Page 1 of 5 123 ... LastLast
Results 1 to 40 of 186
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    ML320, UrS6, M235i Gone: K04'd B8 A4
    St. Louis, MO
    Items for Sale
    My B8 A4 mod rebroos
    Get it, rebroo instead of review? GAH!
    While I have too much time on my hands, figure I can post, and come back to edit as time passes, my opinion on the stuff I have added to my car. I'll try to give each a pedal responce rating between Dagree1 and Dagree5 with 5 being the best.
    Gonna be a long list
    Akebono Ceramic Brake Pads - Post #89
    PowerStop Drilled/Slotted Rotors - Post #90
    VCDS Mods - Vag Cable
    ECS Turbo Inlet Hose
    AFE Pro Dry S Air Filter - Post #143
    LED Interior Lights
    Suntec Carbon Window Tint - Post #123
    Spulen HFC - Post #121
    GIAC Xplus? ECU Tune
    Intercooler Hose Sound Box Delete
    R8 Coil Packs
    Rear Muffler Delete
    Wheel Spacers - Post #132 and #133
    Treadstone TR8 FMIC - Post #167
    Blackout Grille
    Vinyl Wrapped Interior Trim
    034 Transmission Mount Insert - Post #36
    Spulen Differential Mount Insert - Post #71
    Shadowline Wrapped Chrome Window Trim - Post #51
    034 Rear Diff Mounts - Post #22
    H&R Sway Bars - Post #122
    Moog End Links - Post #67
    Dual SBP8A Subwoofer - Post #37
    Ultra Racing Rear Brace - Post #39
    Self Made Strut Tower Brace / CR-15 - Post #15
    Ultra Racing Stut Tower Bar - Post #5
    Podi Boost Gauge
    Magnaflow mid muffler swap
    Whisbar S5 Roof Rack
    034 Street Density Trans Mount - Post #2
    Rockymounts Euro Pitchfork Bike Carriers
    Snow Performance Stage 2
    VMRV701 Wheels
    ECS Short Shifter - Post #176
    USP Stainless Clutch Line
    FUCHS Trans and Diff Fluid
    Custom Catch Can Setup
    CTS Silicone Intercooler Hose Kit - Post #173
    APR K04 tune
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Oct 26 2012
    St. Louis, MO
    Items for Sale
    034 Street Density Transmission Mount
    http://store.034motorsport.com/densi...s5-q5-sq5.html
    A couple of notes for the instructions:
    1. Should mention blue loc-tite for the two transmission mount bolts. This has shown to be pretty vital for keeping it tight.
    2. Only need to remove the front 13mm nut to take down the crossmember.
    Review.
    I could immediately feel that the drivetrain was tighter with this installed. The car moves with no hesitation when the clutch is released. Taking off too, there was no slop when getting on and off the throttle. I like how solid it makes transitions feel.
    The bad:
    There is a lot more NVH, mostly V than I want. It's almost all isolated around 2000 rpm and feels like the car has a bent axle. Even has a rhythm to it. I'll give it a few days to see if things soften up. If not, this might be one I take back off. No matter what gear I'm in, the car rumbles at 2000, plus, if I am stopped and want to rev the engine, feels like a small washing machine is under my seat.
    Have given it over 200 miles now to wear in and the rumbling/vibration when coasting to slow down in gear or around 2000 rpm is way too much for me. My car is pretty stiff already with sways, stock sport suspension, moog endlinks and the other 034 inserts.
    Score: Dagree1.5 - helped with drive-train slop, but added too much NVH. Removed and sold.
    Others have had much better experiences with this than I did, and don't have a significant increase in vibration. Lambda13 gives his a 4.5. Need a score from one of the Russian judges.
    Senior Member Four Rings Smellie's Avatar
    Apr 21 2015
    1996 Supercharged Miata
    Penn State University / LI,NY
    Items for Sale
    Wow! A Dagree of 3? Very nice product indeed
    2012 B8 A4 | CTS K04/APR 100 oct K04 Tune | 329whp/348wtq | 12.35 @ 110
    AWE "Track" Exhaust | CTS Turbo Downpipe | CTS Test Pipe
    ECS Kohlefaser Intake | Treadstone TR11 FMIC | Snow Performance Stg. 2 Water/Meth
    VMR VB3 19x10 | Airlift Performance 3P
    Oct 26 2012
    St. Louis, MO
    Items for Sale
    Quote Originally Posted by Smellie View Post
    Yeah. Feels like the engine is running really rough or a tire is loose. Will be interesting to see more reviews.
