changed that and I'm noise free.......
until I started hearing this metal to metal grinding noise again when I make/turn left...the noise is really annoying, could it be my rear passenger wheel bearings that are bad??? the noise can be heard even as slow as 25mph and when the wheel is approx. turned 100 degrees. It gets worse the more I turn the wheel to the left
accompanying the metal grinding noise is a weird feeling of my undercarriage grinding as well(I know it doesn't make any sense but hopefully someone gets it LOL)
And could this same problem be the reason why my car shakes like hell when I just step on the gas to maintain my speed? and this also means using cruise control....shakes like a mothereffff
but this vibration goes away when I let go of the gas or press hard on the gas to gain speed
I'm almost done with this car >.<
And any other advice what to change suspension wise to make the car feel like brand new again?
I recently changed the following:
Front wheel bearings...both sides
Upper Control Arms....both side
if it matters, I have ST coilovers and dialed pretty high coz of winter. I go up the mountains often and the noise I describe above is just plain annoying.
P.S. I apologize in advance if there are threads that covers these kind of problems.
