Page 16 of 16 FirstFirst ... 6141516
Results 601 to 618 of 618
  1. #601
    Aug 19 2017
    ATL
    Hello,
    So obviously I may have been a little wrong with some of the information. I am working with a DUAL brand AMP XPE4700 (800watts) with 2 x 10" HiFonics subwoofers in a box, I also have the LC2i Converter as well and I'm really confused on what to do. I have the Concert III Series stock radio and I want to add this amp and subwoofer in the trunk and also have the rest of the stock system in use as well... so I want the stock system to run as is, while adding this AMP and subs in the trunk if this is at all possible. I would like to know if there is a wiring diagram for this kind of set up? or any advice I could get to set this up properly. thank you
    1. year and model:::: 2011 Audi A4 Quattro
    2. radio type:::: Concert Series (AMI in glovebox)
    3. steer controls::: YES, it has some controls but I'm not sure what they all do
    4. new radio type::: for now factory radio, looking into any upgrade option available
    5. Sirius XM tuner::: NO, I don't care for any Sirius tuner
    6. Aftermarket Amp::: Yes, DUAL brand Amp XPE4700 (800Watts) with 2 x 10" HiFonics subwoofers in a box (speakers and amp was given to me for free)[/QUOTE]
  2. #602
    Stage 3 Forum Advertiser Four Rings Christian@enfig's Avatar
    Jul 12 2004
    2013 CC Executive Edition VR6 3.6, 2003 GLI VR6, 2005 A4 cab 3.0 V6, 01 GTI VR6. Past 89 & 78 Golf
    Fort Lee, NJ
    Quote Originally Posted by mgfranz View Post
    I know I will need the blade antenna cable, my only concern is the factory amp and steering wheel connections.
    Thanks,
    Not really sure how I missed this.
    Wiring harness - Connects to your cars original harness and terminates into Blaupunkt style connector. (We also have PNP adapters that convert the Blaupunkt style connector into radio specific connections)
    http://enfigcarstereo.com/ENFIG_SRWH_AUD3_HILO.html Fixes low rear audio and does steering wheel controls with a SWCL.
    or
    http://enfigcarstereo.com/ENFIG_SRWH_AUD3.html Is the same as above without the HILO box. This DOES NOT FIX audio issues but is cheaper.
    Adds steering wheel controls to the boxes above.
    http://enfigcarstereo.com/ENFIG_SWCL_SON.html
    Converts the Blaupunkt style connection into a connection specific to your radio. I need a picture of your harness to verify.
    http://enfigcarstereo.com/ENFIG_PNP_SON0017.html
    Antenna adapter - This converts your 2 antenna connections into the universal connections most radios need.
    http://enfigcarstereo.com/ENFIG_AAA_VWAUD5.html
    This is out dash kit. It matches the factory dash pretty close to perfect. We do not have a cheap kit for this because they all look bad in our opinion.
    http://enfigcarstereo.com/ENFIG_RMK8_A4B67.html
    This mic makes replaces the aftermarket mic for better sound goes in the factory location.
    http://enfigcarstereo.com/ENFIG_MIC_AUD4.html
    Keys to take out the radio.
    http://enfigcarstereo.com/ENFIG_RRK4...OOLS_KEYS.html
    To use factory Satellite antenna you must run the cable to the tuner in the trunk. You will still need to buy a new tuner this is just to use the antenna.
    http://enfigcarstereo.com/ENFIG_SAA_SIR_600_GREEN.html
    To use factory GPS antenna. All 2004-2008 radios have a connection in the rear right C pillar. Cars with the RNS-E radio have it behind the radio.
    http://enfigcarstereo.com/ENFIG_GAA_3.html
    If car has GPS antenna on roof but not behind radio you will also need this extension.
    http://enfigcarstereo.com/ENFIG_FAKRA_FF_17.html
    EnfigCarStereo.com - iPod iPhone & Aux Specialists - Radio Replacement Specialists
    info@enfig.com
    201-490-5015
    FaceBook
  3. #603
    Jul 12 2004
    Fort Lee, NJ
    Quote Originally Posted by zackdakiss22 View Post
    Hello,
    [/QUOTE]
    Unfortunately I do not have anything that can make that a plug and play situation for you. If you cannot find the information you are looking for by searching this forum I recommend taking the car to a local installer.
    info@enfig.com
    201-490-5015
    FaceBook
  4. #604
    Established Member Three Rings mgfranz's Avatar
    Apr 08 2016
    Temecula, CA
    Quote Originally Posted by Christian@enfig View Post
    or
    Thank you! Once I figure out which head unit I want I will get a hold of you.