    Oct 26 2012
    St. Louis, MO
    Items for Sale
    Ultra Racing Strut Bar - I paid $120
    UR-TW2-1412
    Short review: Totally worth it, go buy one.
    I had already installed a CR-15 brace right behind the firewall under the flimsy stock strut brace and it made a big difference in steering response. Adding this one feels like it took out the rest of the body flex that made quick turns feel mushy. The difference now reminds me watching a cat run and change directions, there isn't a lag when I turn the wheel now, the front grabs and goes there.
    Took 10 minutes to install.
    Yeah, we have a second firewall right behind the engine, but it is not very thick and not one connected piece all of the way across. I had my stock strut brace off before installing and that firewall overlaps freely about 1/4 of the way over from the driver side. You can move it around easily by pushing or pulling. An aftermarket strut bar does make a big difference in how quick the car responds to quick turning inputs.
    Score: Dagree 4
    I believe it does a lot of what the Alu Kreuz does for a margin of the price. Plus, it's a neat place to put stickers. If EC, ECS or 034 started selling something similar, they would be on a lot more cars.
    Apr 21 2015
    Items for Sale
    I was under the impression that TheFifthDagree would be the best
    Oct 26 2012
    St. Louis, MO
    Items for Sale
    OH MAN! Now I gotta go back and change my scale because Smellie is a genius. Bet that sentence isn't said very often.
    Veteran Member Four Rings Lambda13's Avatar
    Jul 07 2012
    A4, car parts, paint, random sockets, OEM parts.
    Boston, MA
    Quote Originally Posted by blbroo View Post
    Damn he's onto something. Maybe you could give a negative rating so the worst could be negative TheFifthDagree.
    My 2009 A4 Prem+ Build thread
    Oct 27 2010
    Ibis B8 A4. Arctic B6 S4.
    Norwood, MA.
    Items for Sale
    So the Ultra strut bar bolts into stock location shock assembly bolts?
    2010 Ibis white S-line A4
    2.7t swapped stage 3 B6 S4 - Work in progress.
    Instagram- @Thisisastickup
    Oct 26 2012
    St. Louis, MO
    Items for Sale
    Quote Originally Posted by b6Hate4 View Post
    Sent from my toolbox using triple squares
    Jul 07 2012
    Boston, MA
    Do you just have these pictures already taken or are you running out to your car to take these every time? lol
    Oct 27 2010
    Norwood, MA.
    Items for Sale
    Ahhh would you look at that.
    Oct 26 2012
    St. Louis, MO
    Items for Sale
    Quote Originally Posted by Lambda13 View Post
    Already had them on my phone Mr. Gump.
    Jul 07 2012
    Boston, MA
    Oct 26 2012
    St. Louis, MO
    Items for Sale
    U2Nelson's CR-15 Strut Brace
    $120, purchase by sending him a PM. Can't find it on eBay or ECS and Eurocode hasn't copied it yet with a red version. (as of 9/25/15)
    OK, so on this one, I sort of stole his idea and made my own out of a $5 piece of angle iron. Took me a few hours to get right, so I would recommend just buying his, it looks a lot better. Can get it straight aluminum finish or anodized black.
    OldSport did a great install thread.
    http://www.audizine.com/forum/showth...altime-Install
    Goes right behind the firewall that separates the engine bay from the ECU / Washer tank area. Bolts on easily in under 20 minutes.
    Improvement is going to be way more than you expect from a small aluminum square bar. Takes a lot of the hesitation out of quick turns and makes the steering feel more connected. Wish like hell I had thought of this, guy has sold a bunch of them.
    per dollar, best mod I've put on my car besides the $2 audizine sticker.
    Score: Dagree 5
    Bonus points because it comes from a fellow member, is stealth under the cover and James seems like a great guy.
    Funny reading some of the threads on this. Was one guy saying no way it would do anything and he wouldn't want to add the extra weight up front for a car that is already nose heavy. thing probably doesn't weigh 2 pounds.
    If someone asked, what handling mod should I get first, this would get my vote for a quick and easy substantial improvement.
    Veteran Member Four Rings jmeenach's Avatar
    Mar 17 2014
    Los Angeles, CA
    Haaaa, this is legendary!
