Page 2 of 2 FirstFirst 12
Results 41 to 52 of 52
  1. #41
    Veteran Member Four Rings kiku's Avatar
    Jul 11 2013
    2001 Audi S4
    Damascus, MD
    Items for Sale
    Correct
    2008 997.1 GT3
    2015 Allroad
    2014 Ram 3500 Dually (the double wide)
    2014 Phantom Black RS7 w/ APR Stage 1 Tune (sold - farewall fast rs)
    2001 B5 S4 (the track slut)
    2013 Q7 S-Line (sold)
  2. #42
    Senior Member Three Rings AudIan's Avatar
    Mar 01 2014
    NC USA
    Items for Sale
    mmmmmanother dream mod I can't afford. This stuff really is car porn.
    2014 Black S6 LEDs black wood and aluminum inlay, black optics
  3. #43
    Jun 05 2010
    Slovakia, Europe
    I have done it on my A8, RS6 420mm ceramic brakes easy plug and play but then you have to do a coding as in rainy weather it does not brake :(
    I can get complete new set RS6 ceramic brakes for a very good price.
    Audi RS6 C7 700hp+, 900Nm+, Akrapovic, sports cats (upgraded turbos soon)
    Audi A8 4H 4,2 TDi 460hp, 1200+Nm on sale
    Ex Audi A4 B8 3.0 Tdi quattro, S line, AMA exhaust, No DPF, big turbo, big intercooler, remap software 320Hp 710Nm ( soon aprox 340Hp 750Nm ) v max 285Km/h
  4. #44
    Jul 11 2013
    2001 Audi S4
    Damascus, MD
    Items for Sale
    Just be careful, c6 rs6 brakes do not fit c7s.
    2008 997.1 GT3
    2015 Allroad
  5. #45
    Jan 01 2012
    Seoul, Korea
    Steel brakes lighter than CCB?
    This is some interesting stats...
    My understanding was that Carbon Ceramic discs are lighter than still discs...
    It's not the case here?
    Quote Originally Posted by LittleDevil View Post
    Weight saving. Weight difference between S7 and RS7 ceramic is because RS7 have aluminium hats.
    RS7 Steel Brakes 390/356mm:
    Front Calipers with Pads and Wear Sensors = 8.05kg each
    Rear Calipers with Pads and Wear Sensors = 5.60kg each
    Front Disc 390x36mm = 13.80kg each
    Rear Disc 356x22mm = 7.25kh each
    RS7 Ceramic Brakes 420/370mm:
    Front Calipers with Pads and Wear Sensors = 9.75kg each
    Rear Calipers with Pads and Wear Sensors = 6.50kg each
    Front Disc 420x40mm = 8.25kg each
    Rear Disc 370x30mm = 4.55kg each
    S6, S7, S8 Ceramic Brakes 400/370mm:
    Front Disc 400x38mm = 8.45kg each
    Rear Disc 370x30mm = 6.75kg each
    Kind Regards
  6. #46
    Established Member Three Rings fatherdeath's Avatar
    Jul 20 2016
    2016 Honda CRV EXL, 2006 Dodge 2500 laramie mega cab, 1974 Buick apollo
    Vilseck, DE
    what about drilled and slotted steel rotors? as a compromise for sake of cost
  7. #47
    May 17 2016
    Seal Beach, CA
    Quote Originally Posted by riki18 View Post
    Do you happen to know the coding info? I upgraded to the RS6 brakes on my S6 and wet weather braking is for sure sketchy vs stock brakes. THX
  8. #48
    Jan 23 2017
    Romania/Bucharest
    Fitting steel breaks to ceramic version
    Hello and sorry to revive this thread, i am looking to buy a used S6 and found one with Ceramic brakes which is not bad in itself, however i'm not looking forward to replacing them when the time comes :)
    Did anyone successfully replace Ceramics with Steel brakes? Any conclusions if this is possible by just simply fitting the standard brakes to the Ceramic calipers?
    Thanks for any info on this!
  9. #49
    Veteran Member Four Rings Dasquade's Avatar
    Sep 07 2010
    Belgium
    From what i have been told, if you drive the car normally (so no hard pushing track 'abuse')..they should last a lifetime and if they don't get damaged (as they are fragile) it is only pads you have to worry about :).
