Page 62 of 98 FirstFirst ... 1252606162636472 ... LastLast
Results 2,441 to 2,480 of 3917
  1. #2441
    Senior Member Three Rings BG SQ5's Avatar
    Feb 21 2016
    '07 CBR1000RR
    PA
    Quote Originally Posted by Choiboy View Post
    Hi what is your winter wheel setup?
    Looks like the same 19" Sport Edition ST7s I'm running....on my DGP. Wait- is that MY car?! Lol...j/k, I don't rock badges
    '15 SQ5 Daytona Gray
    APR stage 2 (93 v4) - Fluidampr w/iABED 187mm - aFe filter/034 tube/modified box - MercRacing stacked h/x - AWE Touring
    21" Forgestar CF10s w/295s - 034 mounts, RSB & end links - Alu Kreuz - ecodes - deAuto LEDs - VCDS - P3
    12.054 @ 113.27 (-224 DA)
  2. #2442
    Senior Member Four Rings q5 dave's Avatar
    Dec 15 2014
    driving
    Quote Originally Posted by SQive View Post
    Dave, are you just now getting that little gem installed?
    is 3 months too long? lmao
    2013 Q5 3.0T Phantom Black
    1998 A4 1.8T Laser Red, Quattro, 5 speed manual
    IG @q5ds
  3. #2443
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    Quote Originally Posted by q5 dave View Post
    Yes, considering it takes all of 6.15 minutes to install it.
  4. #2444
    May 27 2016
    Atlanta
    Got my crank pulley, cooler, and new tune installed. Put down 389 ft lbs torque to the wheels on a Mustang dyno. Looking at throttle body prototypes as we speak.
    Sent from my Nexus 6 using Tapatalk
  5. #2445
    Established Member Two Rings Reecard's Avatar
    Nov 23 2016
    Battle Creek, Michigan
    Hi what is your winter wheel setup? Are those 255/50/18 on SPORT EDITION ST6? According to tire rack those 18s don't fit on an SQ5.
    They are 255/50/19.
    Reecard
    2016 SQ5
    Daytona Grey Pearl
  6. #2446
    Senior Member Four Rings riceboy22's Avatar
    Mar 26 2015
    2015 Audi SQ5, Felt F65x
    New York, NY
    Quote Originally Posted by centowski View Post
    Nice. Do you have any baseline runs to compare against?
    Current
    2015 Audi SQ5 3.0 TFSI (Build Thread | Flickr | Instagram)
    Past
    2006 Lexus IS350 | 2001 Audi S4 | 2000 Honda S2000 | 1999 Yamaha YZF-R6 | 1995 Acura Integra GS-R
  7. #2447
    May 27 2016
    Atlanta
    Quote Originally Posted by riceboy22 View Post
    not really. Was running a stock file right before this. It put down 260 hp to wheels, in stock mode (with 1 pulley, intake, exhaust).
    Sent from my SM-T813 using Tapatalk
  8. #2448
    Senior Member Two Rings Drichardson72's Avatar
    Apr 10 2015
    Vancouver, Canada
    FINALLY, a break in the weather in Vancouver. Washed and prepped my winter wheels and put them in storage in my garage attic.
    Also did a decent quick wash on the SQ.
  9. #2449
    Feb 21 2016
    '07 CBR1000RR
    PA
    Lol- I like how you edited your post with the wrong info after I replied answering your question with the right info.
  10. #2450
    Feb 21 2016
    '07 CBR1000RR
    PA
    Same mustang dyno? You were running a stock map with a s/c pulley prior?
  11. #2451
    May 27 2016
    Atlanta
    Quote Originally Posted by BG SQ5 View Post
    yes, same dyno. We were trying to get a baseline and did several pulls. Realized either the dealer overwrote stage tune, or engineer put wrong file on last dyno run.
  12. #2452
    Mar 26 2015
    New York, NY
    What did you do to your Q/SQ5 today?
    Any chance you did some logging that you can share (even over PM since this is a custom tune)? I'm still debating crank pulley sizing but have been leaning towards 183. I'm interested in seeing what IATs look like with the SQ5 setup with an aftermarket cooler and DP.
    Current
    Past
  13. #2453
    May 27 2016
    Atlanta
    No, haven't logged in months. I had a device in my obd2 port, but it died(might just need a new battery, tbh). Been swapping out other devices like cam (reads info for overlay)and such.