    2008 Audi B7
    2007 BMW 650i
    2001 Porsche Boxster (for sale)
    1999 BMW 740i M-Sport
  5. #605
    Active Member One Ring A6Jose's Avatar
    Jul 17 2015
    San Jose, California
    Hey guys we get alot of calls and E-mails with radio installation questions. I decided to make this sticky to help anyone who is confused.
    We also sell the following brands of radios radios even though they are not on the site.
    Alpine (installation only)
    Clarion
    JVC
    Kenwood
    Kenwood Excelon (installation only)
    Parrot
    Pioneer
    There will be more updates to our how-to but to start if you tell me what you have I can tell you what you need.
    If you need help this is is what I need from you. I will respond in this thread.
    1. Year and model of car
    2. What radio did the car come with from the factory. (It doesn't matter if you have Bose)
    3.Does the car have steering wheel controls?
    4 What is the brand and model number of your new radio?
    5. Are you going to be using a Sirius XM satellite tuner if yes which one?
    1.)2001 A6 c5
    2.)Bose system
    3.)Yes but might delete them
    4.)It a pioneer not sure of the model number
    5.)No
    Is there a aftermarket wiring harness that will help connect a double din radio... or should I just rewire the whole speaker system my self
  6. #606
    Jul 12 2004
    Fort Lee, NJ
    Quote Originally Posted by A6Jose View Post
    1.)2001 A6 c5
    2.)Bose system
    5.)No
    We can integrate with your factory radio but I need to know what radio you are installing.
    info@enfig.com
    201-490-5015
    FaceBook
  7. #607
    Dec 29 2012
    GA
    1. 2004 S4 b6
    2. Symph II
    3. No steering wheel controls
    4. JVC KW-V330BT
    5. No sat, but back up camera
  8. #608
    Sep 26 2017
    San Francisco
    Hi, I wanted to know which products from your site I would need to purchase to properly install this stereo.
    1. A4 B7 2008
    2. RNS-E
    3. Yes, it has steering wheel controls.
    4. Pioneer avh-4201nex
    5. No, not using Sirius XM satellite. Will be installing a back-up camera.
    Thanks.
  9. #609
    Jul 12 2004
    Fort Lee, NJ
    Quote Originally Posted by fatbiscuits View Post
    1. 2004 S4 b6
    2. Symph II
    4. JVC KW-V330BT
    http://enfigcarstereo.com/ENFIG_SRWH_AUD2_HILO.html Fixes low rear audio and does steering wheel controls with a SWCL.
    http://enfigcarstereo.com/ENFIG_SRWH_AU2.html This DOES NOT FIX audio issues but is cheaper.
    We were going to make a no steering wheel control HILO but decided to bring the price of the HILO with steering down to the no steering price.
    We did the same with the non HILO units and got rid of the SRWH-AUD2-NS. Its still on the site but if you order it we just send you the SRWH-AUD2-B
    We do not have a PNP for that unit but you can send us yours and we charge $20 to make it a PNP or you can use the cable below.
    http://enfigcarstereo.com/ENFIG_PNP_UNI.html
    http://enfigcarstereo.com/ENFIG_AAA_VWAUD2.html
    - - - Updated - - -
    Quote Originally Posted by furiousfkl View Post
    1. A4 B7 2008
    2. RNS-E
    Thanks.
