Page 281 of 281 FirstFirst ... 181231271279280281
Results 11,201 to 11,240 of 11240
  1. #11201
    Nov 13 2015
    Ottawa
    Quote Originally Posted by kabukie View Post
    You're replacing the rotor? Skip the mallet and use a real hammer or sledge.
    Thanks, will go to the store and buy a real hammer. Unfortunately, i live in an apartment and barely have any tools.
    I believe i can remove the top carrier bolt (don't remember). Think i have enough room to use a screw and two nuts to sort of push the rotor away? Something like what is explained in this video
  2. #11202
    Feb 10 2012
    parts
    ONTARIO, CANADA
    Fatkids try some sort of degreaser around the hub and on the back of rotor. It's likely just bing held in by some debris or a bit of rust (thank you Canadian weather). When I did mine the drivers rear was on there similar to what your saying. Real hammers are great but use some sort of padding piece of 2x4 or anything that will handle the blow. Metal to metal on some components I just think is not the best, though usually the best solution, but A bad swing can or will cause damage.
    When you put it all back together there should be antisieze between the rotor and the hub assembly, my drivers rear was dry passengers was coated in antisieze. Make sure you coat things a bit. All the bolts too and torque to spec so later on you'll have less issues. Hope you get it sorted.
    4 turbos (soon 5), 2 motors, 1 B7 A4
  3. #11203
    Nov 13 2015
    Ottawa
    Quote Originally Posted by canadianA4B7 View Post
    Thanks for the tips! I plan on getting some PB Blaster from CT tomorrow and soaking it before giving it another go with the mallet. I am afraid that i will damage the rotor with the metal hammer and it will still be stuck . I put anti seize when i did the fronts as well as lubricated the guide bolts. Next brake job should it a lot smoother :)
  4. #11204
    Active Member Three Rings
    May 20 2017
    New Hampshire
    Use a real hammer. A nice ball peen will remove it.
    You aren't going to break a rust seal with a dead blow my friend.
  5. #11205
    Jun 17 2013
    jersey city nj
    Using a BFH to it free
    APR KO4, APR HPFP,RS4 LPFP Cntr,145 bar PRV, APR TP, TT DP, GFB DV+, AWE FMIC, BFI CC, AWE Exhaust, RS4 Exh tips, ST CO, 034 RSB,034 St Dnsty Mtr Mts, New Sth West Bst guage, B7 RS4 8 pot Calipers.Stop Tech slotted rotors.Goodridge SS brake lines frt & rr. Hawk HPS frt & rr. RS4 PS rack, RS4 Servotronic Relay,RS4 rims. S4 mirror caps,RS4 Mesh Style Grill,LED tail lites
  6. #11206
    Mar 24 2013
    '01 Chevy 2500HD Duramax
    Griswold, CT
    I use a nice 3lb sledge.
    -Adam
    '07 DTM A4 2.0T|6MT|EFR 7163 Twin Scroll|DoTuning|Built Motor|Meth and other go fast stuffÖ
    '06 A4 2.0T Quattro - RIP (Best ľ mile pass 13.634 @ 103.30)
  7. #11207
    Veteran Member Four Rings WillŽnskraft's Avatar
    Oct 14 2011
    2002 Audi A4 1.8TQ, 2007 Audi A4 2.0TQ
    Norcross, GA
    Nein it's all about the Mjolnir
    "Beep beeeep bloop boop" - R2D2
  8. #11208
    Established Member Four Rings Okedokey's Avatar
    Oct 24 2015
    Perth, WA
    Can someone with a sedan and a OEM roof antennae please measure the distance from the back of the antennae to the end of the roof? Any references to actual hole measurements and location would be awesome!
    A4 B7 2.0L TSFI (Mauritius Blue) | KO4 + Autotech HPFP upgrade + BSR Stage II tune - 2.5" BSR CAT-back - CAI| S3 Inj. DW300c LPFP | GFB DV+ | 19" Audi 2015 RS4 rims | R8 Coils | 034 RSB, control arms, end links, street density engine & CVT mounts - snub nose - HFC | Cupra R lip | 7" Erisin 2028AM - Polk Audio PA D5000.5 - 4 x DB6502 + db840DVC sub + Pioneer 10" sub| Yellow Fogs, LEDs throughout | CXRacing FMIC - B12 Bilstein Suspension + H&R Springs | S4 brake upgrade and braided lines.
  9. #11209
    Jun 07 2017
    2010 Camaro SS/RS 6M/T Maggie
    PA
    No. it just unclips
    Thank you!
    2008 A4 Avant SE Ibis White
  10. #11210
    Established Member Three Rings wjg22's Avatar
    Apr 14 2016
    '01 Monster 750
    Pittsburgh
    I get 7 & 5/8" from back of antenna housing to where the roof starts to curve. I don't really have time to pop it off for distance to hole though, so hopefully someone has a diagram
  11. #11211
    Oct 24 2015
    Perth, WA
    Quote Originally Posted by wjg22 View Post
    Champion, thank you!
