Page 36 of 60 FirstFirst ... 26343536373846 ... LastLast
Results 1,401 to 1,440 of 2361
  1. #1401
    Veteran Member Four Rings pwdrskr's Avatar
    Aug 21 2010
    Quote Originally Posted by G_Wagon View Post
    So...what ur saying is the stock catback with an aftermarket downpipe is quieter than an aftermarket catback?
    I'd say so, yes. Probably obvious. I started with the Statis catback only, then added DP and HFC. Addition of the DP and HFC didn't noticeably increase the sound. The AWE was a very nice unit and sounded great, I just didn't want the noise. To be clear, the noise was mostly noticeable immediately after startup and under heavier load at slower speeds. The noise at freeway speeds was fine.
    I couldn't feel any difference in performance between any of the cat back options either. I did with the DP and HFC. So, in the end I decided that since there wasn't a noticeable performance gain it wasn't worth putting up with the noise.
    The larger exhaust tips is nice aesthetically, but again, not worth the trade off for the noise.
    Of course this is all subjective and 100% a personal preference kind of thing. I went through the same process with a few different intake options. In the end the noise was just too much for my preferences
    13 allroad/Prestige/ibis/blk, 20%, expel, APR K04, AWE DP, Eurocode FMIC/HFC, GFB DV+, R8 coils, NGK BKR8EIX plugs, 034 Trans & Rr Diff Mounts, Apikol Rr Diff Mount, Vogtland coils, Alu Kreuz, Stasis S4/S5 Rr Sway, Vorsteiner V-FF 104 (20x10/et30), Conti ExtremeContact DWS 06-275/30ZR20, Stoptech rotors, Hawk Ceramics, iJDMTOY 3000K Amber Yellow fogs, F/R e-codes, semi-dyn sigs, RS5 Pedals, Perf. Shift, load rail storage sys, under seat bins
  2. #1402
    Sep 06 2017
    05 Subaru LGT (HTA71)
    Somerville, MA
    Quote Originally Posted by DetailScience View Post
    I have the resonated downpipe from AWE, so I am not expecting much additional drone, just a deeper tone. I have had a number of Magnaflow systems across many applications, they all drone, I stopped using them for my last few projects.
    That had been my understanding with Mangnaflow setups in the past, but so far I've heard mostly good things about the Magnaflow for the allroad. I've specifically asked about drone and everyone seems to be reporting no drone issues.
    My plan right now is only CBE, no DP. I noticed the cat is a different pipe for this car. Is the HFC+CBE worth it or should I just be sticking with a CBE? With this vehicle I'm not going for max performance upgrades. Just some aesthetics. But if it's silly to skip the HFC then I could go with it...
    > 2015 Glacier White Metallic allroad P+ <> Airlift 3P <> Vossen VFS-2 Satin Bronze <> RS4 FBSW <> BFI Shift Knob <> NGP Rearguard <
  3. #1403
    Established Member Two Rings DetailScience's Avatar
    Oct 03 2017
    Golden, CO
    Quote Originally Posted by Allthea View Post
    There is zero performance gain from a downpipe, the stock downpipe flows pretty well already. Some mid back systems gain a few horsepower, but replacing the cat with a high flow unit would be the primary source of power gains. I am running my K04 catless to maximize gains and eliminate the possibility of cat failure (always fun).
    Bagged 2015 Scuba Blue allroad
    DetailScience Build Thread
    3Zero3 Motorsports
    Instagram: @jburgmaier
  4. #1404
    Sep 06 2017
    Somerville, MA
    So is the HFC what's required to go "Stage 2" on Audis? Also I'm still trying to figure out what the "test pipe" is that I've been hearing about. I need to find the right area to go digging.
    I don't have any plan to go past Stage 1, eventually. I'd do it tomorrow if I didn't have almost 3 years left on my CPO.
  5. #1405
    Feb 02 2017
    Beaverton, OR
    I thought you can do HFC for Stage 2 instead of exhaust for proper airflow?
