Results 1 to 7 of 7
    Established Member Two Rings zzDuality's Avatar
    Jul 24 2013
    Audi a4 b8
    Miami
    Smile Audi a4 b8 Daytime running lights Help
    Hello, I was wondering If anyone knows where I can buy these daytime running lights.
    I have looked around ebay and have found a few for 400-700 but then in some other sites they go for 1.000+?
    Whats the difference, am I getting ripped off?
    What are the lights exactly? Xenons? or LED
    I'm not very knowledgeable in led's
    Any help would be appreciated. Thanks.
    Veteran Member Four Rings jlaudio's Avatar
    Mar 26 2009
    SLC, UT
    The DRL and headlamp are all one unit. If you decide to upgrade from stock halogens you would need left and right side light, kufatec harness, 2x ballast and 2x bulbs from an oem car
    You might need Vagcom coding also
    all in it should cost you about 800-1100 depending on if your buying new/used etc
    '10 S4 - 6MT, GIAC Stage 2, Milltek Resonated Exhaust, AWE S-Flo Intake, Alu Kruez, Bilstein B12 Suspension, 034 Rear Sway Bar and Links, 034 Transmission & Sport Diff mount, Sachs X-Tend Clutch, CR15 Bar, Akebono, ECS SS Lines, 3M Crystalline, E-Codes, Philips White Vision Gen 2
    Previous: 09 B8 A4, 06 S4 6MT, 07 A4 6MT, 02 A4 QM, 99 A4 QM
    Jul 24 2013
    Audi a4 b8
    Miami
    I see..
    Does anyone have any links for a full kit? I cant seem to find one that is full. If it even exists.
    Veteran Member Three Rings A4B8ueg's Avatar
    Aug 13 2012
    Honolulu, Hawaii
    Debadged A4 Quattro | Aruba Blue Pearl Effect
    STaSIS | EuroCode | Apikol | H&R | 034 | AWE | GFB DV+ | K&N | Sprint Booster | ECS Rotors | S5 Brakes | SS Lines | RS4 Grille | Honeycomb Fog Grilles | CF Front Splitter | Replica R8 19" Wheels | RS6 FBSW | S-Tronic Knob | oCarbon | RS5 Pedals | FCA Rear Valence | VAGCOM
    Dec 08 2012
    Moldova
    Not sure if its allowed, but I have a right headlight housing, for about 200$ + shipping, in a great condition.
    Audi A4 B8, 2.0 TDI. Retrofits: Bi-xenon. Front parking sensors with graphics. OEM Bluetooth. Servotronic - 1N3. Footwell lights. Color DIS. AMI. Audi Drive Select. EGR off. DPF off. 207BHP CAHA remap. Keyless Entry/Go. Lane change assist. B&O. Aux Heater.
    Oct 20 2012
    Danbury
    Items for Sale
    i believe there is a set of Ecodes on Ebay for around $1300. The same set I bought. The person that is selling the headlights is selling the complete set with ballasts and bulbs, all you need is the adapter and you can just buy that off the site. Just search "Oem audi a4 bi xenon headlight" on ebay and it should be there.
    Dec 08 2012
    Moldova
    You are really better of getting the complete set from a single place, as its going to be way easier.
