Results 1 to 3 of 3
    Active Member One Ring kadowaki0420's Avatar
    May 30 2012
    chicago/IL/
    2004 audi a4 1.8t heating issue
    I have had this heating issue for a while. I am blowing cold air when the car is already at normal temp but while I was driving on the highway, it blew hot air. I did my research and thought it could be a heater core that was clogged. So I unclogged it and bleed it. I then drove it around to make sure all air was out of the system... After that I realized that both the inlet and outlet hose going to the heater core has no fluid at all. Now, even though I'm driving on the High way, I do not get hot air. The heater core is BONE DRY!!! I had also already replaced the coolant flange because it was leaking really bad. WTF is the problem. HELP!!! SOS!!!
    Jun 22 2012
    09 Honda Civic Si
    Dallas, tx
    Quote Originally Posted by kadowaki0420 View Post
    If your gauge is working properly try this. http://www.pelicanparts.com/techarti...Core_Flush.htm If it isnt replace the 2 pin and 4 pin coolant sensors.
    Bleeding the system is to get the potential air out. When was the last time you flushed the system? ( I did mine last year and I couldn't believe hoe much crap came out of the black itself. I cannot find the DIY or write up at this time online. GOOGLE IT. get a good one with pics and descriptions. )
    You dont want to bleed the system by taking the coolant line off the firewall. There is a BLACK rail to the left of you silver fuel line if its a 1.8 that has a ALAN wrench head on it. You let the car warm up about a quarter on the gauge and open it just a little bit and wait until water type substance comes out. Make sure the heater is on the low setting.
    IF you haven't flushed the system since youve owned the car. I would suggest doing it ASAP to be sure you know its done.
    Get the core flushed. Its easy, I did it today and took about a hour of drinking a few beers and reading instructions.
    Aug 05 2010
    A mess
    South Bend, IN
    I just finished going through the same thing. Three years now and my Audi has never had good heat. Plenty of heat at 2500+ Rpm sure, but almost none at idle. Over the time I've owned it my cooling system has gotten a new t-stat/housing, j-plug, combi-vale, water pump, and I have flushed the heater core and block just this year. I just could never get the air out of the system properly I guess. That, and there just isn't much flow in this system at idle. My solution: I ended up installing an auxiliary water pump from a 2.7t car on the heater core supply line. I also added a couple large resistors that come with LEDs to the wiring to quiet it down a bit. My car puts out so much heat at idle now that I'm worried about breaking the glass!
    2004 A4 Dolphin Grey Ultrasport 1.8t 6spd -
    Stg1 tune, S4 brakes, RS4 sway, JHM shifter
