Results 1 to 40 of 52
    Mar 09 2014
    Massachusetts
    Powering Radar Detector in 2015 S7 using a Mirrortap
    Using the wiring harness in your autodimming mirror is yet another way to power your radar detector. A-Pillar/Fuse panel route and Homelink are two other popular methods.
    I prefer using Mirrortap with a Blendmount for what I think is the cleanest install possible. It's also fairly easy and straightforward. No wires need to be spliced and no panels need to be removed (other than the tiny plastic covering pieces). The one short, thin Mirrortap cable is almost completely hidden behind the rear view mirror. While I used a Blendmount, it should work with other mounting solutions equally well. If you are going to hang it from your visor or windshield you will likely need a slightly longer cable length, which Mirrortap does have available.
    I used a Audi-004 Blendmount mount and 12 inch Mirrortap Microtap, which has slightly thinner (.05 vs .08 I think) pins which you will need to wedge into the Molex connector plug wiring harness. You need to find the 12v wire and ground wire in the harness. You will wedge the red mirrortap pin into the 12v and the black pin into the ground. I show it in the following photos from my own installation but if you are not sure use a multimeter.
    As I indicated, I used a microtap but Mirrortap recommends a regular size Mirrortap (.08 I think ) for Audi vehicles. My Infinity m35x was a real PITA to get the pins into so I wanted the smaller microptap pins for my S7. I would stick to the regular Mirrortap size as my microtap was initially a bit loose. But I was able to snugly fit it in without a problem by wedging the pins into a different corner of the respective ground and 12v connector stalls.
    See cautionary disclaimer at end of this post.
    Step 1:
    Remove plastic trim cover to expose wire harness. Slide it backward slightly so you can see the front lip detach from the middle piece of plastic trim. Then wiggle, pull, back and forth and it will eventually let go. The connector points don't appear designed to hold it too tight. At this point you can also wiggle off the smaller middle piece of plastic trim.
    Step 2:
    With ignition and power to the mirror off, detach lower wiring harness from mirror. Mine was snug and I had to use a bit of force but it came off without a problem. There is a tiny release pin which you push up on to allow the wiring harness to come free. I used the tip of one of my multimeter probes to push it in.
    Step 3: Locate the 12 v and Ground wires in the freed harness. Use a multimeter to confirm the 12v and ground if you are not certain.
    Step 4: Wedge the pins into the respective wire "stalls" of the aforementioned 12V and Ground wires. My wiring harness 12 V lead was the black and red wire and the ground was the brown wire next to it. I also had a second ground wire (per my multimeter testing)- the black wire third in line. So it went black/red (12v)-brown (ground)- black ( 2nd ground)- and purple wire, in that order. At this point I turned on the ignition and confirmed there was power by connecting my RD. See photo below.
    Step 5: Tuck the Mirrortap cable under the middle smaller plastic trim piece such that it comes out at 12 O'Clock where the stem of the mirror attachment exits the plastic trim. This serves to not only hide the cable behind the mirror but it also anchors the slack inside the wiring harness box and doesn't require any drilling of holes or alteration of the plastic trim pieces to allow the cable to exit the wiring harness cover.
    Step 6: Attach remaining larger plastic trim cover, attach your RD and plug it in, and use a plastic zip tie around the Blendmount to gather the slack in the Mirrortap cable and you are done.http://www.audizine.com/forum/images/smilies/smile.gif
    Caution: I am not an electrician or a car mechanic. I am not affiliated with Mirrortap or Blendmount in any way. This is simply how I installed my Mirrortap in my 2015 Audi S7. Please see the Mirrortap instructions that come with your Mirrortap and read them carefully before attempting installation and see the warnings and disclaimers on the Mirrortap brochure/directions. If you are unsure of the Ground and 12V plug indentity, use a multimeter. I make no representation that the wiring of your rearview mirror is the same as mine. The above installation outline is simply a demonstration of how I installed my own RD with a Mirrortap. If you are still uncertain about the installation in any way have a qualified installer do the installation for you.
    Senior Member Four Rings Silverarrow240's Avatar
    Jul 10 2014
    Great walk through!!!! Thanks so much!
    I will be attempting this soon, or else me thinks I'll go broke from future speeding tickets!!
    2012 Audi A7 3.0TFSI Prestige Ice Silver/Black/Aluminum (Sold and missed more)
    2000 TT Quattro | Silver | Grey Nappa (Sold and really missed)
    Veteran Member Four Rings CanuckRS's Avatar
    Dec 20 2006
    CAN
    i found the install using homelink has shorter cable showing and much less intrusive for location imo.
