Results 1 to 31 of 31
    Sep 17 2005
    Fremont, California
    Introducing the 034Motorsport Carbon Fiber Audi TTRS 2.5 TFSI Cold Air Intake System!
    034Motorsport is pleased to present our Carbon Fiber Audi TT RS Cold Air Intake System for the 2.5 TFSI! We are making these available to pre-order through August 20th, and will need at least 6 more buyers in order to meet our target production run. Production parts are expected to be ready on or before September 15th.
    034Motorsport’s engineers spent extensive effort to develop a complete cold air intake solution for the TT RS that yields horsepower and torque gains over the well-designed factory airbox. During the development process, many iterations were designed, prototyped, and tested, ultimately resulting in this beautifully-manufactured Carbon Fiber Cold Air Intake System. This intake offers horsepower and torque gains throughout the powerband, with peak gains of up to 16 crank horsepower and 13 ft-lbs of torque on stock turbo tunes, and over 35 crank horsepower and 24 ft-lbs with an upgraded turbocharger.
    Maximizing Airflow
    034Motorsport engineers first created a CFD-optimized carbon fiber intake tube, which is a direct, high-performance replacement for the plastic factory accordion hose. Using CAD software and 3D scanning technology, 034Motorsport was able to maximize the cross-sectional area of the intake tube while being mindful of space constraints, including the factory high-pressure fuel pump and firewall.
    The resulting part is a functional work of art - maximizing performance given the factory space constraints and featuring smooth transitions that ensure optimal airflow to the turbo inlet.
    Minimizing Intake Air Temperature
    To ensure that the 034Motorsport Cold Air Intake System draws in cool, dense air, the system includes a carbon fiber heat shield to replace the upper airbox. Bolting to the factory lower airbox, this heat shield allows the high-flow conical filter to breathe cold air from the factory inlet duct before the radiator. Both the carbon fiber heat shield and carbon fiber intake tube feature a fiberglass backing layer to aid in isolating cold, dense intake air from the heat of the engine bay.
    Performance Air Filter
    The 034Motorsport Carbon Fiber Cold Air Intake system houses a high-flow conical air filter with double-layer pleated cotton filtration medium. This air filter design offers increased flow through an enlarged filtration surface, while ensuring superior filtration.
    OEM+ Fit & Finish
    034Motorsport carefully selected the carbon fiber weave on the intake tube and upper airbox heat shield to match the factory carbon fiber engine trim found in the Audi TT RS's 2.5 TFSI engine bay. The 034Motorsport Audi TT RS Cold Air Intake System was designed to fit like a factory part, and mates directly to the turbo inlet pipe and factory lower airbox to provide an OEM+ look.
    Dyno-Verified Wheel Horsepower & Torque Gains
    034Motorsport's engineering and development efforts were validated on multiple vehicles using our Mustang AWD Dynamometer to ensure that the 034Motorsport Audi TT RS Cold Air Intake System provided substantial increases in horsepower and torque on both stock turbo vehicles and ones with upgraded turbo kits alike.
    Peak Wheel Horsepower & Torque with Stage 2:
    • Stock Intake: 377 Wheel Horsepower / 421 Wheel Foot-Pounds of Torque
    • 034 Carbon Fiber Intake: 390 Wheel Horsepower / 429 Wheel Foot-Pounds of Torque
    Peak Wheel Horsepower & Torque with Stage 3:
    • Stock Intake: 460 Wheel Horsepower / 424 Wheel Foot-Pounds of Torque
    • 034 Carbon Fiber Intake: 491 Wheel Horsepower / 443 Wheel Foot-Pounds of Torque
    Product Features & Details
    Features:
    • Developed In-House by 034Motorsport's Engineering Team
    • High-Quality Carbon Fiber Construction
    • OEM+ Fit & Finish Matches Factory Carbon Fiber Engine Trim
    • Dyno-Proven Horsepower & Torque Gains
    • Improved Engine & Induction Sounds
    • Increased Throttle Response
    • Compatible with Stock, RS500, and APR Stage 3 Turbochargers
    • Large-Diameter CFD-Optimized Air Intake Tube
    • Fiberglass-Backed Heat Shield
    • Improved Airflow from Factory Airbox & Intake Tube
    • High Performance Pleated Cotton Air Filter
    What's Included:
    • 034Motorsport Carbon Fiber Audi TT RS Air Intake Tube
    • 034Motorsport Carbon Fiber Audi TT RS Upper Airbox Heat Shield
    • 034Motorsport Double-Layer Pleated Air Filter
    • Installation Hardware
    Compatible Vehicles:
    • 2012 - 2013 Audi TTRS 2.5 TFSI (8J)
    Wheel Horsepower Dyno | Stage 2 100 Oct | 034Motorsport Carbon Fiber Audi TT RS Cold Air Intake vs. Stock Airbox
    Wheel Horsepower Dyno | Stage 3 100 Oct | 034Motorsport Carbon Fiber Audi TT RS Cold Air Intake vs. Stock Airbox
    Click Here to Pre-Order!
    Please don't hesitate to contact me directly via PM or email with any questions.