  12. #11212
    Nov 13 2015
    Ottawa
    Thanks for the help everyone. I got some PB Blaster and a sledge hammer, sprayed some PB Blaster and after a few good smacks with the sledge hammer, the rotors came off. The old and new rotor slide right in without a need to take off the caliper carrier bracket.
  13. #11213
    Feb 10 2012
    parts
    ONTARIO, CANADA
    ^^^^^ this is just asesome!!! Good work mate figures it was just a little contamination there holding shit right!
    Now onto a dumb question!! any one got a solution for the shakey rear view mirror?? An no I'm not giving up my solid mounts! I think it's essentially useless at this point. Same with my side mirrors, I may as well be tripping on acid looking into them as everything now is extremely fuzzy while I'm driving!
  14. #11214
    Senior Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    Use your mirrors less. They get you into trouble. Hold your line and make them work to pass you. Because Race Car.
    B7 Avant, 6MT, Quattro - Brilliant Black
    JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Carbinio CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+.
  15. #11215
    Apr 14 2016
    '01 Monster 750
    Pittsburgh
    Quote Originally Posted by fatkids View Post
    the old and new rotor slide right in without a need to take off the caliper carrier bracket.
    Idk how you pulled that off, I was trying that myself when I did rotors a few weeks ago. I had to stand and bounce on the end of a breaker bar with a long metal pipe over the end of it to bust those caliper carrier bolts loose.
  16. #11216
    Senior Member Two Rings Jimmyjamms's Avatar
    Sep 20 2014
    Hilux
    Sydney
    Drop a couple tabs before you drive and maybe it'll appear clear...
  17. #11217
    May 20 2017
    New Hampshire
    Were your rotors OEM or aftermarket? There could be a variation in the thickness of the ones you installed that made them unable to be removed without loosening the carriers.
  18. #11218
    Apr 14 2016
    '01 Monster 750
    Pittsburgh
    ECS Geomet. Pretty sure they're like 1mm thicker than OEM, which was enough lol
  19. #11219
    Veteran Member Four Rings Axis's Avatar
    Nov 15 2011
    A4 B6 Avant | A4 B7 Sedan
    Montreal | I sell in USD
    Questions you thought were too dumb to ask
    Remove rear dome light, there's a hole in the headliner cardboard, find the middle and punch.
    Go outside and punch your mark towards the inside. Drill, then step drill untill the sharkfin fits.
    Did it a couple years ago.
    I also put touch up paint on the exposed metal.
    *****I sell in USD*****
    Click here to read my seller feedback
    B6 Avant GT2871R Motoza Tuned Aka the part hauler
    B7 Sedan Stage II HPFP Aka the retrofitted queen
  20. #11220
    Oct 24 2015
    Perth, WA
    Lovely, thanks for that, appreciate it. Im spraying my car, so now's the time to do it. Thanks again!
  21. #11221
    Nov 13 2015
    Ottawa
    I read on a few threads that some couldn't take the rotor off / put the new rotor in with the carrier bracket in place, so i was a bit nervous when i got to that point. But it came out smoothly, i just had to orient the rotor a tiny bit, but it took less than 10 seconds to take it out / put the new one in. The new rotor thickness is 0.470 in. (Power Stop EBR1006XPR) and a Centric rear rotor is 0.4685039 in. (11.90mm), so i am assuming they are stock thickness. If the rotor was thicker, i would have had issues as there wasn't a lot of room to allow a thicker rotor to slide in.
  22. #11222
    Jun 10 2017
    Honda Pilot, VW Golf, KTM Duke 690
    Chicagoland
    Newbie here. Looking to replace the existing radio/nav head unit in my new to me A4 Cabriolet SLine preferably plug and play. Did a search but info is dated. Not interested in back up camera, just radio, nav, iPhone iTunes sinc/Bluetooth, yada yadda
  23. #11223
    Nov 15 2011
    No worries, enjoy drilling your roof haha
  24. #11224
    May 09 2012
    what size spacers should I get? My wheels are 18x8.5 with a 225/40/18 tire. Not super low my FTG is about 24.5-25". It looks like I have a ton of room I'm thinking 20 rear and 15 front? think I can go more on the front and not rub?
