Page 252 of 328 FirstFirst ... 152202242250251252253254262302 ... LastLast
Results 10,041 to 10,080 of 13084
  1. #10041
    Senior Member Four Rings Okedokey's Avatar
    Oct 24 2015
    Perth, WA
    Quote Originally Posted by vvenom800tt View Post
    i found the actual part numbers for the rivets Audi use. Already ordered them, but thanks for the tip
    share the size then bro :)
    My respray thread
  2. #10042
    Oct 24 2015
    Perth, WA
    Quote Originally Posted by Dubbed-Out View Post
    Thanks for the response guys. I kinda knew the answer to my question already. I was just stuck in denial, being that I just replaced the belt, tensioner, rollers & water pump less than 20k miles ago. But the belt is not looking too good, so I'm going to replace with a Continental brand. I really didn't want to buy a new tensioner though.
    http://www.blauparts.com/products2.asp?cat=4468
    Big savings here right now due to overstock
    My respray thread
  3. #10043
    Aug 19 2013
    Audi A4 B7
    Orlando, FLORIDA
    I'm wondering if this method for the power steering groaning noise will work for the 2.0T
    http://www.audizine.com/forum/showth...ring-Noise-Fix
    Sent from my C5306 using Tapatalk
    Ivan
  4. #10044
    Veteran Member Four Rings QuattriumMT6's Avatar
    Aug 24 2013
    1991 Toyota Mr2 Turbo
    Stockton, CA
    Looking to paint my car white using autodip cans. Wondering how man cans would be needed to cover the entire car minus the roof and sideview mirrors. I've already used this stuff on my RS6 grille and the finish is amazing. It has no tacky feeling/texture to it, washes bug residue off easily and has a natural gloss/shine to it.
  5. #10045
    Established Member Four Rings pezgoon's Avatar
    Jul 25 2016
    new hampshire
    Questions you thought were too dumb to ask
    Quote Originally Posted by QuattriumMT6 View Post
    ALOT
    Buy extra and return un needed?
    Hey just so you know it says right in the FAQ's not to do what your planning on doing
    Eric
    2005.5 6mt A4 2.0(red T ) Silver metallic outside, Platinum inside.
  6. #10046
    Jul 25 2016
    new hampshire
    It says this
    Then this
    Eric
  7. #10047
    Aug 24 2013
    Stockton, CA
    Lol but CA always gets screwed when it comes to certified dealers/installers. DYC from what I can remember does not even ship their DIY car paint kits to CA residents. It sucks when a good product comes along and we're so limited. :/ If I could purchase by the gallon I would be able to use a decent paint gun similar to DYC's applicator which should give me better coverage.
  8. #10048
    Veteran Member Three Rings a4audi4fun's Avatar
    Sep 28 2007
    MY08 B7 2.0T Avant 6MTQS S-Line, 05 B6 3.0 6MTQS
    Vancouver, BC
    Quote Originally Posted by dalmation53 View Post
    Should work as long as you can find the clamp that is leaking - this DIY stops the bleeding of fluid and the ingress of air bubbles due to a loose clamp. On the 3.0, it just happens to be in a very accessible location for the clamp.
  9. #10049
    Aug 19 2013
    Audi A4 B7
    Orlando, FLORIDA
    Quote Originally Posted by a4audi4fun View Post
    Ohhhh i see what it does. You actually just explained it better haha yeah i will look for it because i know 100% my rack is not leaking or bad. And the pump well idk it did start making the noise because it was low on fluid. I might have air in the system right?
    Ivan
  10. #10050
    Jan 25 2017
    Los Angeles California
    08' A4 Sedan titanium. My Bumper is damaged and hangs a bit off. Its not falling off and you can barely notice but to my eye its off.
    Ive noticed a bit of crashed B7's from Rs4's to avantas to regular A4/S4. Im just wondering which bumpers might fit my car? does it have the be the exact make/year/model or is there some swing room between other models. I want to start looking for a part out but i need to know itll fit. Thanks!
  11. #10051
    Aug 19 2013
    Audi A4 B7
    Orlando, FLORIDA
    Quote Originally Posted by Bubbalex View Post
    Any bumper as long as is not from an RS4. Could do A4/S4 even avant. AND DTM
    Ivan
  12. #10052
    Jul 25 2016
    new hampshire
    Right
    You should do the bleed procedure immediately as these systems don't "really" self bleed, they can easily get air trapped and the whole system is very sensitive and in a very short time you could kill the system
    Eric
  13. #10053
    Jul 25 2016
    new hampshire
    How's it damaged? It may just be disconnected and you need to properly reattach it
    Or the mounts are broken, which would mean you need the mounts as well
    Are you sure it's the bumper that's damaged and not the mounts?
