2006 A4; 2007 Audi Q7 3.0 TDI
    Brandon, Suffolk, England
    Thanks for this Andy. Just used it today. Probably the fastest easiest fix I've done to my car.
    This needs to be a sticky. It took me a while to find it because I knew it existed.
    Jul 18 2015
    @i3oricua Glad it helped
