Page 13 of 13 FirstFirst ... 3111213
Results 481 to 509 of 509
  1. #481
    Active Member Two Rings friskuh's Avatar
    Jul 31 2017
    Orlando
    question, bc i saw your setup in the earlier pages.... would your turbo piping from headers to turbo work with the catless headers that people run? i was wondering if someone would buy those, cut them & weld the flange if it would work rather than using factory cats? i know youre in new york so you need cats but florida theres no smog inspection
  2. #482
    Veteran Member Four Rings UkuRiSh's Avatar
    Jan 09 2010
    New York
    Quote Originally Posted by friskuh View Post
    No, you can't install cats before the turbo they will meltdown! Vibrant have some nice high horsepower cats 3" 3.5". Cats must be installed after the turbo for best performance.
    2013 AUDI S5 Turbo < Build thread 6466 Turbo
  3. #483
    Jul 31 2017
    Orlando
    maybe i'm misunderstanding but when you mounted the turbo, your stock headers connected to the turbo. what i'm asking is if i upgrade my headers to the MerTop ones & edit it so that they're shorter & bolt it to the turbo would that work as well?
  4. #484
    Jul 31 2017
    Orlando
    this picture... the picture where the turbo's mounted on the engine... i see you're running the stock headers; is it possible to use the Mertop headers & cut it shorter & use it?
    - - - Updated - - -
    Quote Originally Posted by UkuRiSh View Post
    More pictures
    my bad, this one
  5. #485
    Jan 09 2010
    New York
    - - - Updated - - -
    my bad, this one
    That exhaust manifold is made from very thin SS unfortunately they will crack on day! I would keep stock cast manifold or build new turbo manifold from schedule 10 SS . Stock cast manifold should be good for 900hp and they more stable to heat
  6. #486
    Established Member Three Rings KnewJack's Avatar
    Apr 28 2016
    Absolutely brilliant, man!
    *2013 B8.5 S4
    APR Stage 2+ ECU/TCU 100oct Tune, JHM 187mm CP, Injen Intake. Stasis Touring Exhaust/ Springs & Rear Sway Bar, PLM HX.
    11.468 @ 122.06mph. 90ft DA. *Totaled* RIP
    2016 B8.5 S5 Prestige - bone stock.
  7. #487
    Jan 09 2010
    New York
    Quote Originally Posted by KnewJack View Post
    Thank you !
  8. #488
    Veteran Member Three Rings judeisnotobscur's Avatar
    Apr 22 2009
    America
    I am excited to get a chance to ride in the car :)
    Timing is Everything
  9. #489
    Jul 31 2017
    Orlando
    is it not possible to place turbo where the stock intake is? or in the tower behind it like SRM?
  10. #490
    Jul 31 2017
    Orlando
    Quote Originally Posted by judeisnotobscur View Post
    tell us how it goes!!
  11. #491
    Jan 09 2010
    New York
    Yes you can do it but it will be a lot more piping.
    - - - Updated - - -
    do I know you ? you local ?
  12. #492
    Apr 22 2009
    America
    Yes, it's J-Fonz. I'm hurt that you don't know my az screen name :)
  13. #493
    Jan 09 2010
    New York
    ha ha sorry Josh now I know
  14. #494
    Jul 31 2017
    Orlando
    so... what's next for the build?
  15. #495
    Jan 09 2010
    New York
    Next step is bump redline and add some power after 5k rpm on E85 fuel
  16. #496
    Jul 31 2017
    Orlando
    who's doing tcu tune? J fonz or 034?
  17. #497
    Jul 31 2017
    Orlando
    also, are you getting a revised tune with added timing? i think you said torque is only at 500 crank
  18. #498
    Jan 09 2010
    New York
    J-Fonz
    We keep tq at 700Nm for know, we still have little more room to bump the tq but only after we tune tranny.
  19. #499
    Jan 09 2010
    New York
    Here is progress of Cortex Boost Controller and finally working! Here is Base map for boost, I loved the way is works Turbo spools up faster with Cortex, here is log manual vs Cortex
  20. #500
    Jul 31 2017
    Orlando
    Did you replace the HKS one or is the Cortex added on? & what is it's purpose? to decrease boost when car's EGTs are too high?
  21. #501
    Jan 09 2010
    New York
    Yes I replaced HKS to Cortex! Cortex is very nice unit, I can control boost true each gear/rpm Also can be mapped Water meth pump duty cycle w flow / Wideband e.t.c works very well for me. We should have better EGT numbers with couple more revision and E85 . Purpose of installation Cortex unit is controll boost at each gear! Letís say if I use launch control, I donít need 20-22psi in first/second gear because traction ) Iíll post vid later I tried to launch my car with 15psi on first gear and car still spin the tires.
  22. #502
    Jul 31 2017
    Orlando
    Wow, just seen your video... If you could put the power down that would be a 0-60 monster. The hesitation was because you let off the throtte because of the wheel spin right? Your car's 0-30 is like 1 second then it hesitated & rose to 60 in less than 3 seconds.
  23. #503
    Jan 09 2010
    New York
    Yes this car is badass on pump gas, I guess we done pump gas tune with 22Psi by red line! Here is the VID who didn't seen yet
    added : I add little more boost on 2nd gear and lower down on 1st but don't have chance to test launch, road is wet and black ice in NY today spin tires on 3 as well
  24. #504
    Jul 31 2017
    Orlando
    are you on full throttle in the video?
  25. #505
    Jul 31 2017
    Orlando
    & do you think that your car beats the M4?? haha
  26. #506
    Senior Member Three Rings mjr034's Avatar
    Jul 07 2014
    2015 Mazda 3i GT
    Michigan
    Canít get the video link to work and my curiosity is very high ha
    2013 S5 3.0 TFSI ~ Prestige | DSG | Brilliant Black | Carbon Atlas
    | 034 | APR | AWE | BBS | BFI | BILSTEIN | ECS | VORSTEINER |
  27. #507
    Jul 31 2017
    Orlando
    Quote Originally Posted by mjr034 View Post
    YouTube Oleg Ukurish
  28. #508
    Jan 09 2010
    New York
    Rev 2 on E85!
    Almost full tank of E85 and left over 3 or 4 gal of 93 Oct in the gas tank, some how I'm getting E54-57 in my gauge could be poor E85. Power feels stronger from mid to the end then pump gas file. Here is the log 93Oct 22 psi vs E85 18 psi
  29. #509
    Jul 31 2017
    Orlando
    up the boost!!
