Page 281 of 281 FirstFirst ... 181231271279280281
Results 11,201 to 11,211 of 11211
  1. #11201
    Nov 13 2015
    Ottawa
    Quote Originally Posted by kabukie View Post
    You're replacing the rotor? Skip the mallet and use a real hammer or sledge.
    Thanks, will go to the store and buy a real hammer. Unfortunately, i live in an apartment and barely have any tools.
    I believe i can remove the top carrier bolt (don't remember). Think i have enough room to use a screw and two nuts to sort of push the rotor away? Something like what is explained in this video
  2. #11202
    Feb 10 2012
    parts
    ONTARIO, CANADA
    Fatkids try some sort of degreaser around the hub and on the back of rotor. It's likely just bing held in by some debris or a bit of rust (thank you Canadian weather). When I did mine the drivers rear was on there similar to what your saying. Real hammers are great but use some sort of padding piece of 2x4 or anything that will handle the blow. Metal to metal on some components I just think is not the best, though usually the best solution, but A bad swing can or will cause damage.
    When you put it all back together there should be antisieze between the rotor and the hub assembly, my drivers rear was dry passengers was coated in antisieze. Make sure you coat things a bit. All the bolts too and torque to spec so later on you'll have less issues. Hope you get it sorted.
    4 turbos (soon 5), 2 motors, 1 B7 A4
  3. #11203
    Nov 13 2015
    Ottawa
    Quote Originally Posted by canadianA4B7 View Post
    Thanks for the tips! I plan on getting some PB Blaster from CT tomorrow and soaking it before giving it another go with the mallet. I am afraid that i will damage the rotor with the metal hammer and it will still be stuck . I put anti seize when i did the fronts as well as lubricated the guide bolts. Next brake job should it a lot smoother :)
  4. #11204
    Active Member Three Rings
    May 20 2017
    New Hampshire
    Use a real hammer. A nice ball peen will remove it.
    You aren't going to break a rust seal with a dead blow my friend.
  5. #11205
    Jun 17 2013
    jersey city nj
    Using a BFH to it free
    APR KO4, APR HPFP,RS4 LPFP Cntr,145 bar PRV, APR TP, TT DP, GFB DV+, AWE FMIC, BFI CC, AWE Exhaust, RS4 Exh tips, ST CO, 034 RSB,034 St Dnsty Mtr Mts, New Sth West Bst guage, B7 RS4 8 pot Calipers.Stop Tech slotted rotors.Goodridge SS brake lines frt & rr. Hawk HPS frt & rr. RS4 PS rack, RS4 Servotronic Relay,RS4 rims. S4 mirror caps,RS4 Mesh Style Grill,LED tail lites
  6. #11206
    Mar 24 2013
    '01 Chevy 2500HD Duramax
    Griswold, CT
    I use a nice 3lb sledge.
    -Adam
    '07 DTM A4 2.0T|6MT|EFR 7163 Twin Scroll|DoTuning|Built Motor|Meth and other go fast stuffÖ
    '06 A4 2.0T Quattro - RIP (Best ľ mile pass 13.634 @ 103.30)
  7. #11207
    Veteran Member Four Rings WillŽnskraft's Avatar
    Oct 14 2011
    2002 Audi A4 1.8TQ, 2007 Audi A4 2.0TQ
    Norcross, GA
    Nein it's all about the Mjolnir
    "Beep beeeep bloop boop" - R2D2
  8. #11208
    Established Member Four Rings Okedokey's Avatar
    Oct 24 2015
    Perth, WA
    Can someone with a sedan and a OEM roof antennae please measure the distance from the back of the antennae to the end of the roof? Any references to actual hole measurements and location would be awesome!
    A4 B7 2.0L TSFI (Mauritius Blue) | KO4 + Autotech HPFP upgrade + BSR Stage II tune - 2.5" BSR CAT-back - CAI| S3 Inj. DW300c LPFP | GFB DV+ | 19" Audi 2015 RS4 rims | R8 Coils | 034 RSB, control arms, end links, street density engine & CVT mounts - snub nose - HFC | Cupra R lip | 7" Erisin 2028AM - Polk Audio PA D5000.5 - 4 x DB6502 + db840DVC sub + Pioneer 10" sub| Yellow Fogs, LEDs throughout | CXRacing FMIC - B12 Bilstein Suspension + H&R Springs | S4 brake upgrade and braided lines.
  9. #11209
    Jun 07 2017
    2010 Camaro SS/RS 6M/T Maggie
    PA
    No. it just unclips
    Thank you!
    2008 A4 Avant SE Ibis White
  10. #11210
    Established Member Three Rings wjg22's Avatar
    Apr 14 2016
    '01 Monster 750
    Pittsburgh
    I get 7 & 5/8" from back of antenna housing to where the roof starts to curve. I don't really have time to pop it off for distance to hole though, so hopefully someone has a diagram
  11. #11211
    Oct 24 2015
    Perth, WA
    Quote Originally Posted by wjg22 View Post
    Champion, thank you!
