Results 1 to 40 of 44
    Senior Member Three Rings mattg1.8's Avatar
    Sep 16 2009
    San Diego
    Items for Sale
    What kind of HID headlights are you guys running?
    I posted in the tech forums yesterday but have yet to get a response so ill post in here. My DDM HID headlights have been giving me problems setting off my ABS, traction control, and e-brake light every time i turn the lights on. Ive read that its because of the poor quality ballasts DDM uses. Im going to return these lights but i was curious which HID system you guys are running that cooperates with our ABS module. Any advice is appreciated. Thanks.
    Veteran Member Three Rings Luis_Heineken's Avatar
    May 28 2012
    Bayamon, Puerto Rico (USA)
    Cheapest on Ebay (smallest ballast possible) for a B7. So far so good
    Senior Member Two Rings theboss's Avatar
    Oct 19 2011
    NJ & San Mateo
    You could try to relocate the ballast on the driver side or add in a ground... I rarely had that problem but it worked itself out by restarting the car.
    Feb 17 2004
    Round Rock, TX
    Items for Sale
    Quote Originally Posted by mattg1.8 View Post
    just move the driver side ground wire direct to the chassis and you'll be fine, see this link
    2007 RS4 Sprint/Ebony, Ti, 110k
    JHM/BC Racing/Milltek/oCarbon
    Veteran Member Three Rings JB5's Avatar
    Jul 19 2010
    96 B5 A4- Sold, 06 corollaS (wife's), 97 Ford Ranger, B6 A4 (Daily Driver)
    Snellville, GA
    Items for Sale
    I purchased a morimoto 5five 5000k on Tuesday from the retrofit source but one of the ballasts is bad. To my luck, they happen to be closed tomorrow, Friday, and Saturday. Kinda sucks when I could just drive by their office for the exchange, hopefully there's no ifs or buts for replacing the dead ballast.
    Active Member Two Rings langer's Avatar
    Apr 19 2013
    I run OEM HIDs with real Phillips 4500s
    Veteran Member Four Rings gmudan's Avatar
    May 03 2009
    A6, Q5, A4 b8
    Windsor, ON
    Items for Sale
    Morimotos 35w 6000k. They fit snugly under the headlights. Didn't even need to drill a hole from the back if the headlight cap, ran the wires through the bottom. Sealed them up with a plexiglass card and silicone. The left side ballast occasionally made my dash light up like a Christmas tree so all I did was ground it separately to the chassis and now I'm golden. Running fine for 4+ months.
    Sent from my iPhone using Tapatalk - now Free
    Aug 19 2013
    minnesota
    I'm using Morimoto XB35 with cheap ebay ballasts and I'm lovin it... I have the same Christmas tree situation on occasion when I turn them on, all the lights come on. So you have to take the ground from the Ballast thats causing it and put it to the chassis instead? For me it's the drivers side as well. Also in the past the fog lights were rewired and I have a warning every time I turn the car on that the front right fog light is out but it's not. Is there a fix for that?
    Senior Member Two Rings B6_Dolphin's Avatar
    Apr 10 2005
    2015 Allroad Premium Plus - Brilliant Black/Titanium
    Everett, WA
    Items for Sale
    OEM HIDs.
    2015 Allroad Premium Plus - Tech & Sport Packages, B&O, Spoiler, 20" S7 Black Optic Wheels
    2017 Infiniti Q60S Coupe Red Sport - 3.0 V6 TT 400-hp
    Established Member Two Rings Autobahn5's Avatar
    Jan 19 2012
    Mariaville NY
    Got mine on Amazon. Kensun 6k. Twice in a year one headlight didn't light but a cycle of the switch fixed it. I fit the whole thing inside then headlight. Payed less then 50 I think and I am happy with them. Next time I would get a lower color temp maybe 5k. I would buy them again.
    No lights on dash ever except when one for the headlights didn't light.
    2005 A4 Avant Q 1.8t 6sp H&R and Bilstiens.
    Don' t you wish black stayed clean longer?
    Veteran Member Four Rings Peacob's Avatar
    Jul 08 2009
    Bicycles
    Detroit MI
    Items for Sale
    OEM with 5k CBI bulbs
    -Brian
    B6 A4 OEM+
    DD: e90 325i
    Oct 19 2011
    NJ & San Mateo
    Quote Originally Posted by Peacob View Post
    i want those in a euro spec s4 housing!!!!