    Cheers,
    Laszlo
    Veteran Member Four Rings Evilevo's Avatar
    May 26 2008
    2013 TT-RS, 2017 Golf R
    MD
    👍 Can't wait to get mine!
    AMD - 034 Motorsport - EPL
    Slow4: Did he let you touch his button to extend his spoiler
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by Evilevo View Post
    �� Can't wait to get mine!
    We can't wait to start shipping!
    Sep 17 2005
    Fremont, California
    Hank at Iroz Motorsport had a chance to do some independent testing on Tim's APR Stage 3 Audi TT RS at his shop in Nevada. He was able to replicate gains quite similar to ours, seeing ~26 WHP gains with the hood down in 102 degree ambient temperatures.
    You can really see how much of a restriction the stock intake becomes past 5,500 RPM, allowing the GTX3576R turbo to pick up over 2 PSI by redline with no tuning changes.
    Quote Originally Posted by Hank@IrozMS
    102 degree dyno room temps, 85% RH.
    2 throw away dyno pulls, 5 minute cool down, then 90 seconds between pulls from the time the tires stop. Best run of each 3 sets shown. For the record, they were all within ~3whp.
    Sep 17 2005
    Fremont, California
    I had the time to post a quick behind-the-scenes look at the development of the Audi TT RS Cold Air Intake System on our blog yesterday. If you're interested in what goes into making your performance parts, it's worth a read!
    - Laszlo
    Quote Originally Posted by 034Motorsport
    Developing the Audi TT RS Carbon Fiber Intake System
    Ever wonder what goes into the design, prototyping, and testing of a performance cold air intake? Take a behind-the-scenes look at the process used by 034Motorsport engineers in this Tech Article: Developing the Audi TT RS Carbon Fiber Intake System
    The reality is that factory Audi/Volkswagen air intakes on newer vehicles set the bar quite high in terms of fitment and performance. The days of merely replacing the factory airbox with some piping and a generic cone filter and seeing performance improvements are long gone - in fact, many so-called "cold air" intakes are detrimental to performance under actual driving conditions.
    While there is often room left to improve on the factory design, it requires a thorough analysis of the factory components, and an OEM+ engineering mindset.
    Read More on the 034Motorsport Blog
    Sep 17 2005
    Fremont, California
    Audi TT RS Air Intake Update: They're Shipping!
    We should have enough done in the next few days to fulfill through the August 19th/20th pre-orders! Each of the intake components is thoroughly inspected before assembly and shipment. These ship in BIG boxes as they are fully assembled, which should make installation much easier for you.
    More carbon fiber components are being manufactured and we should have parts on the shelf next month. The manufacturing/assembly process has been more time consuming and expensive than originally anticipated, so the retail price may be going up in the near future.
    Thank you again to everyone who pre-ordered and helped make these intakes a reality! We really appreciate your patience, and can't wait for you to receive the intakes and install them! :)
    Here's a picture from a local customer who picked up yesterday and already has their intake installed:
    Carbon Fiber Audi TT RS Air Intake System by 034Motorsport
    Sep 17 2005
    Fremont, California
    We sold out of the second run as well! The next production run of Audi TT RS Air Intakes will be ready to ship by March 2nd. Thank you for all of the orders!
    Here's another install on a local customer's car to hold you over in the meantime:
    Sep 17 2005
    Fremont, California
    Thank you to everyone who made it out to WinterFest 2016 this past Saturday at 034Motorsport! We put together a quick recap video from the event, and you can read more about it and see pictures here.
    If you've ever wanted to check out the 034Motorsport Performance Facility but live too far away, this video is worth watching! We had the entire service side of our building open, and were giving guided tours of our Engineering, Machining, and Manufacturing Departments next door.
    Audi Club Golden Gate Chapter joined us at the event, and even Audi on demand came by with a C7.5 Audi RS7 to showcase their new service in San Francisco. We had over 150 cars show up despite the rain, and over 200 Audi enthusiasts were in attendance!
    Looking forward to SummerFest in July!
    Sep 17 2005
    Fremont, California
    Some video/sound of this Audi TTRS intake in action, thanks to one of our awesome customers.
    Sep 17 2005
    Fremont, California
    We still have a few intakes left from the current production run, which is scheduled to be complete next month!
    Keith's Audi TT RS with RS500 Turbo Kit is now running our Carbon Fiber TTRS Cold Air Intake Upgrade! You can read more about his car below.
    034Motorsport CF Audi TTRS Air Intake System | Increase Horsepower & Torque, Enhance Induction Sound
    Sep 17 2005
    Fremont, California
    The next run of these intakes will be ready to ship in just a few weeks!
    Feb 19 2004
    Nor-Cal
    I've had this on my TTRS for at least a month or so now. So happy with it.
    On APR Stage 2 software/DP/Exhaust, i'm not sure I really felt much on the butt dyno.
    Fit and finish is top notch. Great turbo sound and additional sounds from the BPV. Very pleased with it.
    Only minor down side is my OEM CF trim is slightly yellowed compared to the new 034 piece.
    Thanks 034!!!!
    '12 TT-RS
    '01.5 S4 - Silver
    Mods: "A pair of pliers and a blowtorch."