  14. #2454
    May 27 2016
    Atlanta
  15. #2455
    Mar 26 2015
    New York, NY
    ^ Nice! I was actually just trying to figure out what the larger intercooler would look like through the black ops grill and whether it was possible to paint it without negatively impacting effectiveness.
    Current
    Past
  16. #2456
    Veteran Member Three Rings plug1's Avatar
    Mar 31 2008
    Colorado Springs, CO
    Maybe I'm just internet dumb, but I can't see the pic
    Whoops...hopefully this one works.
    -Current: '17 Q5 3.0T BO Suzuka Grey-
    -Past: Glacier B8.5 AR, Arctic B6A4 USP, Black B5S4, Black B5A4-
  17. #2457
    Registered User Four Rings
    Jun 25 2016
    DMV
    Actually - OEM intercoolers usually come painted black. This is on purpose and improves cooling based on induction or some other heat energy principle I can't remember. Painting a front mount black only negatively affects cooling if the intercooler is in direct sunlight (rarely).
    Aftermarket intercoolers aren't painted black because (1) it adds a large expense to production and (2) people generally like to show them off. I'm a grower not a shower, so I'm about that stealth life.
  18. #2458
    Oct 06 2016
    CA
    Just curious: Would it be a waste if I got the cooler if I'm only going to do Stage 1?
  19. #2459
    May 27 2016
    Atlanta
    Doesn't add power, per se. Just keeps temps lower over time, so really depends on what you're planning to do.
  20. #2460
    Mar 26 2015
    New York, NY
    Quote Originally Posted by agautohaus View Post
    I was thinking more about what type of paint works best for this application. I get the benefits of it being black from an emissivity perspective, but the paint might create more of a barrier to heat transfer (even supposed specialty paints). I'm thinking the color is ultimately way less important from a performance perspective than convection cooling anyway. At the end of the day, I'll probably just leave it as-is either way.
    Quote Originally Posted by jaboki View Post
    It depends on how you define "waste"! I think even stage 1, there's a benefit, especially if you see warmer temperatures regularly and/or are heavy on the throttle. You should try taking some logs to see what they look like when you first start driving (after warm up) versus when you've been WOT a few times and start getting some heat soak. High IATs can result in a noticeable drop in performance as timing gets pulled and the bypass is opened.
    Current
    Past
  21. #2461
    Jun 25 2016
    DMV
    Totally agree. I think there is specific paints for this stuff, might want to look it up, I don't know unfortunately.
  22. #2462
    Dec 15 2014
    driving
    I've been stage 2 for a year, no additional cooling and don't plan on it. Maybe if I was in a warmer climate.
    IG @q5ds
  23. #2463
    May 27 2016
    Atlanta
    Yeah. I'm in Georgia, and the city street temps here push my thermometer over 100 pretty frequently. Plus, I may do some track time.
  24. #2464
    Mar 26 2015
    New York, NY
    Are you not tempted to go dual pulley?
    Current
    Past
  25. #2465
    Jun 25 2016
    DMV
    In the summer I feel major heatsoak even stage 1
  26. #2466
    Feb 21 2016
    '07 CBR1000RR
    PA
    Looks good! Not nearly as obvious as I thought it would.
  27. #2467
    Feb 21 2016
    '07 CBR1000RR
    PA
    You are referring to thermal radiation, and specifically with a black body. Like wearing white in the sun and black in the shade to feel the coolest during the summer. This principle is really only relevant when there is little convection (air movement) present though.
    Our radiators/coolers are needed under acceleration where the heat transfer is all about conduction (through the radiator body) and convection (to the air). Although any added radiative cooling wouldn't hurt, it's simply insignificant in the big picture for us. The issue is anytime heat is transferred through a body, there will be a temperature gradient. Adding more body (paint/primer) increases the gradient...not desired unless you want to insulate something. The added thickness also affects the boundary layer of the fin and resulting convective heat transfer. Therefore, the only ideal solution for a black look is anodizing (microns vs. mms) OR designing the fin spacing for a precise application of conductive paint/coating of some sort.
    I prefer the black look, but it's unclear if AWE still offers that and how they were achieving it. Also, forge used painted end tanks, which is a decent compromise.