    Eric
  14. #10054
    Senior Member Three Rings supple's Avatar
    Jan 27 2016
    I don't have a garage
    Woburn, MA
    With a titanium edition, you're going to want matching black trim on that grill 🏁
    Sent from my Nexus 6P using Tapatalk
    2007 Brilliant Black A4 Quattro | Unitronic Stage 1+ | Bilstein Sport + H&R Sport | Apikol Snub | GFB DV+ | 034 Turbo Inlet, Street Density Motor Mounts, RSB & End Links, Upper/Lower Control Arms | Pipercross Filter
  15. #10055
    Senior Member Two Rings Yogie's Avatar
    Jul 30 2013
    05' WK Jeep 5.7l Hemi
    So Cal
    Hey everybody, looking for advice.
    Currently looking at 2 sets of S4 Recaros, one for 1100 and one for 1200. They are black and from a b7. Is this a decent price for the fronts and backs? I've seen some pretty low sale prices on these before, just wanna make sure before I commute up there to grab them. Thanks in advance guys!
    '2008 Brilliant Black A4 Avant S-line/Ti 6Speed Quattro'
  16. #10056
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    Any S-Line edition or standard '08 will fit. What's the damage and from where?
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
  17. #10057
    Jan 25 2017
    Thats what i was hoping for, Thanks! I just have to make sure its an 08', correct? older models wont fit?
    Quote Originally Posted by pezgoon View Post
    The bumper was parked over the curb and when pulling out it got hooked and broke the mounts. This was over a year ago and it was fixed by adding new mounts/screws but its still a tad off. Ive seen a couple of wrecked B7's on craiglist and i plan to keep an eye open just incase in run into a bumper in good shape. I just have to make sure itll fit. I wasnt sure the Avant/S4 models would fit it properly. Or if a earlier year model would work.
    Quote Originally Posted by 80sGuy View Post
    Just slightly off after breaking off the mounts. See top. Its not going anywhere, just want to keep an eye out for part outs and wrecked models on craigslist.
  18. #10058
    Aug 18 2009
    A Unicorn
    Portland, OR
    Any 05.5-08 S4 or S-line bumper will be a direct replacement for yours.
  19. #10059
    Veteran Member Four Rings Axis's Avatar
    Nov 15 2011
    A4 B6 Avant | A4 B7 Sedan
    Montreal | I sell in USD
    Need an Sline bumper, make sure you get one with or without headlight washers depending on if you have them or not. S4 bumpers will be the same but they all have the headlight washers.
    *****I sell in USD*****
    Click here to read my seller feedback
    B6 Avant GTX2863R Motoza Tuned Aka the part hauler
    B7 Sedan Stage II HPFP Aka the retrofitted queen
  20. #10060
    Oct 24 2015
    Perth, WA
    Quote Originally Posted by Axis View Post
    Im assuming you can add the blanks correct? Or is it something more fundamental?
    My respray thread
  21. #10061
    Jul 25 2016
    new hampshire
    Blanks?
    My car without them does not have blanks, it simply doesn't have the cutouts for them, I don't believe you can blank them out unless you butchered the cover off them then glued those into place that would be blanks
    Eric
  22. #10062
    Senior Member Four Rings Ashtonts's Avatar
    Jan 17 2015
    I think he means that you can just put the covers over the washer holes even if the car is not equipped with them. Which I will confirm is possible as my car has a bumper with the cutouts glued in place, but no washers.
    Now if your car does have washers and you try to install a bumper without the cutouts, then you'll probably run into issues unless you delete them.
    2005.5 A4 2.0T Brilliant Red | 6MT | Quattro | OEM DTM
    Go: K04 | Carbonio | Maestro | S3 Injectors | IE Rods | JHM FMIC | Autotech HPFP | ECS SS | JHM Clutch | USP HFC | Quad-tip Exhaust | S4 Brakes
    Show: Airlift Performance V2 | 18 Rial Daytona 2pc Wheels | Panda Recaros | RS Grille | OEM CF Trim | S4 Mirrors | Black Ext. Trim | Bixenons | LED Tails | A8 Rings | RNSe | 20% Tint | BFI Shift Knob | Shaved Reflectors | ECS Duckbill | Ziza LEDs
  23. #10063
    Aug 24 2013
    Stockton, CA
    Are the rear valences interchangeable between B7 A4/S4sedan/avants and B7 A4/S4 cabs? I really like the look of the following valence but unsure if it will be impossible to fit on my sedan.
  24. #10064
    Jun 17 2013
    jersey city nj
    Anyone know what led bulb #'s are needed for the rear dome lite on the roof above the cargo area
    APR KO4, APR HPFP,RS4 LPFP Cntr,145 bar PRV, APR TP, TT DP, GFB DV+, AWE FMIC, BFI CC, AWE Exhaust, RS4 Exh tips, ST CO, 034 RSB,034 St Dnsty Mtr Mts, New Sth West Bst guage, B7 RS4 8 pot Calipers.Stop Tech slotted rotors.Goodridge SS brake lines frt & rr. Hawk HPS frt & rr. RS4 PS rack, RS4 Servotronic Relay,RS4 rims. S4 mirror caps,RS4 Mesh Style Grill,LED tail lites
  25. #10065
    Jul 25 2016
    new hampshire
    No
    But you can go to sylvanias website, hey have a bulb checker and it tells you what bulb size every bulb in your car is, if at first the list doesn't list the bulb you need check to make sure there isn't more than one model. Sometimes the list is set up weird but i find 100% of my bulbs there lol
    Eric
  26. #10066
    Jul 25 2016
    new hampshire
    Idk but I hope someone answers this! That looks sick
    Eric
  27. #10067
    Aug 24 2013
    Stockton, CA
    Right? It's almost RS4ish!
