Page 36 of 43 FirstFirst ... 263435363738 ... LastLast
Results 1,401 to 1,440 of 1689
  1. #1401
    Sep 01 2017
    16' 8V S3
    Northern VA
    Quote Originally Posted by 949 View Post
    whats the full specs on the wheels and tires?
    rim specs?
    tires specs?
    michelin version?
    AG M590 19x9.5 +40
    Michelin Pilot Sport 4S 245/35/19
  2. #1402
    Sep 01 2017
    16' 8V S3
    Northern VA
    Quote Originally Posted by Wr3ks_S3 View Post
    Avant Garde M590
    19x9.5 et40
    245s
    Michelin Pilot P4S
    Compared to mine one post above
    BBS RS-GT
    19x9.5 et38
    245s
    Michelin Pilot Supersports
    Lol beat me to it. Thanks broothaaa
  3. #1403
    Feb 01 2017
    Massachusetts
    I'm lowered on 034 springs. Does anyone know if I can use PS4 245/35/19 tires on 19 8.5 et 45 without rubbing and no spacer?
  4. #1404
    Quote Originally Posted by AIK View Post
    Hoping so since going with those same size tires and same size wheels except for 42ET.
    2016 RS7
    2018 GLC C63s Coupe
  5. #1405
    Aug 19 2016
    Southern, NH
    Quote Originally Posted by brad65ford View Post
    FYI both mine and @VA_S3 setups are more aggressive with no spacers and or fender work.
    You should both be fine
    2016 S3 Sepang Blue I Black Optics I BBS RS-GT I ED emmotion lowering springs I ED carbon fiber trunk lip
  6. #1406
    Senior Member Four Rings HBird's Avatar
    Jul 18 2015
    DFW
    My car w/ B8 S4 Peelers (19x8.5 ET47 w/ 5mm/10mm spacers front/rear) on 034 springs. Tires are DWS06 245/35/19, but it should give you an idea. No rubbing at all
  7. #1407
    that drop looks perfect! How do you like the 034 springs assuming you are on mag ride?
    2016 RS7
    2018 GLC C63s Coupe
  8. #1408
    Jul 18 2015
    DFW
    I love them. I drive around with the suspension pretty much only in Dynamic. The ride is firm, but compliant. The highest praise I can say is that this is how the MagRide should've felt from the factory. 034 nailed it
  9. #1409
    Feb 01 2017
    Massachusetts
    Quote Originally Posted by HBird View Post
    It looks great. Did you try them without spacers on?
  10. #1410
    Sep 28 2010
    '18 S4, '16 SQ5
    Winston Salem NC
    I still wanna see the V-FF 103 19x9.5 ET37 on an A/S3 😋
    36094620066_1b413bedb9_o by Audiyos, on Flickr
  11. #1411
    Sep 01 2017
    16' 8V S3
    Northern VA
    So do I now...darn you.
  12. #1412
    Sep 28 2010
    '18 S4, '16 SQ5
    Winston Salem NC
    Quote Originally Posted by VA_S3 View Post
    I'll make a sweet deal 😁
  13. #1413
    Jul 18 2015
    DFW
    I did not. I worked with Mops to get as flush a fitment as I could.
  14. #1414
    Established Member Three Rings sean_entrust's Avatar
    Feb 11 2017
    Portland OR
    Damn this is perfect!
    2017 S3 P+ (Mine) Daytona Gray Pearl / Black Optic / Carbon Fiber Package / 034 springs / Stoptech BBK / 12.94 @105.3mph stock
    2012 Q5 P+ (Wife) Ibis White
  15. #1415
    Aug 19 2016
    Southern, NH
    As did I.
  16. #1416
    Veteran Member Three Rings MerlinS3's Avatar
    Aug 04 2010
    2016 S3 Audi Exclusive
    Houston TX
    That fitment though...
    2016 S3 Prem+ | Black Optics | S Sport Seats | LED Lighting | Tech Pack | B&O |Mag Ride | Audi Exclusive Color |
    H&R Super Sport Springs | Spulen Turbo Muffler Delete | CTS Turbo Intake | FortyFour Wheel Studs and Lugs | E.D. Carbon Trunk Fin | Carbon Fiber Mirror Caps | RS Quattro Grille | E.D. PURE Carbon Front Lip | Zito ZF01 Flow Forged | ORT Coilovers | Hyperco Springs | @MerlinS3
  17. #1417
    Nov 26 2017
    Ontario
    What's your wheel and tire spec's? Any rubbing issues? Great looking setup!!!
  18. #1418
    Aug 04 2010
    Houston TX
    Quote Originally Posted by Smittymedic17 View Post
    19x10 ET35 squared on 275/30's
    Rears rub over big bumps, fronts are good but I did some fender pulling and rolling to make them work
  19. #1419
    Nov 26 2017
    Ontario
    So I'm torn between wheel/tire sizing. I have been through this thread and trying to sum up or confirm my decisions. I've narrowed down the wheel to a TSW Bathurst 19" (gunmetal). Unsure of the width and offset. Options are 8.5W et43 and 9.5W et39. I would like to run Michelin Pilots 245/30/19 or 255/30/19. I don't want to run into rubbing issues or have a stretched look. I'm not lowered at the moment, but have my eye on either H&R sport springs (equivalent) or coilovers. I don't want to pull or roll fenders either. I want to get the most aggressive look with widest tires.