  6. #1406
    Oct 03 2017
    Golden, CO
    Test pipe would be catless, and Stage 2 takes advantage of the additional exhaust flow from a high flow cat. The factory down pipe and mid back system flow fairly well, but there are some power gains from aftermarket systems.
    3Zero3 Motorsports
  7. #1407
    Veteran Member Four Rings oatzel's Avatar
    Jun 02 2004
    LA
    No drone on my magnaflow. Been super happy with it.
    Current: '14 allroad, Premium +, Sport, Black on Black, H&R c/o, Magnaflow exhaust, Hotchkis swaybars, Neuspeed Gunmetal RSe102, CR-15
    Old: '12 4dr GTI Autobahn, Black on Black
    07 s4 avant, ibis, stasis exhaust, vogtland c/o, h-sport rs4 sways, vmr gunmetal v710s, 50/35% tint
    09 A4 2.0t
    03 a4 3.0qms
    00 1.8TQ
  8. #1408
    Veteran Member Four Rings A3 Guy's Avatar
    Apr 01 2011
    Charleston SC
    Hey guys, just picked up an allroad after a brief leave of absence from the Audi world. I had ST coils on my old A3 and am thinking about picking some up for the allroad since Black Friday/Cyber Monday is coming up. The only concern I have is that I had some significant clunking noises from the STs on my A3 and wanted to see if anyone has first hand experience with them on the allroad.
    Any other recommendations for coils would also be appreciated! Happy to be on the allroad train
    ~Brennan
    2014 allroad Premium Plus
    Flickr
  9. #1409
    Sep 06 2017
    Somerville, MA
    Taking an aggressive look at air systems and wheels this week. There are some extended black friday deals coming up and I'm thinking of making a purchase and squirreling it away until the spring...
    Looking at:
    Airlift 3P system Front/rear bags/struts
    dual compressors (VIAIR 444c is what I'm leaning toward)
    upgraded check valves
    Dual wiring harness
    the shop i was talking to suggested dual 2.5gal tanks (they thought this would fit better in the spare tire well) but I think I've seen 4gal setups on allroads in the spare tire well - @dropshadow comes to mind - anyone have thoughts on tank sizes?
    3/8" lines
    because bags bracket
    Wheels, I was thinking 20x10 but the place I spoke with said 20x10.5 should fit fine and wouldn't cost any more. I like the fit of @slow_poke25mph 20x10.5 et35 wheels on air... allows for a little tuck if I want - wondering what the tire size is on these? I don't want to go too thin. The Northeast roads suck even in the summer so I would like some tire protection for the rim. I'll have to see if the wheels I want come in et35 (I don't know if this is something I can just choose...?) Am I looking for trouble going with a 10.5, meaning I will have to use a thinner tire? If I go 10.5 are there some definite modifications I need to make to the wheel well to not mess up the tire / rim?
    Anyway, if people have ideas on anything I might be missing or other things to consider while this is happening, please let me know! I'm currently combing through the Official B8 Air Ride Thread
  10. #1410
    Veteran Member Four Rings earhythmic's Avatar
    Sep 17 2006
    B6 Dolphin S4
    San Francisco, California
    The BB B8 bracket can be bundled with a tank that fits perfectly in the spare tire well. Also, 444 comps on that bracket will be tight. Check out my build thread (link in sig), post #83 I go into details about my air install.
    2013 Allroad - 12.18s 1/4 mile
    CTS K04| APR | IE | Magnaflow | AirLift 3H | Hotchkis | Vorsteiner
    clicky for build thread
    past: B6 S4, B5 A4
  11. #1411
    Sep 06 2017
    Somerville, MA
    Quote Originally Posted by earhythmic View Post
    Perfect, info like this is just what I needed. I'll probably stray from the 444 comps due to that.
    Airlift is doing a 25% off controllers 15% off air setups (minus struts) so I figure now is good a time as any to jump on it.
  12. #1412
    Feb 02 2017
    Beaverton, OR
    I'm pretty sure they do make a allroad specify kit...the kit I bought is specifically for the b8 A4 Avant...