    or
    http://enfigcarstereo.com/ENFIG_SWCL.html
    http://enfigcarstereo.com/ENFIG_PNP_RADIO.html
    look at this article about shallow face radios. https://www.ceoutlook.com/2017/06/21...o-shape-shift/
    info@enfig.com
    201-490-5015
    FaceBook
  10. #610
    Active Member Two Rings SixOp's Avatar
    Apr 15 2013
    2002 Audi S6 Avant
    Omaha, NE
    Quick question: How do I remove my aftermarket radio from your dash kit? I need to check a few of the wires back there and I have been struggling with getting the radio removed after install. This is the dash kit I purchased: https://enfigcarstereo.com/ENFIG_RMK16_A6.html
    Nevermind.....got it out.
    (Say something profound here): I put on pants today.
    2002 Goodwood Green S6 avant
    RS6 goodies, Milltek stuff, Porsche brakes, and electrical gremlins.......
  11. #611
    Jul 12 2004
    Fort Lee, NJ
    Quote Originally Posted by SixOp View Post
    Sorry I didn't see this until now.
    Its tight so sometimes you have to wrestle it out. The tight cavity in the A6 does not help.
    info@enfig.com
    201-490-5015
    FaceBook
  12. #612
    Apr 15 2013
    2002 Audi S6 Avant
    Omaha, NE
    No worries. I fought with it a little bit and got it out.
  13. #613
    Active Member One Ring Edystoy's Avatar
    Apr 20 2014
    Virginia
    Audi radio replacement guide by EnfigCarStereo.com
    Hi I was hoping you can tell me what I need to buy from your site for my A4?
    1. 2008 A4 B7
    2. Symphony
    3. Yes it has steering wheel controls
    4. Kenwood DDX719
    5. Not using Sirius XM
    Thanks in advance
  14. #614
    Jul 12 2004
    Fort Lee, NJ
    Quote Originally Posted by Edystoy View Post
    1. 2008 A4 B7
    2. Symphony
    4. Kenwood DDX719
    Thanks in advance
    or
    http://enfigcarstereo.com/ENFIG_SWCL_KEN.html
    http://enfigcarstereo.com/ENFIG_PNP_KEN0016.html
    http://enfigcarstereo.com/ENFIG_GAA_PIO2.html
    info@enfig.com
    201-490-5015
    FaceBook
  15. #615
    Registered Member One Ring bob.os's Avatar
    Jun 29 2015
    74 VW Station Wagon Bus, 2005 A4 3.0 Quattro Cabrio
    Columbus, OH
    1. 2004 allroad Quattro
    2. Symphony II
    3. Yes, and want to keep/use.
    4 Kenwood dmx7704s
    5. Not going to use, but might wire it up just in case.
  16. #616
    Jul 12 2004
    Fort Lee, NJ
    Quote Originally Posted by bob.os View Post
    2. Symphony II
    4 Kenwood dmx7704s
    (I don't have a PNP for this radio yet but if you send in the harness that came with your radio I Can build you one for $20 using your harness)
    For anyone else reading this. It's $20 because we plan on making the harness. If it's a radio that we do not regularly have a harness for then the price is $50.
    info@enfig.com
    201-490-5015
    FaceBook
  17. #617
    Senior Member Four Rings Bordom's Avatar
    Dec 10 2013
    Pickering, Ontario, Canada
    Quick question on how to remove the radio after you installed it with an RMK15-A6 adapter.
    Trying to remove the radio to add more stuff to it but can't figure out for the life of me how to do it.
    Sent from my SM-G935W8 using Tapatalk
    S4's New Lease On Life
    2001.5 S4 6-spd
    Currently "Monster"
    IG: 24_et
    MODS: Revo Stg 1, 034 Billet Subframe Bushings, SSAC V2 Downpipes, Custom True Dual Exhaust, Forge 007 DVs,
  18. #618
    Nov 12 2017
    1991 VW Vanagon Syncro Westfalia with '03 1.8T.
    Sacramento, California
    2001 Audi S4
    Symphony
    I wish..
    RNS-E
    No Sirius
    Stock amp for now. May put A8 amp in soon.