    2016 RS7 | Bathurst 21X10.5 ET32 Michelin PSS 295/25/21 | EBC RedStuff Front/Rear(DP31939C/DP32082C) |
    Mar 09 2014
    Massachusetts
    Nothing wrong with wiring through Homelink. I just didn't want to see the power cable exit the headliner in front of the mirror...too visible for me.
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    May 09 2014
    Poughkeepsie, NY
    And this is easily reversible (i.e. you can plug the Mirrortap in and out if you need to bring the car in for service)?
    Dec 20 2006
    CAN
    Quote Originally Posted by NPKR View Post
    cable exits from headliner above the mirror. have my detector and camera installed in that location above the mirror so they don't interfere with visibility.
    Mar 09 2014
    Massachusetts
    The benefit of the Mirrortap is that there is no visible cable- it's all hidden behind the mirror.
    Probably more important is the optimal position of the RD just below the rearview mirror for rearward radar detection of sources behind your car. With your detector mounted up high above the mirror or to the side of the mirror sensitivity to radar coming from behind is greatly reduced. This has been shown in testing and makes intuitive sense.
    But to each his own....both methods will work :)
    And yes it is reversible....although I don't think I would bother doing so before bringing in for service.
    Jun 30 2014
    Titusville, NJ
    Great job ... thanks for posting the pictures, and the step-by-step. Much cleaner than the a-pillar cable run. Will try Saturday or Sunday when I am home from vacation. Glad I didn't send back the Mirrortap.
    Thanks, too, for pointing me over here from AudiWorld!
    Mar 09 2014
    Massachusetts
    Quote Originally Posted by Silverarrow240 View Post
    Quote Originally Posted by bjterp00 View Post
    Your welcome. Hope it helps. If during your own installations you find a way to improve on the install please feel free to add to this post.
    Established Member Two Rings PB4UGO's Avatar
    Oct 12 2010
    '14 A6 TDI - Previous RS4, 4.2 allroad, A4, A5
    Earth
    Items for Sale
    Great post!!! Thank you!!!
    Veteran Member Three Rings soslower's Avatar
    Apr 23 2012
    Audi
    SO CAL
    Super clean install. I'm trying to tap into some wires for my headlights. Was thinking of going to the fuse box
    Jun 30 2014
    Titusville, NJ
    Just did mine tonight following NPKR's instructions ... worked perfectly! No comments to improve other than just noting that it is a little worrisome to tug so hard not the trim to pull it off, but no problems at all!
    May 09 2014
    Poughkeepsie, NY
    How thick is the cable? My A6 mirror housing is different but there is a 1/8" gap between the headliner and mirror cover where the wire might be able to squeak through.
    Mar 09 2014
    Massachusetts
    Not sure what the A7 mirror cover looks like but the installation will have a cleaner appearance if you have the cable exit on the windshield side of the mirror (behind the mirror) rather than btwn the cover and headliner which would leave cable visible in front of the mirror, at least in the S7.
    Mar 09 2014
    Massachusetts
    Quote Originally Posted by KmanA6 View Post
    Not sure what the A6 mirror cover looks like but the installation will have a cleaner appearance if you have the cable exit on the windshield side of the mirror (behind the mirror) rather than btwn the cover and headliner which would leave cable visible in front of the mirror, at least in the S7.
    Active Member Two Rings niklasios's Avatar
    Nov 19 2014
    Miami
    Great post. Just did it on my RS7, looks amazing.
    Senior Member Three Rings JoeCaMotto's Avatar
    May 06 2014
    Chitown
    Quote Originally Posted by PB4UGO View Post
    +1, Thanks
    14 White S7 Loaded
    14 HD white demin V-rod muscle
    10 White Ford Raptor 6.2 Loaded
    09 Red GT-R sold
    Jun 02 2012
    CO
    Great write up! Just installed mine over the weekend. FWIW, the wires in my 16 S6 were the exact same as yours.
    2016 S6, Daytona Gray Pearl, Prestige, Black Optics Package, Sport Package, Driver Assistance, Cold weather package, Black Headliner, Bose, Rubber mats, 20% tint, clear bra, Eurocode Sways, Links, Alu Kruez, Roc Euro Intake, VagCom, 034 Tranny Mount
    For the Wife: 2014 Moonlight Blue SQ5, Prestige, B&O, Tint, Clear Bra, Rubber Mats, 21" wheels (19" TI wheels for winter)
    Gone: 2012 Brilliant Black S4, Prestige
    Established Member Two Rings AnTarbh's Avatar
    Oct 17 2015
    2008 Q7
    MN
    Quote Originally Posted by AstleyJ View Post
    Can you show some pictures of your configuration? How big of an impact is it in your visibility?