    Pedal Responce Team's expedition ace/Banana Responce Team first responder
    2013 B8.5 A4 Quattro. RS grille / 20" 'Flower Petal' reps / AFE / VCDS mods / more to come...
    instagram
    Oct 27 2014
    NEW YORK
    Items for Sale
    keep em reviews coming. this is a thread i finally want to keep browsing....
    Jul 07 2012
    Boston, MA
    You're missing out on the pedal responce thread man!
    Apr 21 2015
    Items for Sale
    i did something right!!
    Mar 17 2014
    Los Angeles, CA
    Really weren't a fan of the 034 Transmission mount, huh? I just saw your ad in the classified section.
    instagram
    Jul 07 2012
    Boston, MA
    Quote Originally Posted by jmeenach View Post
    Its not the transmission mount insert that everyone loves, its the new one they just made, the street density one.
    Oct 26 2012
    St. Louis, MO
    Items for Sale
    034 Differential Carrier Mount Inserts
    http://store.034motorsport.com/034mo...-aluminum.html
    Pricey little buggers at $95 for two small pieces of metal.
    this was my initial review. I liked them!
    First: My bolts were hella tight and I needed a breaker bar to get them loose. (may have also been the injured rib weakening me)
    Second: Use the lube boys. The inserts don't glide on in like the 034 gif shows. They draw in as you tighten the bolt (would be funnier if it was a nut).
    Third: WEEEEEEEEEE. I like it
    Already have the trans mount and the spulen diff mount and those made shifting crisper and the car feel more sporty. Maybe the oxygen level in the air tonight is extremely high, but these mounts made the car feel like it has 20 more HP. Throttle response is soooo much better and cornering is a joy as the rear really hooks up.
    Made the car feel more RWD than before and felt more responcive.
    TORQUE ACCURACY WARNING. If you over tighten this, you'll have a light whining noise under load.
    Score: Dagree 4
    There is no scientific method to my scoring. These are a good buy and deliver a better driving feel, also, really easy to install.
    Mar 17 2014
    Los Angeles, CA
    Ah. Makes sense.
    instagram
    Oct 26 2012
    St. Louis, MO
    Items for Sale
    I like the transmission mount insert a lot. It's the best of the drive-train inserts to get, in my opinion. Review forthcoming.
    Jul 07 2012
    Boston, MA
    Ah. Makes sense.
    Ya I actually have the same part at my house... Hoping my experience is different.
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    This thread. I like this shit.
    2013 A4 Quattro Brushed Steel / APR E85 Stage 2 / AG F421 Copper + Smoke + Neo Chrome / Eurocode FMIC + HFC / AWE Quad + CF Valance
    build / instagram / flickr
    Active Member One Ring AllaudiGone's Avatar
    Jul 01 2015
    RI
    As a lurker new to the mod scene for my b8.. A thread like this is very beneficial. Keep it up!
    Overall I give this thread 4/5 pedals, needs moar responce
    Sent from my SM-G925V using Tapatalk
    Oct 26 2012
    St. Louis, MO
    Items for Sale
    Quote Originally Posted by AllaudiGone View Post
    Veteran Member Four Rings AUDIMAN33's Avatar
    Jan 11 2014
    2014 Audi A4, Porsche Cayenne S, Mercedes Benz S430 4matic
    New York
    Items for Sale
    Is this a half ass build thread?
    Current
    2014 AUDI A4
    2003 AUDI A4 Convertible
    2004 VW Touareg V8
    Previous
    2010 BMW 328XI
    2002 BMW M5
    2013 JETTA SE 2003 MERCEDES-BENZ S430 4MATIC 2006 Ford Five Hundred SEL LEXUS GS460, 2011 CHEVY CAMARO 2008 BMW X3,2000 Audi A4,2003 LAND ROVER DISCOVERY,1996 LAND ROVER DISCOVERY,1988,SCIROCCO16V
    Apr 26 2014
    San Diego, CA
    Quote Originally Posted by AUDIMAN33 View Post
    No, it's a parts review thread.
    Oct 26 2012
    St. Louis, MO
    Items for Sale
    Oct 26 2012
    St. Louis, MO
    Items for Sale
    this one is just for B6Hate4
    Kenu Airframe Cell Phone Holder
    Think you can get it for $5
    BEST DAMN $5 you can put on a B8
    ^ not my car
    Seriously though, it holds your phone. I only use it for GPS, otherwise, phone is in my pocket or the console.