    2007 A4 2.0T Quattro Tip
    - Autospeed Tune - ST Coilovers - VMR V710
  25. #11225
    Sep 20 2014
    Hilux
    Sydney
    Quote Originally Posted by blue28 View Post
    Depends on your wheel offset. Put a straight edge against your wheel and measure distance from wheel edge to fender at top
  26. #11226
    Aug 22 2017
    Poland
    Quote Originally Posted by Jimmyjamms View Post
    This may be useful
  27. #11227
    Oct 24 2015
    Perth, WA
    But my car doesn't have read seats
  28. #11228
    Apr 30 2017
    1976 Ford (Mercury) Capri II, 1990 Vw Vanagon & a 1998 Toyo 4runner
    Amherst NH USA
    OK so dumb question . My engine is dead, long live the engine. Have managed to get one from a local wrecking yard and they are putting a warranty on it, parts and labor so that's good. The engine has had some work done to it, there is a poly bush, it has the red r8 coils, a single stage clutch, and some shiny bits. The engine comes complete with the wiring and ecu. Not sure if the ecu was chipped. So to my question is can I use this ecu or does that raise a bunch of other questions/issues?
    Sent from my SAMSUNG-SGH-I467 using Audizine mobile app
  29. #11229
    Established Member Three Rings Luccatavares's Avatar
    Aug 15 2016
    Florida
    http://www.audizine.com/forum/showth...and-P0507-CELs
    Typing that code in on my google took me to the last time I searched it. Thread above shows a number of audi possible solutions. I think I swapped my fuel filter. And later had the repeat code which I think is when I changed out the fuel system sensor on HPFP
    Funny thing is that I need to replace the oring on the oil dipstick. That would be amazing. Haha
    Everytime I go low in gas to the red mark the p2393 comes up. Hope I haven't pushed my lpfp to hard and have to replace. P0171 is new since I replaced the fuel pressure sensor because the code p0087. And all that after a install a custom tune.
  30. #11230
    Veteran Member Four Rings vvenom800tt's Avatar
    Dec 04 2011
    Kansas City, KS
    7
    Sent from my SM-G920V using Audizine mobile app
    2005.5 Audi A4 Quattro 2.0T 6MT - APR - 034 - Custom 3" single exhaust - 17z Brembo - GFB - Alzor - Kumho - ST - Injen - Swift - Hyperco - ECS - Saikou Michi - PowerFlex - Podi
  31. #11231
    May 09 2012
    dunno how I forgot that. They are +45. I've measured for spacers on other cars and still screwed it up so figured someone is running similar wheels to mine that can hopefully chime in. 18x8.5 ET45 or 35 seem to be pretty common
  32. #11232
    Aug 19 2013
    Audi A4 B7
    Orlando, FLORIDA
    Ok so i'm at loss here today i removed my passenger axle to do my inner boot. Everything went well until it was time to put my axle back on. The end of the axle won't seem to go inside the spline. I turned it with the car in neutral to see if it would go in but i won't. It got dark and i was tired so is there any way to put the axle in the whole? Do i have to remove my upper control arms and tie rod to get it in? I did it without removing them so i ask if there is a way to do this?
    Sent from my SM-G925T using Audizine mobile app
    Ivan
  33. #11233
    Oct 14 2011
    Norcross, GA
    Quote Originally Posted by dalmation53 View Post
    Have someone turn the wheel all the way to the left. Insert axle. Tap it in with a hammer if needed.
  34. #11234
    Aug 19 2013
    Audi A4 B7
    Orlando, FLORIDA
    Quote Originally Posted by WillŽnskraft View Post
    Have someone turn the wheel all the way to the left. Insert axle. If needed, then tap it in with a hammer.
    Tap it where though? Any specific location?
    Ivan
  35. #11235
    Oct 14 2011
    Norcross, GA
    The end of the axle (CV joint area) into the hub.
    Also, use some lubricant to help slide the spindle back in.
  36. #11236
    Aug 19 2013
    Audi A4 B7
    Orlando, FLORIDA
    Ohh ok i see i will try it tomorrow thanks.
    Ivan
  37. #11237
    May 09 2012
    Virginia
    If you are sure it's seated in the splines but you just can't get it to come through you can thread the axle bolt in and pull from that (gently with a pry bar if needed).
  38. #11238
    Feb 10 2012
    parts
    ONTARIO, CANADA
    Quote Originally Posted by nij_tp View Post
    Requires IMMO delete. Most guys are charging $100 to do this using BDM type software. I've got this stuff all built hooked up ready to use. I've scanned a few ECUS already but have not done any coding yet. BDM System cost me $70 usd. And a bit of time. For me where I am in the game it's worth it's weight in gold.
  39. #11239
    Aug 19 2013
    Audi A4 B7
    Orlando, FLORIDA
    That's my problem the splinenwon't even go in i tried to clean the area of dirt and grime too i guess i'm gonna have to remove my upper control armsnto see what the fuck is going on. I'm having trouble putting things in holes
    Ivan
  40. #11240
    May 20 2017
    New Hampshire
    Don't remove an upper control arm. Pop the lower rear ball joint out of the upright and you'll have plenty of play to get an axel in.
