Results 1 to 15 of 15
    Oct 04 2013
    203 Connecticut
    Steering Feels Weird when Wheels are cut ALL the way.
    When my wheels are cut all the way left or right as if I'm driving around in a tight circle with my car the traction feels weird and it feels like the steering is making a slight noise. Maybe it's a quattro thing because it reminds me of the same feeling I got when I used to put my old Jeep cherokee in All wheel drive and tried to make tight circles or cut a super sharp corner. I relax a on the angle of the wheel a little it feels fine again, it's only when the steering wheel is all the way left or right while I'm moving. Normal?
    Veteran Member Four Rings superswiss's Avatar
    Jan 07 2013
    San Francisco Bay Area, CA
    This is normal on the B6/7. The tires are actually grinding. My understanding is that it has to do with the front differential. This is one thing I love about the B8.5. No more of this stuff. Smooth as butter when making tight turns.
    '13 panther blk RS5, Ti pkg, blk leather/alcantara, nav pkg, sport exhaust, driver assist pkg, rear shade, alu kreuz, ECS spacers 15f/10r, ECS tru-float rotors, ECS brake lines, Hawk HPS pads, european delivery
    '07 phantom blk S4, blk leather, 6mt, conv pkg, audio pkg, heated front&rear seats, bluetooth, nav plus, parktronic, DTM pkg, carbon trim, TPMS, rear&side shades (sold)
    Oct 04 2013
    203 Connecticut
    Quote Originally Posted by superswiss View Post
    I wonder if I'm doing any damage if I ever have to make a quick fast turn like this?
    Jan 07 2013
    Don't worry. I sold my S4 with almost 80k miles and no issues there at all.
    Senior Member Three Rings KAL's Avatar
    Jun 05 2012
    Audi A6 S-line
    Ottawa Ont. Canada
    Thats your quattro. My a6 does it. So do about of other quattros
    C6 A6 4.2 S-Line
    Dipped: Front Grill and rear defuser
    Veteran Member Four Rings FastEddie's Avatar
    Apr 01 2012
    Queens
    Items for Sale
    Its quattro, your doing nothing wrong. i thought the same thing when i first got the car. If you read the manual it actually tells you not to hold it there for more than 15-20 seconds. Dont know why but dont worry about it.
    Veteran Member Three Rings blackedoutt's Avatar
    Sep 16 2007
    B7 S4, MK1 TT, Tacoma
    Southern Indiana
    Mine slightly judders at continuous hard full lock. I also have some power steering pump noise. I keep jacking it up and cycling lock to lock with the cap off and letting the bubbles disperse (overnight) but still everytime I bleed it, there's more bubbles! Filled for 10mm above max line when warm as well, just flushed with new fluid, febi mineral.
    YEAH BUDDY!
    Senior Member Three Rings MidwestB6's Avatar
    Aug 01 2013
    1970 Ford Maverick
    Iowa City
    I've always heard turning at full lock is hard on the steering system, especially in 4wd vehicles. So I try to avoid turning like that, but it shouldn't be too much of an issue. You're just putting a bit of pressure on the system, while putting a rotational force on the wheels. Think about when you use a swivel extension on a socket wrench; the closer you have the swivel to 90 degrees, the harder is is to turn. Now think of that swivel extension as your cv joints.
    2004 Light Silver 6MT S4
    Oct 04 2013
    203 Connecticut
    I hardly need to cut the wheels that much but it's just something I noticed. I figured it was because of quattro but wanted to make sure. At least now I know to try to stay out of those angles as much as possible.
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Chicago, IL
    Center differential binds a bit when the steering is at lock. The owner's manual even mentions that it is normal operation.
    now: 2011.5 BMW M3 sedan ZCP
    past: 2005 Audi S4 sedan, 2011 Audi S4 sedan
    Mar 05 2013
    Mk4 Jetta
    Items for Sale
    Odd that my 06 A4 with 136K miles has never had this issue (that I know of) yet my 07 S4 at 90K miles does...
    Oct 04 2013
    203 Connecticut
    This happens to me a lot when turning into driveways and such or busting a u-turn. Does this have any negative affect on tire wear?
    I think I experimented and when ESP is off this doesn't happen.
    Apr 01 2012
    Queens
    Items for Sale
    Quote Originally Posted by ladiesgod View Post
    Think its bad now? Put in the 4:1 center diff. Makes it MUCH more pronounced. Totally worth the it though, i have 0 understeer. Looking forward to the LSD going in next
    SUSPENSION-KW V3-Hotchkiss RS4 sway bars-034 Adj UCA-034 strut mount-034 F&R end links-034 motor mounts-034 Snub mount W/bracket-034 Trans mount l BRAKES-ECS Stage 4 BBK-ECS rear rotors & lines, Hawk pads l Engine-JHM Tune-JHM 6 rib pulley-Milltek catless DP's-FI exhaust l EXTERIOR-RS4 black grille-Custom headlights-LED city & DRL lights-ECS LED tail lights & plate lights l INTERIOR-Custom steering wheel-SRP pedals-ECS LED lights-MOMO shift knob-Gen 2 RNSE & AMI l WHEELS-OEM RS4 W/ Michelin PSS
    Oct 04 2013
    203 Connecticut
    Quote Originally Posted by FastEddie View Post
    I just did my first oil change after getting my car back from an engine sway some months ago. My car like shit until I changed out my oil, and even the feedback I was getting when cutting my wheels is not even noticeable. The 4:1 center diff...I'm going to look into that!
    Veteran Member Four Rings blai76's Avatar
    Aug 25 2011
    planes, trains and automobiles.
    San Francisco, CA
    Items for Sale
    Quote Originally Posted by dparm View Post
    Exactly. The center differential attempts to equalize the rotational speed of your four wheels, and struggles to compensate at slow speeds when at extreme turning angle. It's just quattro; sometimes you may even hear a noise like a foghorn in this type of scenario. The problem is lessened when you speed up. Moral of the story, avoid these situations, as it places additional wear on the center diff. Remember that you can't tow a quattro with two tires on the ground for the same reason: when all four wheels are not rotating at the same rate, quattro torsen diff suffers greatly, and will burn out if hitch towed with two tires on the ground. The experience you are having is similar to this, to a lesser scale of course.
    When you are turning slowly at full turn, the difference in rotational speed of your other wheels compared to the inner wheels, at slow speed, is much greater proportionally, to the same full turn at higher speed. Thus, you'll see this during slow-speed full turns versus cruising speed full turns (if you can manage that, like doing spinnies or drifting at speed, you will not hear the center differential groaning; you risk damaging your steering pump instead if you hold at full turn for too long)
    Bob
    2008 B7S4tip Avant, 1998.5 B5A4tip 2.8L V6 (retired)