    Score: Dagree 2.5
    nothing special, does what it is designed to do.
    Jan 11 2014
    New York
    Items for Sale
    I feel ya
    Current
    2014 AUDI A4
    2004 VW Touareg V8
    Previous
    2010 BMW 328XI
    2002 BMW M5
    Jul 07 2012
    Boston, MA
    Just had a thought, when you write the review for each item on the list, link the post number next to it so that people can quickly find them.
    Oct 26 2012
    St. Louis, MO
    Items for Sale
    K. Good idea.
    Oct 26 2012
    St. Louis, MO
    Items for Sale
    034 Transmission Mount Insert - Once imitated, never duplicated
    http://store.034motorsport.com/trans...a5-s5-rs5.html
    Should be $45 instead of $75
    My initial thoughts were:
    If you like the total isolation of the drivetrain, then that is lost. I can feel the car better in my seat and hands now, but not in a harsh way at all, just a more connected feeling. No more noise. It does seem stiffer and bumps a bit harsher, but I have the sport suspension already.
    As for the MT, the best example i have is the 1-2 shift when it used to take a lot of finesse to prevent my passengers head from moving forward when I depressed the clutch then back when I re-engaged the gears. I guess the looseness in the system allowed a lot of inertia shifting that is gone now. Engagement into gears is more immediate too, both with up-shifting and down-shifting. I missed the tightness I felt in lower gears in my 6mt Acura TL when I went to this car and thought it was just due to the turbo vs NA. Now, the car is ready for any changes in input and has near immediate response. I can launch better now too without the chain reaction feeling of waiting.
    This thing needs to be torqued correctly and needs blue loc-tite. Too loose or no loc-tite and there is more slop than stock.
    My favorite mount/insert that I've put on while on my back, that has to do with a car. Not pertaining to a car, I've achieved over 9000....
    Score: Dagree 4.5
    If you ever feel like your car moves as though there is rope between the motor and the wheels and you wait for the slack to tighten, this is for you.
    Plus, 034 writes great instructions.
    Oct 26 2012
    St. Louis, MO
    Items for Sale
    Dual SBP8A Powered Sub
    http://www.amazon.com/Dual-SBP8A-160.../dp/B002WN2JS4
    I think I found one for $60
    Go easy on me Lambda13, I know you are an audio geek and this may lame you out.
    After putting a YUGE sub in the back of my step-sons car, his mom and I both decided we wanted more bass. I put one in her M35X and one in my A4.
    It's really easy to install a sub in the trunk. Posted my install notes here:
    http://www.audizine.com/forum/showth...phony-have-RCA
    Small box but it puts out great sound. I found it on many lists of the best powered subs to buy. This way, it's easy for me to unplug and remove if I need more trunk space. Plus, my kids think the blue light is sweet.
    Looks like this, I don't have that capacitor thing though.
    Score: Dagree 3
    Concert stereo system now cranks the Wu Tang like nothin to F with.
    Jul 07 2012
    Boston, MA
    Score: Dagree 3
    I have a 500/1 and a 10w3 in my trunk. For SHAME sir. FOR SHAME. Blue LED's. Talk of capacitors for an amp that doesn't even put out 200w peak. Or just capacitors in general is a joke, all they do is put more strain on your charging system and hardly do anything to actually improve performance. I am firmly anti-capacitor as they hold very little charge, discharge super quick and put additional strain on the alternator. I saw that sub in your original list and was like I hope he's joking about the Dual thing... Sounds like So Cold by Breaking Benjamin?
    Oct 26 2012
    St. Louis, MO
    Items for Sale
    Ultra Racing Rear Lower Tie Bar
    http://www.ultraracing.my/catalog/in...roller=product
    I got it cheap on "make an offer".
    Should have paid attention when I was installing my sway bars, or when replacing my lower control arm that I f'd up when installing my sway bars. Our control arms are already tied together by a beam in the back that this thing mounts on to.
    Don't think it did anything for handling. I didn't notice anything, at least. Saw one other person installed it recently but didn't see what they thought of it.
    Score: Dagree 0
    Sincerely, Winston Maxwell Dagree the Fifth, esquire
    Oct 26 2012
    St. Louis, MO
    Items for Sale
    Hey Andrew,
