Page 14 of 14 FirstFirst ... 4121314
Results 521 to 547 of 547
  1. #521
    Jul 04 2012
    Woodbridge, VA
    Quote Originally Posted by christianb5s4 View Post
    Of course, always happy to help where I can! Drivetrain should be getting pulled either last night or today, thankfully the turbos seem to be unscathed from any debris that might have come off from the engine blowing.
    All that work and throwing the k04 snails back in? Yooooou crraazy
    Just kidding man. Gives you something to upgrade later if need be.
  2. #522
    Senior Member Four Rings christianb5s4's Avatar
    Aug 24 2014
    Newport Beach, CA
    They are actually full RS6 CHRAs and custom Compturbo billet RS6 wheels in a machined out K04 housing (cold and hot). I'll try to dig it up exact specs but these turbos have exceeded everyone's expectations, there was a ton of headroom left on the tune (deliberately conservative to safeguard the stock motor). Based on where we were at on the most recent tune revision, my tuner is confident with timing and boost turned up now that the motor isn't a limitation we can hit 525whp on E85 along with RS4 cams and same supporting mods as before.
    Bottom line is that these turbos are in a different league based on what we've seen to date than PJK04s or the K04 hybrids that are out there currently. They spool great (a touch later than K04s), don't drop off at the top end, make great power, and are overall amazing for my driving needs. That's my hands on experience to this point, I will be getting some hard data and vbox runs when the car is broken in and running to get some empirical data.
    Imola 2001 Stage 3 S4: 305K - K04/RS6 Hybrids - Clutchmasters Stage 4 - Etspec - Cinesnow WG Lines - AWE Intercoolers - AA built trans - JHM Trio - DriveshaftShop - Stern Mounts - H&R Coilovers - FCP - Brembo - OZ Racing - SRM/SSAC exhaust - 034 Motorsports DVs - Tons of New OEM parts
  3. #523
    Feb 19 2011
    Earth
    I like this!
    100-200 (kph) would be nice to know, if you have the real estate to make it happen easily.
    2000 Achat S4
  4. #524
    Aug 24 2014
    Newport Beach, CA
    I talked to Tweets over PM here and there about borrowing their Vbox but it probably won't be available until middle of this year from what he said.
    In other news, got some updates from Marc. Engine is progressing nicely and will be going back into the car this week with the goal of having a first start this weekend. Also picking up an APR bipipe and ordered a few miscellaneous things like new front axle bolts since I have two new OEM units going in.
  5. #525
    Jan 09 2009
    Depends on the time of day
    Homie - what credit card do you use? I hope you're getting x2 points for all those purchases. haha - I'm happy it's all coming together! Thanks for taking the time to keep us in the loop.
    Nick
    I'm not driving fast, I'm flying low.
  6. #526
    Aug 24 2014
    Newport Beach, CA
    Ha, I wish I was rewarded in some way for spending more on this car! Got some great progress yesterday, new motor is getting close to completion barring a few little parts we came across that needed to be replaced like a tiny hairline crack in the new water pump I installed 10k miles ago along with the timing belt, found out the Stern motor mounts had a lot of play, and the power steering line wasn't replaced like it was supposed to be during the last build. Also got to break down the old motor and see the destruction first hand.
    Long story short, 5 holes in the block, snapped the rod on cylinder 6 in half, and the rod blowing out the block destroyed my starter motor. Good news is the Fx400 clutch looks brand new still and the turbos are unharmed.
    Parts ordered today overnight shipping:
    - 034 billet motor mounts
    - 034 power steering hose
    - New waterpump
    - New starter motor
    - Coolant hard pipe and oil dipstick o-rings
    - Crank center lock pin/bolt
    And some carnage pictures:
  7. #527
    Senior Member Two Rings MyXbfS4's Avatar
    Jan 18 2015
    2001.5 Silver B5 S4(His), 2002 Laser Red B5 S4(Mine) 2005 Blk B6 S4
    Los Angeles, California
    I just yelled out words that weren't very ladylike out loud by myself right now
    WOW!
    2002 Laser Red B5 S4 Sedan
    Tiptronic w/ Onyx interior
    1 of 16 sold in US - AoA
  8. #528
    Senior Member Three Rings Corradovolksb's Avatar
    Aug 29 2013
    2000 S4 and 2007 GMC Yukon
    Phoenix AZ
    Glad your making progress bro. Those last few pictures scare me and make me want to do rods now!! Keep it up you guys are close to getting it running again.
  9. #529
    Aug 24 2014
    Newport Beach, CA
    It was impossible to see the two holes in the block until the engine was disassembled but man that broken rod really messed things up while destroying itself. I believe today is the day I finally put in my last part order for the build, so much money adding up. But it'll be an amazing feeling to have the car running, there is literally not a single component in or around the engine that isn't brand new at this point.
