Results 1 to 24 of 24
    Nov 29 2007
    Calgary, Alberta, Canada
    034 Motorsports crankcase breather hose kit???????
    I am having an issue after doing a complete lcv, eval, sai delete what to do with the hose that comes with the crank breather hose. I have the main piece attacked to crankcase and going up to the T-Flange of the back of the cylinder head, but what the hell does the 1/2 inch tube that comes out the side of the main crank hose connect to? there is a billet fitting for the side of the crank breather hose and then a hose that attaches to that and connects to WHAT?
    2004 A4, K04, APR TUNED, APR TIP, APR R1 DV, JHM SS....
    Nov 29 2007
    If anyone has pictures of there 034 breather kit set up on car that would be appreciated.
    Veteran Member Four Rings jubei4769's Avatar
    Feb 09 2012
    79 VW Rabbit / 09 Triumph Daytona 675
    Kailua, HI
    Items for Sale
    it should go from on top of the oil cooler to the back of the cylinder head. the piece that comes out the side should have a check valve that goes to the intake manifold. unless im thinking of something different
    did ur kit look like this?
    instagram: @low_n_slo
    03 B6 A4 1.8T RIP Jan 2015 http://www.audizine.com/forum/showth...ld-progression
    79 VW Rabbit
    02 Audi S6
    Established Member Two Rings S_Line_A4's Avatar
    Dec 07 2012
    LS V8 , 04 STI , 01 RS 2.5
    CHICAGO , IL
    That hose from T fitting and the billet pcv valve goes to intake manifold
    Senior Member Two Rings SoCal Driver's Avatar
    Nov 28 2012
    2011 Jetta SE 2.5 - B7 A4 2.0T Quattro 6-Speed
    Oxnard, CA
    Quote Originally Posted by jubei4769 View Post
    I did mine a few weeks ago and mine looks exactly the one above. A vacuum cap goes one the 1/2" tube coming off the main crank hose.
    like this...
    Current: 2008 A4 2.0T Quattro 6-Speed | TT downpipe, custom magnaflow exhaust. | Miro 111
    Past: 2004 A4 1.8T Quattro 6-Speed USP in Arctic White
    Feb 09 2012
    Kailua, HI
    Items for Sale
    Quote Originally Posted by SoCal Driver View Post
    like this...
    thats a better diagram but basically the same thing i said.
    79 VW Rabbit
    02 Audi S6
    Nov 29 2007
    Awesome thx
    Nov 29 2007
    There are 5 ports on my intake mani, can I pick and choose where I want to connect it?
    Dec 25 2004
    Earth
    Items for Sale
    Quote Originally Posted by ColinBurger00 View Post
    The 034 kit eliminates hoses 15, 16 & 17 pictured above, and theres connects were hose # 10 connected to the intake manifold.
    Unless you dont have an OE manifold....
    K04-15/APR/TT 225 Injectors/TFSI Coils/Custom Stainless Exhaust/710N/RaceTec FMIC/ 034 HFC/Jet-Hot Cermi-coated & ported exhaust manifold/JHM B7RS4 SMFW clutch/Neuspeed TIP/Apikol Snub/Optima 75-35/AFE Pro-Dry/AMS Short-shift @ %40 redux
    Bilstein Sports with H&R/H-Sport Anti-Sway bars/E-codes/ 19x8.5 Skinny Fives 235-35 Falkens/B7 A4 brakes with StopTech Ceramic pads and Stop Tech rotors/Sirius Satellite Radio/Ross-Tech HEX-USB+CAN Equipped/Escort 9500ix
    Senior Member Two Rings Eurofication's Avatar
    Feb 24 2013
    2004 A4 USP, 2005 C230
    Charlottesville, VA
    So if I am correct the hose that replaces 12 on the diagram, will essentially attach to another hose to be ran down the firewall correct. Similar to how I have mine done now but this kit looks so much better.
    SCAT Rods 20mm wrist pin, Mahle Pistons 9:1, CM Stage 3 Clutch, Boost Brothers FMIC, Forge Splitter DV, TT 225 Injectors, K04, Unitronic Stage 2, Miltech DP, Magnaflow exhaust, 3" Test pipe, ST Coilovers, Podi Stepper Boost Guage, Matte White and Machinery Grey Paint, Custom OEM Boser hood, STI Front Lip, Shaved and Molded USP bumper, Pioneer 7" DVD, Kicker L5 custom enclosure, white beltline trim, Black & Charcoal Plaid headliner, Memphis 6.5 Components, Hifonics amps
    www.podi.ca
    Feb 09 2012
    Kailua, HI
    Items for Sale
    Quote Originally Posted by Eurofication View Post
    depends on your car, my car has the valve inthat spot so the hose i got is really little.