    I haven't installed it yet, so can't tell u how it works...
    Interesting as I came across this - allroad with KW Height Adjustable Springs - https://www.gmpperformance.com/index...1#!prettyPhoto
  13. #1413
    Established Member Three Rings G_Wagon's Avatar
    Jan 21 2017
    Cabbagetown, Atlanta, GA USA
    Quote Originally Posted by chip_ View Post
    The springs for the Avant and allroad are interchangeable...that what I was inferring...
  14. #1414
    Jan 21 2017
    Has anyone has to replace their clutch? If so what were ur symptoms and what mileage?
  15. #1415
    Feb 02 2017
    Beaverton, OR
    What skid plate is for the allroad from ECS?
  16. #1416
    Mar 28 2009
    Minneapolis, MN
    The one marked "from the 2013 model year" here: https://www.ecstuning.com/b-ecs-part...3251ecs01akt2/
  17. #1417
    Feb 02 2017
    Beaverton, OR
    Thanks dropshadow!
  18. #1418
    Jan 21 2017
    Skid plates on sale today $50 off...
    $174
  19. #1419
    Feb 02 2017
    Beaverton, OR
    $174
    The reason I asked.
    Is this upgrade worth it?
  20. #1420
    Jan 21 2017
    The reason I asked.
    Guess it depends on how low u go...
    If ur static and really low it may be a good idea...if ur stock or riding on air probably not necessary...
  21. #1421
    Sep 06 2017
    Somerville, MA
    oh snap. I did not see it was on sale... might have to snag this.
  22. #1422
    Jan 21 2017
    Anyone know how to lift the front wipers up to clean the windshield???
  23. #1423
    Veteran Member Four Rings DirtD1ver's Avatar
    Feb 20 2013
    2017 Allroad, 2015 Q7
    MD
    In the MMI under the car menu there is a screen for services and checks. From there you should be able to put the wipers into the service position and raise them from the glass.
    Current: 2017 Allroad Prestige Manhattan Grey
    Previous:2013 Allroad Prestige Monsoon Grey
  24. #1424
    Mar 28 2009
    Minneapolis, MN
    Quote Originally Posted by DirtD1ver View Post
    You can also put the wipers into service position by pulling down on the wiper stalk immediately after turning off the ignition.
  25. #1425
    Feb 20 2013
    MD
    I always forget about that one.
  26. #1426
    Jan 21 2017
    Senior Member Three Rings skifreak85353's Avatar
    Sep 23 2015
    Arlington, VA
    This topic got buried a while back...with a second one on the way, this is now more of a concern. Why does only one of my seats have the car seat tether? Even more curious, the stickers signifying the tether are there. Thoughts on how to rectify this?
    ____________________
    2014 Audi Allroad Prem+ Moonlight Blue | 19" S5 Rotors w/ 10mm H+R spacers | 19" S4 Peelers plasti-dipped anthracite w 25mm and 30mm H+R spacers | Stasis RSB | Alu Kreuz | Avant S-Line springs | 20% tint | Vag Com mods
    2009 Volvo XC90 V8 R-Design
    2013 Subaru WRX Limited (Satin White Pearl) - Gone but not forgotten
    The Instagram the_radifier
  28. #1428
    Jul 02 2016
    Florida
    Quote Originally Posted by skifreak85353 View Post
    Wouldn't the center position utilize one of the left and one of the right tether points?
  29. #1429
    Mar 28 2009
    Minneapolis, MN
    It is definitely odd. Do you know your car's full history? Any reason the right side would have been replaced? I wonder if there was an issue that was addressed under warranty and a sedan seat section was installed instead of the wagon version with the anchors.
  30. #1430
    Sep 23 2015
    Arlington, VA
    Quote Originally Posted by weverb View Post
    I think you are referring to the LATCH points. Iím referring to the anchors for the third point at the top of the car seat. On our cars the anchor is at the top of the seat in some other cars, like my wifeís, the anchor is far down on the back of the seat.
