Results 1 to 9 of 9
    Veteran Member Three Rings jr1415us's Avatar
    Mar 08 2011
    Chicago IL
    Removing intake manifold questions
    OK, I need to pull the intake manifold due to a leaking valley pan gasket, which is covering the front of the motor in oil.
    The DIY pages I've looked at say to remove the injectors and rail first-could I just disconnect the fuel line and electrical connections and leave everything in the manifold and remove as one piece?
    Will I need new manifold gaskets or can I reuse what's there?
    2013 Arctic White Allroad Premium Plus-Vogtland Coilovers
    RIP 04 S4 Avant 2012-2017
    Veteran Member Four Rings 65vetteC6's Avatar
    Jul 28 2007
    V8's
    In an Audi
    Items for Sale
    I don't think you can get to the manifold bolts with it on. It's really a simple job to remove the fuel rail, 4 bolts and some pulling. Why not do it right just to make sure you don't accidentally damage something? You should order some pointless caps though because I bet you will have a few missing/broken. And you need to replace the intake gaskets.
    Also the process of getting the plugs in the front of the engine off is a PITA! You will by doing a little man handling on the manifold at during that.
    Veteran Member Four Rings TarlCabot's Avatar
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    Items for Sale
    Quote Originally Posted by 65vetteC6 View Post
    Agreed... do it right cause you not going to save any time trying it another way...
    The plugs...
    This helped me getting them loose, be very careful those plastic clips and vacuum lines will break
    Pain, just to get to this :(
    2006 Audi (B7) S4 4.2L 25th Anniversary Special Edition #167, SRP Racing Pedals, 245/35 ZR 19x9.5" ET 25 MRR Catalina's with 5mm Spacers on rear, (B5) Front Spring Perches, RS4 H-Sport (Hotchkis) Rear Sway, Apikol Snub Mount, 034 Motor/Trans mounts, ECS Performance Rear Differential Mount and 034 Rear Carrier Mount Upgrade, South Bend Feramic/Kevlar Stage 2 Clutch Disk, JHM 93 octane Tune, Ported IM & Elbo, 034 MAF hose, XS 2.5" 200 cell HFC D/P's. Custom 2.5" true dual Magnaflow Race C/B
    Established Member Two Rings jpo's Avatar
    Jun 22 2008
    Calgary
    This isn't in any DIYs I've seen but before you pull the manifold try and clean as much dirt and crap as you can from around the edges cause sand and crap will fall into the open valves.
    2004 Moro Blue S4 MT
    Established Member Two Rings rave's Avatar
    Jul 27 2011
    Cleveland, OH
    It's not necessary to remove the TB say, if you were just to put in some spacers right? I read the one diy where the guy takes it off but I think it's just because he replaced it with a new one?
    Ryan
    2008 A4Quattro 3.2 RIP
    2005 B6 S4
    Magnaflow exhaust, H&R springs, H&R spacers 12F/15R, ITG air filter, Apikol snub, Sonic Tuning cabin/trunk LEDs, Ziza lplate LEDs
    Jan 29 2010
    north ga
    Items for Sale
    my car needed to have its valley pan gasket replaced prior to me buying it, and I have heard of at least one other with the same problem. I'm wondering if it will start occurring to others more frequently or if these are rare occurrences.
    To the OP, yes the fuel rail needs to come off. It pops right off, just lift straight up gently, it's probably the easiest part of the job.
    The TB can stay attached to the IM unless you are replacing it with the JHM IM & TB.
    enjoy being hunched over your engine for awhile.....I know my back aches just thinking of having to pull the IM just to begin replacing the valley an gasket
    Mar 08 2011
    Chicago IL
    damn, changing the serp belt and snub mount incapacitated me for week. Dreading this one.
    Mar 06 2012
    Mazda RX8 GT
    south florida
    im getting my JHM intake mani installed soon, this looks like something i should do while its off, where do you get the gasket from, part number?
    B7 Sprint Blue Audi S4
    Few mods here and there
    Jul 31 2012
    Scotland
    Quote Originally Posted by mgikone69 View Post
    Love to see another write up on how you find life with the IM. I'm seriously considering this as my next mod... even just for the red wrinkle powder coating, lol.
    Sold: 2006 6MT Saloon. Apikol Snub & 034 Street Trans and Motor Mounts. JHM LW Front Rotors. JHM 91 Tune. Piggies. Milltek non-resonated cat back and JHM IM. Missed already
    Sold: 2009 XFR 5.0 V8 Supercharged :(
    2013 B8.5 S4, (no Sport diff or adaptive dampers); APR Stage 2 (crank / lower pulley), TCU tune, 034 Rear Anti-roll bar. 034 Trans mount.
