Results 1 to 13 of 13
    Established Member Two Rings i.am.gustav's Avatar
    Apr 21 2013
    New York
    Items for Sale
    What are the symptoms of a vacuum leak
    So today I was able to get my car smoke tested and saw that one of my vacuum hose had torn. I was wondering what are the symptoms of a vacuum leak and how does it affect the performance of the car? Thanks in advance for your inputs!
    Senior Member Four Rings iHaveBoost?'s Avatar
    Jul 26 2012
    JHM'd B6 S4
    Waltham, MA
    What's a vacuum hole? I'm intrigued..
    But a vacuum leak can cause lean conditions for letting in unmetered air, as well misfires, rough idle, potential stalls and no start symptoms if the leak is large enough, and degraded performance, etc.
    You should buy a boost gauge. There is no better diagnostic instrument to have for a turbocharged car. This will tell vacuum/boost levels so you can be sure everything is on par. Also replace whatever hole you broke. Wink.
    Oct 27 2010
    Ibis B8 A4. Arctic B6 S4.
    Norwood, MA.
    Items for Sale
    Did you smoke test it yourself? I would go for a test using compressed air, that was you can hear and feel the boost leaks. There is a guide on a4mods.com on how to do make your own tester on the cheap.
    2010 Ibis white S-line A4
    2.7t swapped stage 3 B6 S4 - Work in progress.
    Instagram- @Thisisastickup
    Jul 26 2012
    JHM'd B6 S4
    Waltham, MA
    I made my own from $5 worth of Home Depot materials. I didn't do it quite like a4mods, I made a more simple one. But the premise is the same.
    This is only good if you have your own compressor, btw.
    Apr 21 2013
    New York
    Items for Sale
    Quote Originally Posted by b6Hate4 View Post
    No, my uncle is a mechanic and he used the Redline Smoke Pro machine. He saw that the smoke was escaping from the hose thats connected to the pcv valve.
    Established Member Four Rings milan2k13's Avatar
    Jun 09 2013
    Orlando, FL 407
    Quote Originally Posted by i.am.gustav View Post
    If he's a mechanic just have him replace it...
    More Power, More Problems! 1.8Tiny
    B6 ---> Motoza Stage 1+ | 550cc | 034 HFC | Forge TIP | Forge 007 DV | 2.0T FSI Coils | NGK BKR7E | K&N Drop-In | 93 Proof |
    Apr 21 2013
    New York
    Items for Sale
    Quote Originally Posted by milan2k13 View Post
    He is but he says he wants to get the hose from Audi because it a special shaped one.
    Jun 15 2011
    08 A4 Q Stock, '58 Porsche 356A, '73 BMW 2002
    Exiled.......
    Just use regular heater hose from Napa....they have a ton of hoses with different diameters and bends. No need to do what I did..which was to spend $30 on a rubber hose.
    Veteran Member Three Rings pa4ul's Avatar
    Mar 20 2008
    03 Audi A4 1.8T/ 72 Ford F-100
    south
    Napa hoses have saved me lots of money! Never once had a problem with them either.
    Joooe Mamma!
    Jan 06 2009
    Depending on the hose (some are tapered, some are T's, some have a tight radius) you may need to use the OEM piece.
    Check this out for a DIY on most of the PCV related hoses/valves: http://www.audizine.com/forum/showth...-by-a4darkness
    B6 2.7t BEL -- F21s, ER ICs, etc -- Tuned by Bische --
    B7 2.0t
    Apr 21 2013
    New York
    Items for Sale
    Anyone know any symptoms to a vacuum leak?
    Apr 07 2011
    I'm pretty sure you can get the 034 kit for a fraction of the price of OEM. There can be many symptoms as mentioned in post #2.
    Veteran Member Three Rings tenspeed's Avatar
    Dec 12 2011
    Honeoye NY
    Quote Originally Posted by iHaveBoost? View Post
    I thought he gave a good explanation. Basically a rough idle and the engine wants to die. Sometimes giving it a little gas will keep it running.