    2016 S6 Goodwood Green Pearl
    2014 A6 3.0 TDI Prestige Phantom Black Pearl (SOLD)
    2008 Q7 3.6l Premium Lava Grey
    2006 A4 2.0T MT Brilliant Red (SOLD)
    Senior Member Three Rings ak_siberian's Avatar
    Jan 30 2015
    2015%20RS5
    20 miles NW Fairbanks, Alaska
    Which Blendmount model did you get as there seem to be several. TIA
    siberian
    The best long distance runners eat raw meat, run naked and sleep in the snow
    Senior Member Three Rings kouzman's Avatar
    Nov 03 2014
    15 Audi RS7, 14 Audi A4 2.0T
    new york
    Quote Originally Posted by ak_siberian View Post
    siberian
    +1 one on this! I just want to be certain before I order. thanks!
    2015 Porsche 911 Turbo S
    Jun 03 2014
    Phoenix, AZ
    This is my first post here, having just acquired a 2014 A7 Prestige. I can't live without my V1 and this will be my first mod. Thank you so much for posting this and including the pics
    Nov 10 2013
    1980 Porsche 911SC, 2014 VW golf TDI 4-door 6MT, 2014 911 50th Anniversary
    Greenwich, CT
    Doing this soon on to be delivered '16 S6 - thanks, great write-up.
    Established Member Two Rings Phoneboy's Avatar
    Nov 16 2013
    Long Island ny
    I have the blend mount and mirror tap for my 2013 a7 and love it. I had it in my s5 previously and had it moved. Would not use anything else.
    Jun 30 2012
    16 Lava Orange GT3 RS, 18 Nardo Grey RS3, 17 Panda Macan GTS, 91 C2 964, 16 F150 Lariat, 63 Impala
    Woodstock GA
    Quote Originally Posted by kouzman View Post
    I got this one for the RS7 and it's perfect. Love it.
    https://store.blendmount.com/blendmo...ies-p2021.aspx
    Active Member One Ring TallMartin's Avatar
    Dec 14 2015
    Los Gatos, California, USA
    GREAT POST! I've been looking for instructions on how to wire my Valentine V1 into my 2016 S6.
    Quick question: does your car have the auto stop / start (i.e. when the car is in Comfort mode, the engine will stop at stoplights, ect, and restart when you take your foot off the brake)? If so, does it maintain power to your detector when this happens? I'm currently using the cigarette lighter in the armrest, and the engine restart causes power to dip to the point that the detector restarts (resetting the bluetooth connection to my phone). Mildly annoying...
    2016 Audi S6
    Daytona Grey Pearl Effect
    Prestige Package
    Driver Assistance Plus Package
    S6 Sport Package
    Black Optic Package
    Black, Valcona Leather Seating Surfaces
    Carbon Atlas Inlays
    Mar 09 2014
    Massachusetts
    Quote Originally Posted by TallMartin View Post
    My S7 doesn't have auto stop/start so i can't say anything myself about your problem. However, I have seen other posts which directly address your problem on Audiworld. Valentine ( i think its Valentine) sells a tiny unit for $25 that you plug in-line with your radar detector cat-5 plug and it alleviates the restart with engine shutting down.
    Nov 10 2013
    Greenwich, CT
    Thanks very helpful. I just did the install on my 2016 S6, all relatively similar. If anyone has specific questions
    about the S6, pm me.
    Mar 14 2016
    Cleveland, OH
    Thanks for the write up. I just did this on my 16 S6 prestige as well as my wife's 16 A6 Premium plus. The wiring was same on both Black/red was + and brown next to it was Gnd -. Thanks again was super easy to hook up the Escort 9500ix.
    One step I skipped was disconnecting the connector. I just placed the mirror tap pins and zip tied to the harness wires. Just verified with multimeter first.
    Also if you something powered constantly it's the yellow/red wire it's the + and the brown next to it as the Gnd - on the secondary harness.
    Mar 27 2016
    St. Louis
    Nice work OP. Did you install the Escort mute button in the car somewhere?
    Established Member Two Rings 13_C7_SC's Avatar
    May 01 2016
    2011 Range Rover Sport
    Glenside, PA
    So I did this install using the mirror tap and blend mount, and it works great. Yesterday I installed LED reverse lights, and now my radar doesn't get powered on anymore by my mirrortap.
    Has anyone had this issue happen to them?
    Sent from my Nexus 6 using Tapatalk
    Veteran Member Four Rings ericw.'s Avatar
    Apr 23 2011
    SF Bay Area
    Items for Sale
    I followed OP's post, required a little effort to make sure my mirror tap made consistent connection with the wiring but this was a very helpful resource to eliminate the question of where to tap into power. Thanks NPKR for sharing!
