Page 22 of 22 FirstFirst ... 12202122
Results 841 to 851 of 851
  1. #841
    Apr 19 2017
    Houston
    Quote Originally Posted by jbullin2 View Post
    Just PM me! Should have another set done around Friday!
    Will do.
    Thank you Sir.
    Sent from my Pixel using Audizine mobile app
    My car.
    Stuff I've bolted to my car
    -Random Quote-
  2. #842
    Established Member Two Rings WillRaceForBeer's Avatar
    Nov 12 2007
    13 Black B8 S4, 01 Nogaro B5 S4, 95 Eclipse GSX
    Germantown, MD
    Got the TR7 programmed and installed today, did the trick!
    Only oddity is that I need to hit the push to start button twice. Wondering if there is a better trigger.. I found a switched source in the fuse panel near the ECU. Have not been able to find a reliable fuse diagram so I'm not sure what else is on the particular circuit. It's the 4th so fuse counting from the fender, the first 10 Amp. As I recall it was 5amp 5amp 5amp 10amp 15amp. The 10amp circuit switched on with ignition. (Wish I had grabbed a photo).
    GIAC chip, FrankentTurbo F21s, Evo MS Intake, 710ns, Billstein PSS9 Coil-overs
  3. #843
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Providence RI
    I am starting to get these symptoms in extremely cold temperatures (below 10F). OEMflywheel, clutch, and pressure plate. All installed about 20k miles ago.
    Just ordered an extended slave.
    2001.5 b5s4 built bottom stg3 on E - Sold
    2013 B8.5 S4 stage 2 DP
  4. #844
    Dec 03 2008
    2014 Forester XT, lawn mower
    Castle Rock, Colorado
    Just got a shout back from Scott at 3z3 wanting to test the (hopefully) final revision of the master switch solution soon.
    Sent from my SM-G930VC using Tapatalk
    2012 Audi S4 Prestige 6 speed, 034 Stage 1, 034 SC pulley, USP Intake, custom x-pipe exhaust, 034 Trans Mount Insert, 034 Front/Rear Diff Mount Inserts, JHM Stage 3 clutch, JHM LWFW, USP SS clutch line, 034 boost tap, Podi boost gauge
  5. #845
    Dec 03 2008
    Update, my car is spending the weekend at 3z3 to have two more revisions thoroughly tested. Hopefully, for the last time.
  6. #846
    Jul 28 2009
    Providence RI
    Put the longer slave in. It feels and works great! Highly recommend.
  7. #847
    Senior Member Three Rings jbullin2's Avatar
    Dec 21 2014
    2016 Mitsubishi Outlander SEL
    East Troy WI
    Quote Originally Posted by rtl5009 View Post
    :D
  8. #848
    Jul 28 2009
    Providence RI
    Iím not sure why everyone is still messing around with electrical solutions. The extended slave is simple, effective, and so easy.
  9. #849
    Dec 03 2008
    Testing went well, sounds like 3z3 should have final product ready to ship in a few weeks.
  10. #850
    Feb 21 2017
    TX
    Is there a difference between B8 and B8.5 slave cylinders? Looks like there are different part numbers.
    Is the Beck the way to go or should I just get a Sachs OEM? I am putting in a LWFW.
  11. #851
    Dec 21 2014
    East Troy WI
    Quote Originally Posted by Callandor View Post
    No difference. Youíll have to grind down the trans to fit the Beck/Arnley. Just get the Sachs. Iíve sold many of the extended slaves and I only use the Sachs slave.
