Page 11 of 11 FirstFirst ... 91011
Results 401 to 423 of 423
  1. #401
    Senior Member Four Rings christianb5s4's Avatar
    Aug 24 2014
    Newport Beach, CA
    Copper gasket spray or paste is ideal for that, I use spray on the v-band joints and paste on the rest for my SSAC and it works great and hasn't shown any signs of leaks.
    Imola 2001 Stage 3 S4: 308K - 2.8sec FATs - Completely Refreshed/Built Motor - K04/RS6 Hybrids - Clutchmasters Stage 4 - Etspec - Cinesnow WG Lines - AWE Intercoolers - AA built trans - 4:1 Diff - JHM Trio - DriveshaftShop - 034 - H&R Coilovers - FCP - Bosch Motorsports - OZ Racing - SRM/SSAC exhaust - Tons of New OEM parts
  2. #402
    Senior Member Three Rings e30mclow's Avatar
    Feb 08 2015
    An Irishman living in NC
    Got out for a drive last night while the weather was cool
    Current: 2000 Black Stage III (BW-K04)
    Previous Bad Idea: 2000 Imola Stage III (BW-K04) - Now a parts car - HERE
    Previous "Better" Ideas: Euro e30 m3, Euro e34 m5, Inca Orange 2002Tii, '89 325iS, '89 318i, '90 318iS, '91 318iS, 2 X '87 316, '89 320i, '81 316 and so on..
  3. #403
    Senior Member Three Rings Corradovolksb's Avatar
    Aug 29 2013
    2000 S4 and 2007 GMC Yukon
    Phoenix AZ
    Awesome man. That's a great pic. How she running?
  4. #404
    Feb 08 2015
    Runs well, but my paranoid mind wants to chase every little noise. I sense that I'm hearing a boost leak, but cannot find other evidence of such.
    Got my NLS methodology down, thanks for lowering the RPM!
  5. #405
    Feb 19 2011
    Earth
    Quote Originally Posted by e30mclow View Post
    How often are you using nls?
    2000 Achat S4
  6. #406
    Feb 08 2015
    Very rarely.
    I've maybe only used it for somewhere between 8-10 shifts in 2 months. More so inquisitive as to what it felt like.
    Only launched the car once.
  7. #407
    Feb 08 2015
    The final few pieces came in to complete the 18z swap.
    Piles of spoke clearance on my of Work reps, so my current wheels should be similar. Looks like 17s would clear with a spacer and some trimming of the caliper.
  8. #408
    Aug 29 2013
    Phoenix AZ
    Hell yes looks bad ass
  9. #409
    Feb 19 2011
    Earth
    Very rarely.
    i've been fucking with it a lot. sounds extremely different on a bone stock car than to my old k24 car, i mean thats to be expected, but it sounds like the car is falling apart haha
    2000 Achat S4
  10. #410
    Established Member Four Rings Cysco abt S4's Avatar
    Oct 07 2016
    5mm spacers on the fronts if I remember correctly for the avus wheels
    Has anyone heard of oe wheels
    Jegs sells them and they make a nice looking rs4 replica in 18"x8 112x6 and I think the et was either 35 or 40 I'll try and link them
  11. #411
  12. #412
    Feb 08 2015
    A Gamblers Thread e30mclows Replacement S4
    I definitely have a boost leak issue, and I'm trying to chase it down.
    I had been suspicious of a light whooshing noise that I occasionally hear between 15-21psi. Sounds like it is coming from down on the drivers side.
    This morning was the first time the car registered a Positive Deviation code and hit limp mode.
    My compressor was stolen so no pressure test as of yet. I decided to just rip into it.
    APR bi-pipe so no TBB to suspect. Removed the lower and upper IC hoses, cleaned and inspected - checked out OK.
    Dug in more and removed the 90deg elbow off of the drivers side turbo - cleaned and inspected and looked like new. Did the same on the pass side, it was fine too.
    Used all my ratchet elbows and didn't remove but tightened up the pipes off the turbos to the inlets. These were new in April, so I don't suspect them to be torn, as I'm only on k04s.
    WG actuators are not loose in any way.
    Would it ever be something like the smaller lines that run along the inlets from the compressor housing? They'd hardly lose enough pressure to trigger limp mode though?
    I did forget to check those at the compressor housing while I was in there...
  13. #413
    May 20 2012
    San Jose
  14. #414
    Feb 08 2015
    God ole f-Ing F hose!
    Split right in the crotch. It was the 1st day hose, so I managed to get a few wraps of high pressure silicone repair tape in place with it in place.
    I'll order up a new one with clamps tonight. You always forget the F hose.
  15. #415
    Aug 29 2013
    Phoenix AZ
    Ahh F hose it's almost as big of a pain in the ass as the Throttle body boot lol. That's great you found it.
  16. #416
    Feb 08 2015
    This is how those hoses should be from factory. Whatever, it definitely works for now!
    The thing just rips now, and I mean way faster than it has been since swapping turbos.
    I think this little F Hose may be the root cause of my relentless chant "why isn't this car as fast as my imola was!!?".
    May be worthy of a revised tune once replaced as it was clearly leaking the whole time.
  17. #417
    Aug 29 2013
    Phoenix AZ
    Man that's great to hear. When you get a chance log it and we'll see how she looks. I can for sure make some revisions if needed.
  18. #418
    Feb 08 2015
    Off to buy some brake cleaner before buttoning it all up.
    So much room with these wheels!
  19. #419
    Feb 19 2011
    Earth
    the way your bumper meets the fender is the best thing about this photo
    2000 Achat S4
  20. #420
    Apr 01 2011
    B5 on jack stands
    charlotte
    When you installed the spoiler did you just use the supplied double sided tape or did you add to it?
    MODS
    Things'n stuff
  21. #421
    Feb 08 2015
    I just used the supplied tape.
    Doesn't seal 100% everywhere, but the thing is going nowhere.
    Hey 18z guys - I'm having a hell of time bleeding these things on my own. Any tips to what order I bleed these things in?
    I have been using a mighty-vac on the outside bleed screws and I'm not having much luck. Pedal is soft and goes to the floor...
  22. #422
    Feb 08 2015
    Aaaaaaand they're upside down lol.
    That's what I get for doing it at 7am
  23. #423
    Feb 08 2015
    Got the brakes flipped pretty quickly yesterday and they bled really easy. Great improvement over stock already, and there is still a lot of bedding in to go.
    I swapped out the bandaged up F hose for the 034 one this morning. The thing is boosting like a champ! I have a feeling that the WGDC needs to be fettled, as it was definitely leaking while being tuned. Now that it's fixed, I suspect things are a little off.
    Next up - meth!