  31. #1431
    Sep 23 2015
    Arlington, VA
    Unfortunately, I just know what the carfax told me. Bought it sight unseen thinking the CPO warranty meant it was pretty squeaky. Last time I do that. Had a wonderful experience buying sight unseen on the car before it, thought Iíd get the same luck.
    Were there any seat recalls? Should this have passed the CPO checklist? Do you think I have any grounds to go back to the dealer? Mind you, I bought it back in early May and the dealer is in Miami, and Iím in Arlington, VA.
  32. #1432
    Mar 28 2009
    Minneapolis, MN
    I'd go talk to your preferred dealer and see if you can get some assistance from Audi to get it rectified. It's a major safety concern when it comes to mounting child seats, so maybe you can run it up to the right person. There's an official Audi presence here on Audizine too, maybe you can reach out to them and start a discussion.
  33. #1433
    Senior Member Three Rings Killerboots's Avatar
    Nov 19 2014
    Phoenixville, PA
    B8.5 allroad Info &amp; Resources Megathread
    Definitely not a sedan back. Those have a pass thru that allows skiís and such. Looks like the hooks were just removed by the previous owner. They are attached with torx screws I believe..
  34. #1434
    Jun 02 2004
    LA
    They're pretty cheap. Like $32 or so
    https://www.audiusaparts.com/auto-pa...omponents-scat
    09 A4 2.0t
    03 a4 3.0qms
    00 1.8TQ
  35. #1435
    Sep 23 2015
    Arlington, VA
    As always you guys are killer (see what I did there??)! Actually found those diagrams and parts but wasnít sure if something else was up but this makes some sense. Not sure why on earth they would be removed...but at least it seems I can safely retrofit.
  36. #1436
    Jul 18 2017
    Anaheim Hills, CA
    I apologize if this has been covered before, but did a search and couldnít find a specific answer.
    I have 19x8.5 et32 wheels and wanted to use 20/15mm spacers rear/front. I have found wheel bolts either 19mm longer or 22 mm longer for the rear. I was wondering if it was better to go 1mm shorter or 2mm longer than the spacer width. Everything I read says to go longer but I worry about it being too long and interfering with the brakes.
    I have gone through most of the build threads and I think these sized spacers with the et32 offset will get me almost flush. I am lowered on H&R springs, which really arenít that low, so I donít think I will have any rubbing issues. Any experts here want to chime in on their opinion with these final offsets? I definitely donít want any poke.
    Thanks,
    Jason
  37. #1437
    Jul 02 2016
    Florida
    Sorry my bad. You are correct.
  38. #1438
    Veteran Member Four Rings Gusman1's Avatar
    Jun 01 2014
    2015 Audi S4, 2014 Audi Allroad, 2011 Mustang GT Sold: 2004 VW Jetta GLI, 2015 VW GTI
    San Jose, CA
    Any feedback on anyone running APR stage 1 e85 tune? Might take advantage of the sale.
    2015 Audi S4: Ibis White, Black/Chestnut Brown, 305 Forged FT108 19x9.5 ET42 w/ PS4S, Bilstein PSS10, Dinan Exhaust
    IG: gusman_s4
  39. #1439
    Veteran Member Three Rings bluefox280's Avatar
    Jul 03 2005
    Broomfield, CO
    Quote Originally Posted by Gusman1 View Post
    Other than the power is excellent (for Stage 1 users) and results are very proven?
    I have thoroughly enjoyed my Allroad on APR's 91oct / E85 software.
    If it hasn't been suggested, do make sure you check / change your spark plugs for the increased fueling and boost.
    Here's a thread I've started regarding plugs:
    http://www.audizine.com/forum/showth...K-BKR8EIX-2668
    - Erik
    ē PatternDraftImaging.com - "...Where Engineering Discipline and Photography Merge as One..."
  40. #1440
    Established Member Two Rings blew-dub's Avatar
    May 18 2017
    FL
    revo has a 25% off sale as well.
    http://www.audizine.com/forum/showth...-Revo-Software!