  28. #10068
    Aug 24 2013
    Stockton, CA
    Sadly I found this from browsing the interwebs.... but for some reason I beg to differ. The rear valence looks too similar in shape and size :/
  29. #10069
    Jul 25 2016
    new hampshire
    yep
    I think we need some dimensions
    Where do the cabrios hide around here lol
    Also there's this now http://www.audizine.com/forum/showth...d-all-Cabrio-s!
    I may have had alittle bit too much fun writing the post though.... ah well
    Could be a little drunk after last night stilll
    Also from my searching that's not a stock rear valence
    Eric
  30. #10070
    Nov 15 2011
    If he doesnt have jets on his he can use one with them, he just wont have anywhere to connect them.
    If he has them and the bumper doesnt, he just has to plug the pump hole and disconnect the power to it.
    I actually like the jets, especially during winter when you get to a point where dirt water reduces the light output.
  31. #10071
    Apr 04 2017
    Chelmsford
    Why does my climate control have a mind of its own? I'll turn the heat on and set the blower to exactly where I want it and then 10 minutes later I realize I'm sweating and I look down and the blower is several settings higher than where I set it. This has been an ongoing thing since I bought the car a month ago and it seriously aggravates me. Can anyone explain how to stop this from happening?
  32. #10072
    Apr 17 2017
    Philadelphia, PA
    Went in yesterday to get a new replacement key bought from the dealer programmed for my 2005.5 A4
    The car was serviced there for the entirety of its life
    After 45 minutes the guy goes "I'm sorry, but the key works everything except for turning the car on"
    I reply, yea the immobilizer that's why I'm here, because you're the only ones who can do it
    I have to now go back Friday to have a master mechanic take a look into it.
    Is it wrong for me to request a better explanation and an honest reason for why I should trust them to do any service or repairs in the future, when they can't even program a key?
    Or is this a reasonable response from the Audi service center?
  33. #10073
    Oct 09 2007
    Miele S7
    Quote Originally Posted by mfink94 View Post
    I think it's miscommunication. When you visited the dealer and bought the key fob did you meant you bought it from the parts department, then hop on over to service? If not, while you're having the car serviced surely it must of been mentioned about the key problem along during the writeup. So how could he missed that?
  34. #10074
    Oct 09 2007
    Miele S7
    Quote Originally Posted by silver07b7 View Post
    Do you happen to have it on Auto or Econ mode?
  35. #10075
    Senior Member Three Rings klrider44's Avatar
    Aug 20 2014
    Doylestown PA
    I swear mine does the same thing, the temp stays put but the fan speed seems to do its own thing even when it's not on auto
  36. #10076
    Apr 04 2017
    Chelmsford
    No, it's definitely not on Auto or Econ mode. When I first started driving the car it was on Auto, so I turned it off (thinking this would fix the problem) but the problem persists.
  37. #10077
    Senior Member Three Rings wjg22's Avatar
    Apr 14 2016
    '01 Monster 750
    Pittsburgh
    My fuel level gauge has been pretty wonky for the past few weeks. I ran through the cluster test in vag com and all of the gauges swept from min to max and then to calibration positions, which indicated to me that the cluster was fine. So I replaced the in-tank fuel pump, and nothing changed. I tried to recalibrate to full with VagCom but for some reason when I adjust the level upwards from 128, the needle doesn't move at all.
    Does anyone have any thoughts on this?
  38. #10078
    Apr 17 2017
    Philadelphia, PA
    No you're correct. I bought it at parts and they drove the key over to the service department to program it to no avail.
    I was only at the dealer to have the spare key programmed not ready for a required service yet thankfully.
  39. #10079
    Senior Member Three Rings tloft4's Avatar
    May 15 2016
    Lock Haven, PA
    Quote Originally Posted by wjg22 View Post
    probably not the same but one of my fuel level sensors is broken and the needle wont go past 45% or so, range comp also never calculates for a full tank, but it also leaves the gas pump icon on top of the display showing error (im guessing)
  40. #10080
    Apr 14 2016
    '01 Monster 750
    Pittsburgh
    Yeah I get the persistent gas pump icon with annoying beep too. I've heard that you might have to recalibrate the new level sensor when it's installed, but I can't seem to change the needle position with VagCom, despite the gauges testing procedure showing that it appears to be fully functional