    79 VW Rabbit
    02 Audi S6
    Feb 24 2013
    Charlottesville, VA
    My car had a Valve there until I got rid of all the emissions and PCV system
    www.podi.ca
    Dec 25 2004
    Earth
    Items for Sale
    Feb 09 2012
    Kailua, HI
    Items for Sale
    79 VW Rabbit
    02 Audi S6
    Sep 03 2009
    San Antonio, TX
    Anyone have a diagram for AMB motors? According to 034s site, for my VIN (8E-3-107804) my kit doesn't look anything like the one shown:
    [IMG][/IMG]
    MY BUILD
    Jan 01 2012
    2004 A4 Avant
    CO
    Looks just like it to me. Only thing is they don't have the checkvalve in place with the hoses connected like you are seeing them in the other pictures.
    | 2004 A4 Avant | Gloss Dark Grey |
    | GTRS | Motoza | Bosch 550's | 034 TIP & TT225 MAF housing | 034 HFC + BB catback | 710N | TR18T FMIC | RA4 stage 2 clutch | 034 RSB & Endlinks | Apikol snub | 17z BBK |Vogtland GT1 Coilovers | Moog adj. UCA's | Peeler reps |
    | 2011 A4 Avant | Brilliant Black | Vogtland Coilovers | RSE's | 034 Sway/tranny mount | Q5 brakes |
    Feb 09 2012
    Kailua, HI
    Items for Sale
    Quote Originally Posted by sa_seahawker View Post
    [IMG][/IMG]
    Mine was for AMB it connects the same way
    79 VW Rabbit
    02 Audi S6
    Jun 27 2011
    Items for Sale
    OP do you know what the purpose of all those systems is? The ones you "deleted"?
    Le sigh...
    -CP
    2008 Brilliant Black Unicorn (2.0t S-Line Ti 6MT Avant) - Bosch FR6KPP332S plugs - Q5 Rear Aero Wiper
    2012 Q5 2.0t - Stock Mommy Missile
    Former USP CLUB MEMBER #136
    Apr 01 2007
    2017 Mustang GT Performance Package, 1983 Chevy Silverado
    houston texas
    Le sigh...
    Thur for deletin'!
    2005.5 6 speed with the Premium, Lighting, Sport, and Cold Weather packages
    Pag Parts EFR 6758 kit, Pag Parts intake/FMIC/manifold/downpipe, Eurodyne Boost Manager Plus, Eurodyne Maestro, StopTech 332mm BBK, Stasis Touring suspension
    Jun 27 2011
    Items for Sale
    Quote Originally Posted by texasboy21 View Post
    Thur for deletin'!
    Don't make make me come down there and whoop yer ass boy!
    -CP
    Senior Member Three Rings G.AUDI's Avatar
    Dec 07 2008
    MK6 GTI
    SGV, CA
    Le sigh...
    Can you splain it for the rest of us who might not..... you know, for science?
    Jun 27 2011
    Items for Sale
    Quote Originally Posted by G.AUDI View Post
    PCV regulates crankcase pressure, so that the engine retains proper vacuum and doesn't over-pressurize and blow out the various oil seals in the head/block. Many people "delete" this system to varying degrees for various reasons (becuz racecar, to "simplify", because they got annoyed at it and hulk smashed it, etc) but doing that, you're just asking for sludge issues and the engine won't get a constant supply of fresh air circulating through the block, purging the oil vapors, etc.
    EVAP is a emissions system, that recycles the fuel tank vapors and pumps them into the intake tract. Its a metered part of the fuelling system, so deleting it will cause lean conditions at worst, or increased fuel trims at best.
    SAI is a stupid emissions component that helps to speed up the heating of the catalyst elements. It serves an important purpose from an emissions perspective, but won't affect proper engine running in any way, unless you leave the SAI port on the back of the block wide open, then you're an idiot, haha. The SAI is perfectly fine to remove assuming its done right. When the pumps fail, people often just rip them out, which is fine.
    People LOVE to just rip these systems out willy nilly because their brains can't comprehend why there are so many lines and what they do. So rather than actually learn what they do and understand their purpose, they rip them out. The reasoning being, well my '55 ford pickup/'96 Talon/'99 Civic don't need this shit, emissions are for tree hugging hippies, and I'm an idiot, so it's all gotta go buddy!
    Savvy?
    -CP
    Jan 24 2008
    Pennsylvania
    So you're deleting your pcv, evap, and SAI?
    Why are you doing this?
    2004 B6 Avant l Moro Blue Pearl l Sportec l EFR TS-7064 l United Motorsport Tuned l 460 awhp, 93 octane
    2014 P+ Allroad l Glacier White l Airlift 3H l BBS l Eurocode l OEM+ Goodness l CTS l IE l K04 l United Motorsport Tuned l
    Instagram: bluewings460
    So many Audis, so little time....
    Feb 09 2012
    Kailua, HI
    Items for Sale
    Quote Originally Posted by Turbavanttro View Post
    see end of above post
    79 VW Rabbit
    02 Audi S6