    Ideally i want to run the 19x9.5 et 39, 245/30/19 tire. Confident this will fit even if lowered w/o rubbing. Worried about the stretched look.
  20. #1420
    Nov 02 2017
    Irvine/CA
    I would go with the 8.5 if you are worried about that stretched look. I have 245/35 tires on an 8.5 wheels on my other car; and even with that slightly taller profile, it still looked a tiny bit stretched - at least to my eyes (I like my tires to be pretty much squared with the wheels). The shorter sidewall will make the stretch more pronounced.
    2018 Audi S3 Premium Plus
    Navarra Blue Metallic/Magma Red - Technology, Dynamic, S Sport, Black Optic, Resonator Delete
  21. #1421
    Mar 26 2007
    Colorado
    245/35 on my 8.5's was a good look.. My Golf R (also depends on the tire you chose)
    CURRENT:
    APR - B8 A4 Avant
    2008 - 4Runner
  22. #1422
    Nov 02 2017
    Irvine/CA
    Quote Originally Posted by vdubjetta02 View Post
    This is very true - it's very tire dependent. What tire did you have on your Golf R - that 245/35 pictured looked really meaty.
  23. #1423
    Senior Member Two Rings SickAWD's Avatar
    May 16 2012
    VW Tiguan
    Palm Desert, CA
    My A3 8V on stock sport suspension running HRE FF01 19x9.5 et45 on Nitto Motivo 255/35/R19 96Y XL tires. I have 10mm in the rear and 5mm in the front to clear the shocks. Looks amazing in my opinion but I just recently took them off because I didn't like the heavy feel when turning. Other than that it worked out great for the month I had them on.
    2017 Audi A3 S-Line 2.0T AWD
  24. #1424
    Senior Member Three Rings INYAUDI's Avatar
    Feb 21 2016
    Southern New Hampshire
    Aggressive Iíd say lol
    ZERO F‹CHS DRIVEN
  25. #1425
    Nov 17 2014
    San Francisco, CA
    Quote Originally Posted by VeeDubb View Post
    19x10 squared
    Did you remove the rear fender liner? I have 20x9 +38 with 245/35/20 with some slight rubbing in the back.
  26. #1426
    Aug 04 2010
    Houston TX
    Quote Originally Posted by mroberte View Post
    Nope,
    Liner is still in the front and rear, just trimmed edges to make more clearance
  27. #1427
    Nov 09 2017
    australia
    Do you know where you are rubbing in the back, as i have 20x9 245/30/20 and i get very slight rub every now and then and cannot tell where it is rubbing in the back
  28. #1428
    Mar 26 2007
    Colorado
    Quote Originally Posted by XMetal View Post
    Bridgestone Pole Position
    CURRENT:
    APR - B8 A4 Avant
    2008 - 4Runner
  29. #1429
    Established Member Two Rings ralphie_43's Avatar
    Aug 18 2017
    Fillmore, CA
    This thing is perfect!
  30. #1430
    Active Member Two Rings maskari_gti's Avatar
    May 27 2017
    Oman/UK
    I placed an order on Rotiforms LAS-R a month ago and just got my set as they were in back order.
    Unfortunately, there has been a mistake in colour. I ordered silver and got the Matt black finish.
    Could anyone here help out photoshopping both wheels onto the car? Iím also going to bag the car.
    Thanks in advance.
    First pic is not of my car.
  31. #1431
    Aug 18 2017
    Fillmore, CA
    finally lowered! On 245/40R18 square super tight fitment will take more pics tommrow
  32. #1432
    Aug 18 2017
    Fillmore, CA
    Wheels specs 18x9 et30
    Tire specs 245/40 R18
  33. #1433
    Aug 04 2010
    Houston TX
    Quote Originally Posted by ralphie_43 View Post
    Looks good
    What are you lowered on?
    Iím dropping down to 18ís on my S3 too
  34. #1434
    Aug 18 2017
    Fillmore, CA
    Looks good
    Lowered on Neuspeed sport springs 👍👍
  35. #1435
    Aug 04 2010
    Houston TX
    Looks good man
  36. #1436
    Oct 25 2015
    Illinois
    That looks awesome! What wheels?
  37. #1437
    Aug 18 2017
    Fillmore, CA
    Looks good man
    Thanks dude, love your car too
  38. #1438
    Aug 18 2017
    Fillmore, CA
    Quote Originally Posted by A4_kamil View Post
    Thanks! Alzor 020
  39. #1439
    Dec 02 2008
    FW Texas
    Bring this thing back from the ded
    Gorgeous. Does it rub at all in the back? Any fender modifications done?
    2018 RS3 - On Order
  40. #1440
    Sep 03 2014
    New York NY
    I havenít posted in a long time but hereís some pics of the different wheels I have used on my 2014 and 2017 A3
    VIP modular VX110 19x9 and 19x9.5
    Vossen LC 106T 20x8.5 et 45
    VossenxWork wheels collaboration 20x8.5 et 45 (added spacers)
    [IMG][/IMG]
    j