    Sep 17 2005
    Fremont, California
    Update: Good news for 8P Audi RS3 owners watching this thread... We were able to work with out friends at Awesome GTI in the UK to verify fitment of this intake on the 2011-2013 Audi RS3!
    Quote Originally Posted by reefer_bob View Post
    Thanks 034!!!!
    Thank you for your order and the review!
    Sep 17 2005
    Fremont, California
    We appreciate your continued orders and patience! We expect to have more of these intakes shipping next month.
    Sep 17 2005
    Fremont, California
    Just checked the shelf we still have 2 in stock ready to ship. Don't be the unlucky guy that has to wait for the to be back in stock.
    Sep 17 2005
    Fremont, California
    We should have these back in stock 8/9! Thank you for all the orders
    Sep 17 2005
    Fremont, California
    We just came back from Fastivus! Who saw us out there?
    Sep 17 2005
    Fremont, California
    We just posted our recap of Fastivus!.
    034Motorsport at Fastivus!
    Sep 17 2005
    Fremont, California
    Who's going to Big SoCal Euro?
    Let me know if you need any specific parts and we can bring them down to the show!
    Sep 17 2005
    Fremont, California
    Thank you for all the orders!
    Sep 17 2005
    Fremont, California
    A look back at Big Socal Euro! Did any of you swing by the booth?
    BIG SOCAL EURO 2016 | AN EVENT FOR ALL
    Sep 17 2005
    Fremont, California
    Thank you for the orders!
    Any reviews to share?
    Sep 17 2005
    Fremont, California
    Sep 17 2005
    Fremont, California
    Trailing arm bushings have been updated! They will now come with the complete arm with the bearing pressed in to save you some time and money!
    Features:
    Fully Assembled with New Factory Steel Trailing Arms - Simple Bolt-In Installation!
    Genuine Aurora Spherical Bearings Featuring Teflon Race Lining
    Billet Aluminum Bearing Holders - Anodized Black
    Stainless Steel Bearing Spacers
    Improved Handling & Road Feel
    More Precise & Predictable Handling
    Fully Rebuildable
    SPHERICAL REAR TRAILING ARM KIT, MKV/MKVI VOLKSWAGEN GOLF/JETTA/GTI/R & 8J/8P AUDI A3/S3/RS3/TT/TTS/TTRS
    Sep 17 2005
    Fremont, California
    How was everyone's Black Friday/Cyber Monday buying extravaganza! I hope no one missed out on our sale :)
    Sep 17 2005
    Fremont, California
    Looking for rear adjustable control arms to get more camber? Well, look no further!
    Features:
    Billet Aluminum Construction - Anodized Black
    Approximately 5 Degrees of Camber Adjustment (-2.4 Degrees or +2.6 Degrees)
    Adjustable in 1/36" Increments. Each 1/36" Corresponds to ~0.18 Degrees.
    Dust boots now included!
    034MOTORSPORT, REAR UPPER ADJUSTABLE CONTROL ARMS
    Sep 17 2005
    Fremont, California
    In the Fremont California area? Don't miss out on our open house!
    Dynos starting at $79 or $89 for three pulls!
    NorCal Audi Club and 034Motorsport bring you WinterFest 2016! Join us at 034Motorsport for another great meet with food, cars, and fun!
    We'll be hosting the 4th Annual NorCal Audi Club WinterFest as well as another 034Motorsport Dyno Day & Open House on Saturday, January 21st! We'll have all of the attractions you're used to, as well as a few extras:
    Cars & Enthusiasts - Bring your stock or modified Audi, meet fellow enthusiasts, see their cars, and get an in-depth look at some of 034Motorsport's race cars and projects.
    Food & Drinks – This year Javad is bringing plenty of home-made chili, and we’ll have drinks and snacks on hand for you as well.
    Open House - We will be giving tours of the 034Motorsport Facility, including our Service Department. This is your chance to see how our parts are made, and get a behind-the-scenes look at what goes on here at 034. :)
    Discounted Products - We will be offering 10% off all 034Motorsport-branded products and merchandise at the event, as well as discounted pricing on 034Motorsport ECU Upgrades.
    Free Raffle - Everyone who attends can enter their name in our free raffle, featuring items from 034Motorsport.
    Dyno Runs - We are offering great deals on baseline dynos, and accepting 16 cars. See what you car makes on our Mustang AWD Dyno, or just check out some of the other cars doing pulls.
    Dyno registration
    Facebook event
    https://www.facebook.com/events/1213223295433433/
    Sep 17 2005
    Fremont, California
    Waiting to see 034Motorsport's R460 Audi S3 in action? Video from the European Car Magazine 2.0T Tuner GP presented by Continental Tire
    Sep 17 2005
    Fremont, California
    We have four of these intakes on the shelf and ready to ship!
    Sep 17 2005
    Fremont, California
    We have plenty in stock ready to ship! Make sure you take advantage of the free shipping we have going on for a limited time!
    Sep 17 2005
    Fremont, California
    Have you seen our latest feature on TEeddy's R420 MKVI Volkswagen Golf R