    Franken Turbo / Motoza / Test Pipe / EV550 / TR18T / 034 Street Motor Mounts / Apikol Snub / APR Diverter / 2.0TFSI Coils / Gates TB / JHM Trio Shifter / JHM B7 RS4 Clutch+LWFW / Neuspeed Exhaust / KW V1's / HSport S4 Sways / 18x8.5 Miro 111's / Conti DWS 225/40/18 / 10mm Rear Spacers / B6 S4 Brakes / S4 Bixenon Ecode / S4 Upper Grill / Neuspeed SS Brake Lines / 5% tint / Boser CF Hood / AVH-X5500BHS / Audisen Bit Ten D / Speakers on Speakers / Podi Gauges
    Aug 26 2005
    I am running '05 OE Valeo DOT Titanium housings with B5 S4 e-code clear lens D2S projectors, with Osram 5000K CBI HID lamps.
    Vorsprung durch Technik
    Veteran Member Four Rings Timtheguru's Avatar
    Dec 30 2009
    Morimoto bi-xenon H1 Mini with 35watt morimoto ballast, great light output and even greater high beams.
    2001.5 S4 Sedan
    2002 A4 Avant 1.8t - Traded in
    2001.5 A4 1.8t - In storage rotting away providing homes for rodents
    2013 Q7 TDI
    Veteran Member Four Rings Pothole's Avatar
    Jun 02 2008
    Snohomish, Washington
    US Bi-Xenons with Osram 5k's..... I gave up playing with kits
    Please Drive Right
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    OEM B6 S4 Bi-Xenon ecodes with 5k Osram bulbs. Also did the lens upgrade.
    USP CLUB MEMBER #34
    2004 A4 1.8T USP - GT2871R Eliminator - Motoza program - ER Comp FMIC - Stoptech BBK & lines - JDM SS - CIM gauge - ECS RA4 Stage 2 clutch & LWFW - Fluidampr pulley - RNS-E - RS4 pedals, e-brake, & mirrors - S4 Bi-Xenon ecodes - 19" OZ SLIII - Bilstein PSS9 - B6 S4 Recaros - more stuff...
    Jun 27 2011
    Items for Sale
    Lulz.
    I got dem eagle eye halo LED b8 replicas yo! Ebay Racing FTW!!!
    #YOLO
    OEM ftw. Morimoto bulbs FTW. Clear lenses coming to a silver USP near me this weekend.
    -CP
    2008 Brilliant Black Unicorn (2.0t S-Line Ti 6MT Avant) - Bosch FR6KPP332S plugs - Q5 Rear Aero Wiper
    2012 Q5 2.0t - Stock Mommy Missile
    Former USP CLUB MEMBER #136
    Jul 19 2010
    Snellville, GA
    Items for Sale
    has anyone checked The Retrofit Source and HID Planet websites? i think their down. I remember last night reading that TRS was going to be closed today, friday and saturday and wont be processing any orders but didn't know this would affect both of their websites
    May 03 2009
    A6, Q5, A4 b8
    Windsor, ON
    Items for Sale
    Quote Originally Posted by JB5 View Post
    Posted on there facebook wall
    "Just another reminder: We will be closed tomorrow (10/17) and Friday (10/18). Please email us at answers@theretrofitsource.com if you have any questions over our time off and we'll answer it in the order they are received starting on Monday. Thanks guys!"
    Jul 19 2010
    Snellville, GA
    Items for Sale
    Quote Originally Posted by gmudan View Post
    Nice,
    Thanks.
    Jun 27 2011
    Items for Sale
    Uhh, websites don't "Close for business"
    They might not be processing orders, but nobody takes their website down for a holiday....
    -CP
    Dec 30 2009
    theretrofitsource website is up for me...
    2001.5 S4 Sedan
    2013 Q7 TDI
    Jul 19 2010
    Snellville, GA
    Items for Sale
    I'm not that dumb i know that, but I've been having issues getting to their website and was pretty much asking if anyone else had this issue. i've tried logging in from work and from home so i figured their server was down and couldn't get in touch with anyone there. but as of 30 minutes to an hour ago i can now access their site. Anyway, lets not get sidetracked since OP wanted to know who runs what HID Kit.
    Jun 27 2011
    Items for Sale
    ^^ Oh my bad. I realise it sounded stupid, I probably should have realised that.
    In any event, TRS Morimoto Three5 bulbs are excellent. Have a set in my b7 and the output is worlds better than the 5 y/o bulbs that were in the car. Probably not as good as the Osram CBI bulbs but for less than 50% the cost I'm ok with that...
    -CP
    Established Member Two Rings ultrasport69022's Avatar
    Aug 01 2008
    So Cal
    Thumbs up
    xantec slim ballasts from ebay, bought them over 3 years ago and never have had any issues ever! and they were only 30$
    Registered User Four Rings OEMplus.com's Avatar
    Feb 27 2004
    2x VW, 2x Audi
    OC, CA
    OEM ftw!
