Page 14 of 14 FirstFirst ... 4121314
Results 521 to 550 of 550
Thread: B5 V8 Swap
  1. #521
    Nov 03 2011
    B6 Avant 420-R
    Kampala, Uganda
    It’s looking good.
    His:
    Hers:
  2. #522
    Mar 29 2012
    1997 Audi A4 V6 Quattro
    Lynnwood, WA
    I don’t know.....
    Not sure if I should
    1) Add my X-pipe (2x2.5”, 1x3”, 2x2.5”) , delete resonator, and add dual 2.5” inlet muffler.
    2) Hack off one end of the x-pipe and make it two 2.5” to one 3” Y-pipe that connects to a 2.5” or 3” resonator.
  3. #523
    Mar 29 2012
    Lynnwood, WA
    Wrapped.
  4. #524
    Mar 29 2012
    Lynnwood, WA
    The plan...
    Add clamps after cats, which would then have approximately three feet of piping that leads up to where the X-Pipe will take on new residence. Goodbye factory resonator. I’m already looking for a 2.5” dual inlet/out muffler.
  5. #525
    Dec 10 2013
    Pickering, Ontario, Canada
    Skip the muffler. Just do twin vibrant resonators and party
    Sent from my SM-G935W8 using Tapatalk
    S4's New Lease On Life
    2001.5 S4 6-spd
    Currently "Monster"
    IG: 24_et
    MODS: Revo Stg 1, 034 Billet Subframe Bushings, SSAC V2 Downpipes, Custom True Dual Exhaust, Forge 007 DVs,
  6. #526
    Established Member Two Rings Jsol's Avatar
    May 02 2016
    Bellingen, Australia
    You also need to have the x-pipe closer to the engine otherwise you lessen the effect. Making progress:)
  7. #527
    Mar 29 2012
    Lynnwood, WA
    Quote Originally Posted by Jsol View Post
    Yes, you are correct.
  8. #528
    Mar 29 2012
    Lynnwood, WA
    I picked up a dual 2.5” in/out muffler. Made the ends slightly larger so my pipes can slide in tight. It was the only thing that costed me a hundred bucks. I still need to replace my rear 02 sensors and their harnesses. #almostthere
  9. #529
    Mar 29 2012
    Lynnwood, WA
    B5 V8 Swap
    Good start of the weekend.
    Took out the old resonator and muffler.
    I also started to repurpose the old hangers. They’re still in good shape. Only needed to shave of a bit of their surfaces to fit and tack weld in place.
    Rear hangers on the muffler are done.
    Now I just need to figure out my 90 deg turn forward of the muffler, maintaining clearance while routing forward, and how to set up the next hanger with reinforcements for two pipes instead of just one.
  10. #530
    Mar 29 2012
    Lynnwood, WA
    I need to smoothen out my welds, check for holes, and add reinforcements. I have two more turns before it connects to the front half. I also have one more hanger to install.
  11. #531
    Dec 10 2013
    Are those pipes touching? If they are you'll run the risk of them vibrating together and you'll get rasp. I'd space them out more so you'll get a deeper more mature sound
    2001.5 S4 6-spd
    Currently "Monster"
    IG: 24_et
  12. #532
    Mar 29 2012
    Lynnwood, WA
    Quote Originally Posted by Bordom View Post
    No. There’s nearly an inch of separation. It looks different from a side view. The way I routed them forward was to ensure there’s enough clearance from any other assemblies (rear drivetrain/rear suspension/rear mounts).
    I plan to add reinforcements to ensure they won’t vibrate together, or bend unexpectedly. My old V6 exhaust had reinforced routes as well.
  13. #533
    Senior Member Four Rings
    May 27 2016
    Westchester, NY
    Quote Originally Posted by king84 View Post
    That’s a X section muffler correct? Looking forward to more updates.
  14. #534
    Mar 29 2012
    Lynnwood, WA
    B5 V8 Swap
    Quote Originally Posted by Ephry73 View Post
    Oh yes it is.... Iol. Its pretty much an X-pipe within the muffler itself. It makes me question my plan to install my X-pipe after the cats. I’ve already deleted the resonator and I’m considering I can just make it straight the rest of the way without my X-pipe.
  15. #535
    Mar 29 2012
    Lynnwood, WA
    Almost forgot how much the clutch slave can be a pain to put back in when the system hasn’t been bled. Started to put a few things back together as I wait for my 02 sensors to arrive.
    I also cleaned out and replaced some contaminated grease for the CV axels.
  16. #536
    Mar 29 2012
    Lynnwood, WA
    Got my sensors in yesterday. Old vs New pic below. Minor difference in appearance. Four sensors for 60 bucks. We’ll see how they hold up. Ready to go OEM just in case.
  17. #537
    Mar 29 2012
    Lynnwood, WA
    B5 V8 Swap
    So i’ve been thinking....
    I have the muffler end ready and hanging, but everything that I want to route near the differential going forward is my concern. There are two turns I need to deal with before it connects to the aft end of the cats. There’s space, but not as much I would want for two pipes near the differential brackets. There’s also one last hanger I need to install.