    - OEM water pump
    - New Bosch starter
    - Coolant hard pipe o-rings, oil dipstick o-ring
    - 034 solid engine mounts
    - 034 power steering pump
    - New crankshaft gear bolt
    - New DLC washer from Scotty @Advanced Automotion
    - Center diff rear output bearing & seal from Scotty
  10. #530
    Aug 24 2014
    Newport Beach, CA
    Also know there's a gun enthusiast page on here, but is there anything bike specific? Got back in the mountain biking game this weekend after taking a break a few years after my last bike got stolen.
    Breezer Cloud 9, CF frame, Rockshox SID fork, raceface/Shimano XT component set, curious if there are other cycling junkies on here.
  11. #531
    Jul 04 2012
    Woodbridge, VA
    What is the DLC washer and why did you need a diff output bearing? Were you having sounds? Sorry if this has been answered but it's really hard to search through everything.
    Build is looking good my friend
  12. #532
    Hard pipe
  13. #533
    Aug 24 2014
    Newport Beach, CA
    Quote Originally Posted by vavJETTAw36 View Post
    It's the washer that goes between the crank and the crankshaft gear bolt, it's a not often talked about weakspot and if that little washer fails supposedly your engine is in trouble. Scotty has new ones, I did it just because it's super cheap and peace of mind.
    Quote Originally Posted by Cysco abt S4 View Post
    Hard pipe
    Very hard pipe.
  14. #534
    Nov 05 2009
    Denver
    Diamond laser coated or something like that
  15. #535
    Aug 24 2014
    Newport Beach, CA
    ^Yup, his are coated. Wish I knew the exact mechanics behind replacing it but went off Cinesnow's recommendation.
  16. #536
    Feb 12 2015
    Butler PA
    looking good man! I CANNOT WAIT to build my motor and make it perfect. HAHA. having a shaved bay car i take pride in my bays (not bae) as they say clean.
    keep up the good work!
  17. #537
    Aug 24 2014
    Newport Beach, CA
    Thanks man! It's such a good feeling to have a all this stuff brand new and worry free with no loose ends.
  18. #538
    Feb 12 2015
    Butler PA
    this is the 100% truth. the way you are going about the build is exactly how i did my other car. it is also how i do this one. Replace as much new as possible and with OEM equipment.
  19. #539
    Senior Member Three Rings ElementR's Avatar
    Nov 23 2013
    '07 Volvo S60R Cavalli Turbo, '93 Mustang Cobra Twin Turbo 347cid, '01 B5 S4 Tial 605's
    Grosse Pointe, MI
    Still don't understand the purpose or moreover the need for this washer. No mention of it in the Bentley manual and doesn't seem to be required for proper belt alignment wrt the crank sprocket. ECS doesn't mention it in their timing belt write-up either...
    http://bd8ba3c866c8cbc330ab-7b26c6f3...34-10-2012.pdf
    2001 Silver/Black S4, Built engine (RPM rods, ARP hardware, Mahle pistons, Supertech valvetrain, etc), Tial 605's @25psi on 93 oct, JHM FMIC, JHM full trans rebuilt/upgrade, 3" SS dp + CBE, Vast intake + bipipes + tune, ST Coilovers, Hotchkis Swaybars, RS4 wheels and interior goodies.
  20. #540
    Aug 24 2014
    Newport Beach, CA
    I was told those are friction washers and help prevent the possibility of the crankshaft gear bolt from loosening, another thing is these crankshaft gear bolts are one time use like axle shoulder bolts so they should be replaced anytime the bolt is removed.
  21. #541
    Hahaha worry free
    Sent from my HTC331ZLVWPP using Audizine mobile app
  22. #542
    Nov 23 2013
    Grosse Pointe, MI
    Well, after applying what's probably 400-500 lb-ft of torque to the bolt, I'd be shocked if it ever came loose! That considers install torque + 180 deg to stretch. And yes, agree - always replace them. You can actually see the stretch visually if you compare old and new bolts.
  23. #543
    Apr 26 2015
    Phoenix, AZ
    Hahaha worry free
    Lol
  24. #544
    May 20 2012
    San Jose
    I believe the keyway in the timing belt drive gear is a weak point and has failed a number of times in the past. The DLC washer should theoretically take some of the strain off the keyway by helping hold the pulley in place due to the extra friction between the pulley and the crank.
  25. #545
    Jul 04 2012
    Woodbridge, VA
    Good to know. Thanks man. I'll be ordering one just because. IF something does go wrong with my build I will know it wasn't that little sucker.
  26. #546
    Veteran Member Three Rings slow ride's Avatar
    Apr 20 2005
    Waterloo, IA
    Quote Originally Posted by oppositelock View Post
    Correct, and being it also drives our accessories seems to be a decent amount of load for what amounts to be just a bit of keyway engagement. I have had the timing sprocket off my car twice and not noticed any issues, but I always replace the crank bolt and torque to spec.
    02' Corvette ZO6 383 TT 1012whp 990wtq
    02' Tundra
    00' S4
    SOLD 93' AWD Talon 523whp 486wtq
  27. #547
    Aug 24 2014
    Newport Beach, CA
    Good to know, thanks for the info guys. Just never see anyone mention it ever so was interested if anyone knew much about that washer.