    Joe@OEMplus
    Jul 08 2009
    Bicycles
    Detroit MI
    Items for Sale
    Quote Originally Posted by theboss View Post
    Like so. Euro spec bixenon, oem ballast, 5k cbi bulbs, with relay mod
    -Brian
    B6 A4 OEM+
    DD: e90 325i
    Jun 29 2012
    ATL, GA
    if you want good quatily ballasts buy morimoto ballets at theretrofitsource.com, or pm me and i can get you hooked up since i work there
    Oct 19 2011
    NJ & San Mateo
    let me pick up my jaw!!! dude i want those... i might just buy the US spec and change the fresnal lense
    Dec 19 2007
    York, PA
    Im running OEM Valeo ballasts, DDM 5000k D1S bulbs, Ecode housings and TRS TSX-R projector lenses.
    they still need to be aimed properly.
    EDIT: I've been running a 35watt ddm kit in my wifes car for at least 2 years now without any problems...including a front pass collision back in May of this year...everything survived.
    Those DEPO lamp projectors still ghost a bit above cut-off..but not bad for a pair of $190 headlamps. Those are 6000K bulbs too...the camera didnt pick up the blue light these put off that great. I want to switch them to the same as mine, 5k.
    Sep 16 2009
    San Diego
    Items for Sale
    So i finally got around to adding a ground wire from the harness to the power steering reservoir and i even relocated the ballast to underneath the headlight. Im still having the problem with getting a christmas tree every time i turn the lights on. any other suggestions im about to throw these things in the garbage.
    Feb 12 2008
    Michigan
    Items for Sale
    I've been running the morimoto mini h1 bi-xenon since may and the last couple months my passenger said a bulb is randomly not turning on and i am getting the dipped headlight error message. If I turn them off and on a few times it will fire up.
    Is this a wiring issue or a failing bulb or ballast?
    Feb 23 2004
    Stow, OH
    Quote Originally Posted by Fast4esT View Post
    It's likely the ballast is going bad.
    USP CLUB MEMBER #34
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    Dolphin Grey Audi A4 3.0 Q 6MT
    Dirty Jerz
    Items for Sale
    Single Xenon E-codes, Valeo ballasts, and Osram CBIs
    Retrieve your SKC for use with VCDS
    Setup Ross-Tech VCP Drivers
    3.0 JHM Tuned, JHM LWFW & Clutch, JHM Solid Short Shifter, Zingo Airbox Mod, quattro, Vogtland Jr. Suspension, Single Xenon E-Codes, Apikol Snub, 034 Motor & Trans Mounts
    Jun 27 2011
    Items for Sale
    Quote Originally Posted by CyberPMG View Post
    This.
    My b7 has a very random and intermittent dipped bulb warning. The bulb failed and I replaced it (got super red/pink for two days then blew out) but the error still occurs. Leveling works 100% so it's definitely the ballast unfortunately.
    -CP
    Senior Member Three Rings chadski's Avatar
    Apr 23 2013
    Harley Davidson Sportster
    South OC, CA.
    8000k HID 35W Conversion on Low and Fog. Just Bought Blacked Out Euro E-codes and only running 8k up top at the minute. Because of the new "T10 mini city light", I might bring it all back to stock or at least 5000k due to the different colors I now have.
    This is what I ran before, I know people say it kills people on the road, but with this cheaper 35W kit in So-Cal, you actually see it, sometimes worse, all the time...
    02' B6 A4 1.8T Dolphin Grey 5pd
    APR Stage2+|KO3s|TT225's|710N DV|Remus Dual w/Res Delete|034 3" TP-Cust.2.5" DP|Cust. AEM Intake|Stern Snub|B7S4 BBK Drilled&Slotted Fronts|StopTech SS Lines|BB FMIC|S4 Anti-RattleClips|NGK Iridium Spark
    S4 Rear Bumper|USP Front Lower|OEM RS4 Inserts|USP Door Blades|Cupra R|Eibach Susp.|RS4 19" VMR|OEM USP CF Spoiler|Boost Gauge|LED Interior Kit|HID Conv.8000k Lows/Fogs|Blacked-Out Euro E-Codes
    Jul 08 2009
    Bicycles
    Detroit MI
    Items for Sale
    Please dont go over 6k kelvin temp.
    -Brian
    B6 A4 OEM+
    DD: e90 325i
    Jun 27 2011
    Items for Sale
    Yuuuuup....
    At least with 8000K bulbs, the light is dim enough you won't really be blinding people...
    -CP
    Jun 08 2008
    Calgary AB Canada
    Items for Sale
    OEM Bixenon E-codes with OEM valeo ballasts and 5k bulbs
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
    Senior Member Three Rings screwball's Avatar
    Jun 29 2009
    B6 A4 - Mk4 GTI
    Northeast
    Morimoto Mini H1 setup in place of the stock projectors. With bixenon highs + halogen highs aliens can see you from space it's so bright.
    B6 A4 1.8t & Mk4 GTI 1.8t - PAG Parts 50 trim - AEB - RMR/70mm