    IG @lolzhax // agilitydrives.us
    C7 S7 4.0tt | LX7U | STG1 ECU+TCU | RFX7 | EVO2 | EUROCODE SWAYS | CETE ASC | RS7 FR+R | Indicator Delete | Hardwired | Straight Piped
    b7 a4 2.0t | Stage 2+ | Recaro | Klutch KM20 | Pirelli P1 | 034 TP | Custom AWE | IE HPFP | JHM FMIC | ECS Slotted Rotors | Hawk Pads | Podi | 034 RSB + End links | DTM | Relak CF | OSRAM Headlights | Custom Steering Wheel | Android Multimedia | JL Audio| CF Wrapped Trim | Tinted | [sold]
    Feb 16 2014
    Il
    Installed my V1 using the Blendmount and Mirror Tap. Very clean and "professional" looking. My only complaint is that it does block vision a bit, especially when the MMI screen is up, which is all the time for me. Other than that, it's a great set up.
    '14 Audi S7 Prestige, Ibis White on black, Black Optics, Drivers Assistance, Cold Weather pack, LED Headlights, Sports Diff. Anthracite HRE FF01's with PS4S's.
    '13 Audi S5 6MT Premium Plus, Phantom black on black, Drive Select, Adaptive Suspension, Sports Diff., B&O, BBS CXR/PSS (gone)
    '09 Audi A5 6MT, 3.2 Prestige, Drive Select, B&O, S-Line wheels, PSS (gone)
    Apr 23 2011
    SF Bay Area
    Items for Sale
    Quote Originally Posted by BCT View Post
    That's why i didn't go with the blend mount. I'm going to stick with suction cup mounts on this car.
    Sent from my SM-N920P using Tapatalk
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Items for Sale
    just installed my escort max 2... put it above the mirror and to the left. I have a big box above my mirror, and the max 2 sits nicely there and the view to the back is fine... just a little irritated that the radar sits so far forward. Thinking of going with regular 2 suction cup attachment to gain the space back so I can move my visor forward more.
    Edit: I also ran the hardwire cable through the pillars and found a switched 12v line. cake
    Oct 31 2014
    Northeast
    Really nice job on this. Just installed a 360 Max in my 2016 RS7 following your instructions and the install went perfectly! Didn't even have to pull out my multimeter. 45 min from start to finish. Thanks!!
    Active Member Three Rings
    Jan 02 2018
    El Paso, TX
    Couldn't find this thread while searching, but a very nice forum member linked it for me (thanks buddy). Wanted to bring it up for 2 reasons. First, the correct mount now is AUD-009 for the S6, which has the weird stem. Second, can't remove the (wide) upper plastic part, and don't want to break anything. Where are the clips up there? It has to be pulled down, but wish people took a picture of the part instead of trying to explain how to remove it. Most of us seeing where the tabs are would make it obvious how to remove it. If unsuccessful, will just pull down the console. Should be easy after removing 1 T-25 Torx screw inside the sunglass holder. Thanks.
    2018 S6 mythos black/black; S sport package, driver assistance package, 20" black optic package, carbon atlas, Audi rings, all-weather mats, 35/20% tint
    Active Member Two Rings Blackbeard's Avatar
    Dec 25 2017
    02 BB S4 trailer, 00 CG A4 vr6, 06 Ford Superduty
    Rosamond, CA
    Would this by chance work for the b5 a4/s4?
    Be Honest, Be Humble, Be Happy
    Apr 23 2011
    SF Bay Area
    Items for Sale
    Quote Originally Posted by Blackbeard View Post
    The concept might be the same if it has a powered mirror, you can use a multimeter to confirm or find your + and - but otherwise the similarities between a B5 and C7 pretty much end at the audi emblems on front and back.
    Jan 02 2018
    El Paso, TX
    Two more things folks. First, the mirror housing with the driver package is very different than without it, due to the lane-departure camera. Upper plastic part is wider than the sunglass compartment. On cars without it (like ericw's), the stem seems very narrow. That's why I can't put the detector there. And that's also why people should specify which mirror they have. And second, in my car, there's absolutely no space to push anything backward or forward, to 'wiggle' the plastic anywhere. The only way to remove anything is starting with the wide piece on top, and the only place it has to go is down from the very top (where it touches the headliner)... but mine doesn't want to budge when squeezed and pulled down. It was already creaking, so need to know where the freaking tabs are, before I break something. If somebody has an S6 with the driver package, it'd be nice to hear specific instructions on which of the 3 plastic parts to pull, and exactly how. And yes, from now on, somebody please take a picture of the stupid piece upside down (showing all tabs) and that would provide all the explanation us DIY-type need. Otherwise, I'll go with the roof console when the mount arrives later this week. With the roof console out, it should be easy to pop that wide piece out. In fact, looks like the OP had the roof console removed on his first pic, so that might be necessary to remove before that wide piece anyway. I'll find out soon enough. He he. Thanks gang.