    (one of the reasons why i also looked for a S6 with ceramics :) and found).
    Current S6 C7 avant 2013: estoril | ceramics | JD engineering stage 2 | LightVan no backseats | Milltek non-res valved | 034 trans-diff mount |CETE ASCv2 & EVC | FL dynamic tails | Thermo ZO coated catless DP | Custom HX cooler (JD) | RS6 c6 matt gunmetal 20" wheels | custom tailgate spoiler & diffuser | Armor heatshielded mani-turbo-dp
    In development: R8GT steeringwheel | FIS controler (mmi gauges)
  10. #50
    Jan 23 2017
    Romania/Bucharest
    Quote Originally Posted by Dasquade View Post
    Thanks for the info, feels reassuring to hear that! I heard rumors, that but was a little skeptic.
    Still it would be nice to know that, IF the time comes, we can switch to steel. :)
    In theory, per the size, this should not be a problem. But maybe coding is needed as mentioned above?
    Cheers!
  11. #51
    Senior Member Two Rings widebodyfx's Avatar
    Jan 31 2009
    Referenced this thread a bunch so want to add to it.
    Coding - I've seen on VCDS and other Audi forums a good number of people trying to hunt down the coding. Still not really a figured out thing because the long coding just has no descriptors. Little Devil and other audizine members have had some luck but nothing concrete.
    Found this on another forum and this i believe applies to all new Audi cars and wet weather. These cars are well engineered and logical, if auto wipers are on and the rain sense is activated by the car it can and does quite a few things from what I've noticed. There is coding to have your windows close when rain is sensed to give you an idea how they tie things together.
    Rain sense - I've noticed my head lights come on even though the MMI screen does not go into night mode from being in auto mode.
    Rain sense - I believe all newer cars will active brake wipe as stated below. I always noticed how grundgy my wheels were when driving in the rain even though the car was cleaned up prior to it raining so the below explains some of that.
    From A8 D4 (including Q7 V12)
    -Brake disc wipe function is activated if the rain sensor is switched to active (i.e. the intermittent wipe lever must be actuated)
    -Brake disc wipe function is deactivated if the interval between wiper activations is longer than 30 seconds, even if the intermittent or rain sensor is active.
    -Speed at which it is switched on and off (vehicle speed) is the same at 80 km/h
    -The wiping interval for GG brakes is every 3 km, and every 1 km for ceramic brakes (i.e. not distance and time-dependent)
    The disc wiper is for steel or ceramics to dry the surface so rain fade is less apparent. This is from a CCB car and OBDEleven.
    I wet with the 400/370 kit to keep wheel selection a little more open.
    Interesting caliper profile, left is towards the face of the wheel.
    Test fitting, while the front calipers look massive they aren't too different visually beside the ends hugging the disc.
    Caliper clearance to wheels is not very different either, the ceramics are wider but the front set up needs a different dust/splash shield because the disc is inset a bit more even though both steel and ceramic are 400mm.
    Same impact spot at the point closest to the hub. I would imagine that the 420mm kit would actually clear this impact point because the calipers are the same as the 400 kit but the bracket to the spindle is different so the radius of the closest physical point is pushed outward.
    Rear, no need to change the dust/splash shield. We had to use a different brake line though.
    Some photos collected. Notice the reflective surface, the discs are fairly raw when new so bed in rotors have a different appearance.
    Difference between 400 and 420. Caliper position away from the hub is easy to see here and the raw surface of new discs.
    original and a bit of reflective surface after some bed in of the brakes.
    Graphics, dimensions are below.
    Front is basically 4 wide
    Rear is basically 3 wide
    Painted mine Brembo Yellow.
    Ceramic rear plate vs. RS plate difference.
    Install
    Still hunting for the correct coding, haven't looked at the ABS module since getting the car back so we'll see how it goes.
    ///TWCompetition 2016 S6
  12. #52
    Jan 31 2009
    Quote Originally Posted by fatherdeath View Post
    Since you're over in Europe. Saw this on another thread. http://www.ultimot.de/ looks like some decent looking drilled rotor option for front and rear for the C7.