  28. #2468
    Established Member Two Rings DanMontgomery's Avatar
    Jun 07 2014
    Clarksville, TN
    Actually painted my intercooler black after watching this video....plus, like everything to look like it came from the factory that way
    https://www.youtube.com/watch?v=f1QL9veQaNg
    V/r
    Dan
    2014 Audi Q5 (Ann) Prem + 3.0 TDI Scuba Blue
    - Ross-Tech Mods, Under Seat Drawers, VVF-102 Anthracite Gloss Gray w/275 DWS
    2015 Audi Q5 (Franz) Prem + S-Line 3.0 TDI Daytona Grey Pearl
    - Ross-Tech Mods, Under Seat Drawers, RSQ5 Grille, P3 Vent gauge, High Beam Assist, Stock Airbox Mod, Darkside InterCooler, MagnaFlow Exhaust, ChipWerke Pro, HR-2 Springs, VVF-103 Mystic Black w/295 DWS
  29. #2469
    Feb 21 2016
    '07 CBR1000RR
    PA
    Quote Originally Posted by DanMontgomery View Post
    V/r
    Dan
    Entertaining video and a fun experiment to show the principles. However, I hope you realize that nothing they did is at all representative of the operating conditions or the design parameters of the intercooler.
  30. #2470
    Feb 21 2016
    '07 CBR1000RR
    PA
    Quote Originally Posted by plug1 View Post
    Thanks! I'm still thinking about going with a 5000k though
  31. #2471
    Veteran Member Four Rings PreciseD's Avatar
    Feb 05 2014
    Orange County NY
    Built my intake after work.. has a nice whine to it without being obnoxious..
    Sent from my SAMSUNG-SM-G930A using Audizine mobile app
    ----- My EFR 7670 Build Thread ----- "The thing about quotes on the internet is you can not confirm their validity" - Abraham Lincoln -----
  32. #2472
    May 08 2016
    Northern VA
    Took the car into get the airbag recall initiated. I'm on grest terms with my service advisor and he knew the car has a tune. Asked him to notate that I don't need the ECM updates, however the tech did the update anyway which blew away the tune.
    Was panicking the whole way home that Unitronic had not yet prepared a new tune for the updated Audi software. Turns out they do and John @ Unitronic was able to quickly update my UniConnect account to reflect the new tune.
    What could have been a bothering situation is now settled. Now I am to think my car was flagged TD1
    For those who have yet to complete the airbag recall and have a tune without an at-home tuning solution, be prepared that your tune will be wiped if the dealership provides that new ECM updates.
  33. #2473
    Apr 10 2015
    Vancouver, Canada
    Quote Originally Posted by PreciseD View Post
    Looks awesome!
  34. #2474
    Mar 11 2017
    Montana
    I just bought a new to me 2012 Q5 2.0T. Now its time to get started. Stage 1 or 2? APR or GIAC? Either to coat the rims black or new rims. How to blackout the window trim and roof rails? Factory Hitch Kit or DIY it? So many questions and so many forum posts to get answers. Do I want know it it burns oil or not? lol. I had a B5 S4 with Stage 3 AWE ECU and all cool stuff. Loved the RS4 Bumper. I'm not looking to go to wild on the Q5, lol I said the samething with my S4. Thanks for all great ideas. Btw everyone has cool color names for their rigs. How do you know what the cool color name is? Mine is gray, lol I want a cool color name gray. haha
  35. #2475
    Sep 28 2010
    '18 S4, '16 SQ5
    Winston Salem NC
    Quote Originally Posted by tkawika View Post
    Lets see a pic! :)
  36. #2476
    Feb 05 2014
    Orange County NY
    Thank you sir! I retained the factory airbox (slightly modified) as in my experience they out perform heat shield/hot air intakes when it comes to IATs as it is a true cold air intake.
  37. #2477
    Senior Member Three Rings soul strong's Avatar
    Mar 03 2009
    joliet
    wrapped my trim in matte gunmetal metallic to match my wheels
    IG: q5chris
  38. #2478
    Sep 12 2016
    Natick/MA
    Quote Originally Posted by soul strong View Post
    IG: q5chris
    Nice :)
  39. #2479
    Established Member Three Rings hurricanes28's Avatar
    Sep 29 2015
    Slingshot pearl black
    Massachusetts
    Let me know if you want a down pipe and air intake for this q5 model 2.0t.
    I am selling mine
  40. #2480
    Jun 25 2016
    DMV
    dropped the price on my AWE downpipes! (shameless plug someone please get them out of my house lol)