    Side view pic of muffler inlet on the right, and routing path going to the left:
    My concern is the routing path.
    Pic from where the resonator use to sit, looking forward.
    Turn 1: (Last hanger would sit below the differential bracket.)
    Turn 2: Its kinda tight and probably would need one of the pipes to run a little lower than the other to clear through. I kinda don’t like that
    So, I thought I can repurpose my X-pipe, but in halves. Also, I’m repurposing the 3” downpipes I partially constructed a few months back. The 3” downpipe fits the routing path perfectly.
    My setup would be my two cats to a Y-pipe, which merges to a 3” piping. It would route through and split back to two 2.5” duals before the muffler.
    Note: To help hold pieces together I used two halves of pipe and clamps. It helps when I need to tack weld straight pipes together.
    I don’t think I would lose much in functionality, but we’ll see.
  18. #538
    Mar 29 2012
    Lynnwood, WA
    B5 V8 Swap
    It’s all tack welded in place and hanging. Aft end will be taken out carefully. I plan to get a pair of exhaust clamps to attach the midsection (after cats).
    NOTE: This is only my tack welding process to set things in place. I’m going to start finishing it off here shortly and fully reinstall it back.
    I don’t plan to remove my downpipes for anything else. I do need to route my 02 sensor harness after Im done welding the back half.
    It took a lot of energy, but it was fun.
    I want to slightly relocate this hanger a good inch lower to pull it up. There wont be any more “low hanging fruits” once I’m done.
  19. #539
    Dec 10 2013
    Interesting approach to the muffler there.
    2001.5 S4 6-spd
    Currently "Monster"
    IG: 24_et
  20. #540
    Mar 29 2012
    Lynnwood, WA
    Only one hanger came off during its removal. Everything else stayed intact. Picked up some band clamps as well.
  21. #541
    Mar 29 2012
    Lynnwood, WA
    B5 V8 Swap
    I would have kept it dual all the way through, but I ran into a little clearance issue when passing through and near the differential brackets. I’m sure I could have gotten away with it, but it was more of a headache to weld them so close together.
  22. #542
    Senior Member Two Rings 4Loops's Avatar
    Feb 21 2013
    1999.5 A4 B5 4.2 Quattro, MK4 Jetta TDI
    South Central Indiana
    Wow, certainly a lot of effort, but it shows! Can't wait to hear what it sounds like!
    Sent from my SM-G900W8 using Audizine mobile app
    1999.5 A4 B5 4.2 Quattro (My V8 Swap Project)
    2002 Jetta TDI ALH
    2000 C5 A6 Partout (<--click here for link)
    2007 GL320 CDI
  23. #543
    Mar 29 2012
    Lynnwood, WA
    B5 V8 Swap
    And its done and installed. Bolts on the band clamp seem a bit long and I may cut an inch off of each stud tomorrow. Everything aligned and fastened. Nothing hangs too low. Still need to route those 02 sensor harnesses.
  24. #544
    Established Member Three Rings Joe Jr.'s Avatar
    Mar 09 2017
    Longmont, CO
    You have a lot of work into that exhaust. looks great!
    2000 Avant A4 1.8TQA
    2001 A4 1.8TQM
    2002 VW TDI 5spd
  25. #545
    Feb 21 2013
    What magnaflow muffler is that? You got a part number to share? It's not the integrated x-pipe resonator/muffler is it?
    2002 Jetta TDI ALH
    2007 GL320 CDI
  26. #546
    Mar 29 2012
    Lynnwood, WA
    Quote Originally Posted by 4Loops View Post
    It does have an X-pipe within, but I dont have a part number handy right now.
  27. #547
    Mar 29 2012
    Lynnwood, WA
    Quote Originally Posted by Joe Jr. View Post
    Thanks. This how low it use to hang.
    And now.....
  28. #548
    Mar 29 2012
    Lynnwood, WA
    Got the uprights back in along with the CV’s bolted to the transmission. Trimmed off the studs on the band clamp and routed the 02 sensor harnesses.
    Decided to hack off the excess amount of unused mounting material on the cover plate. Also, the waterline closest to the manifold will probably get a new 45 or 90 deg aluminum fitting that’ll keep the waterline away from all that heat. I may even make a thin layer of heat shield to protect it all.
  29. #549
    Mar 29 2012
    Lynnwood, WA
    B5 V8 Swap
    In the midst of putting things back together, I decided to “improve” a waterline port. The waterline hose routing is a bit too close to the manifold. I should get the 90/45 deg aluminum fittings by today or tomorrow.
    I did try to weld and form some aluminum pipes to see how it would look. Thought about welding it to the block, BUT I would have to worry about impurities and contaminants. I would rather change out the barb fitting with and adapter. Then put a long 90 or 45 degree barb fitting.
  30. #550
    Mar 09 2017
    Longmont, CO
    following along...lots of work. looks good!
    2001 A4 1.8TQM
    2002 VW TDI 5spd
