Page 5 of 9 FirstFirst ... 34567 ... LastLast
Results 161 to 200 of 350
  1. #161
    Established Member Two Rings Calderone's Avatar
    May 31 2016
  2. #162
    Senior Member Four Rings Poodini's Avatar
    Oct 26 2015
    2016 Subaru Outback 2.5 Limited
    Fremont, NorCal
    Recent shots:
  3. #163
    Established Member Two Rings br0wn's Avatar
    Nov 04 2015
    Quote Originally Posted by ajm0903 View Post
    where did you get hose matching fog lights from
  4. #164
    Established Member Two Rings Dcferolino's Avatar
    Jan 10 2015
    Salinas, ca
  5. #165
    Jan 10 2015
    Salinas, ca
  6. #166
    Jan 10 2015
    Salinas, ca
    Quote Originally Posted by Dcferolino View Post
    Heres the inside look
  7. #167
    Established Member Two Rings heatseeker23's Avatar
    Jan 04 2016
    B8 A4 Quattro | MK5 GLI | | GMT900 Silverado | MK2 TTS 15' (retired) | MK4 VR6 12V (retired) |
    Dallas/TX
    Ignore the Expansion tank cap missing, it was in the process of getting painted candy red as well.
    Instagram: @TheHeatSeeker
  8. #168
    Oct 26 2015
    Fremont, NorCal
    Ultimate Black B8 Picture Thread (UBBPT)
    [QUOTE=heatseeker23;12148666]
    That right there is what I'm talkin' bout!!
    Been going back n forth about throwing a Stybek front lip on or not. How are you getting by and NOT killing it underneath with such an aggressive drop?
    Anyways, kudos man.
    'That whip so cold!
    This old thang!'
    Ye
  9. #169
    Jan 04 2016
    Dallas/TX
    [QUOTE=Poodini;12148790]
    Quote Originally Posted by heatseeker23 View Post
    Anyways, kudos man.
    'That whip so cold!
    This old thang!'
    Ye
    Mostly because i don't drive the car much anymore. I try to pull it out for a spin once a weekend but sometimes can't even do that. I am on air so that helps as well. I have had the lip on for nearly one year and no scrapes on it so far.
  10. #170
    Established Member Two Rings kwstantinosk89's Avatar
    Oct 01 2016
    isuzu pickup 1989
    cyprus
    Sent from my SM-G900F using Tapatalk
  11. #171
    Veteran Member Four Rings bmoreS4's Avatar
    Apr 27 2011
    Couple Audis and a VW
    MD
    Current:
    2001.5 B5 S4 - Stage 3 on Meth -- Thanks to Brad and Country Dubs
    2013 B8.5 S4 - EPL Stage 2 / EPL TCU
    2018 Atlas SEL Premium - Black on Black - Black Wheel Package
  12. #172
    Just took some quick pictures. More to come this summer!
    Day 1..... Changed Grille & Fogs
    Next.... Plasti Dip side mirrors and door blade. Purchased RS5 reps.
    Today.... OEM 20" S6 rims, Vinyl wrapped window trim, side mirros & Door blades. 5% tint all the way around & 50% on windshield. Added Thule bike rack.
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    2010 Avant S Line+ Prestige+ Quattro, Brilliant Black, 35% all around w/ 40% on the windshield, debadged, 19x95 et22 Rs5 reps, 255/35/19, S4 Mirrors + matching side skirt, RS4 Grille - Much More to come! (Turbo replaced at 62k & pistons, guides, rings, chains & tensioners replaced at 65k)
    Previous Cars -B8 Sedan, B7 & B6
  13. #173
    Senior Member Three Rings Sumo337's Avatar
    Jan 07 2015
    2012 B8 A4, 1994 RHD Miata
    Pittsburgh, PA
    @chetbagged
    Bagged 2012 Prestige A4 B8 2.0T / 6MT / 260HP 360TQ
    APR / 034 / ECS / BFI / Eurocode / Caractere / Airlift Performance / Watercooledind
  14. #174
    Oct 01 2016
    isuzu pickup 1989
    cyprus
  15. #175
    May 06 2017
    Vancouver BC
    murda murda
  16. #176
    Established Member Two Rings jcun's Avatar
    Sep 02 2016
    scottsdale/az
    Fresh wash a few months ago!
  17. #177
    Established Member Two Rings 2k12A4's Avatar
    Feb 25 2016
    Los Angeles, CA
  18. #178
    Established Member Two Rings steviesteves's Avatar
    Nov 13 2016
    Westchester NY
    Quote Originally Posted by Poodini View Post
    Recent shots:
    How did you get that sline badge to fit on your grille?
  19. #179
    Established Member Three Rings NathanGreatScott's Avatar
    Apr 05 2017
    '16 Ford Flex Limited
    Western PA
    Quote Originally Posted by steviesteves View Post
    Correct me if I'm wrong, poodini, but I'm guessing it's this style badge; https://www.ebay.com/itm/111826949721
    That's what I used on my mesh grille
    Brilliant Black '14 A4 Quattro 6MT w/ S-Line style package
    PROGRESS
    IG:@nathangreatscott
  20. #180
    Oct 26 2015
    Fremont, NorCal
    VERY CAREFULLY...
    I just trimmed off a bit of the back tab that would normally clip into place. Just enough so as to insert it into the mesh space and be able to rest relatively balanced and the back of the actual badge comes in contact with the mesh. A little dab of auto grade Goop, hold it in place to set. After an hour, just lightly did a once over w heat gun at lowest setting in case some of the glue clumped up prior to setting.
    Whoop there it is! Still solid as a barnacle on the hull of a ship!
  21. #181
    Established Member Three Rings Steelerhater37's Avatar
    May 29 2017
    BMW E36 M3 convertible VW B6 Passat
    Bel Air Maryland USA
    1st day in my new home
  22. #182
    May 29 2017
    Love my A4 but need gps & rear view cam desp. Help!
    Love to keep my system somewhat intact though
  23. #183
    Established Member Two Rings Kash_zu's Avatar
    Sep 11 2016
    Long Island, NY
    Here's my b8.5
  24. #184
    Oct 01 2016
    isuzu pickup 1989
    cyprus
    My Black devil
    Στάλθηκε από το SM-G950F μου χρησιμοποιώντας Tapatalk
  25. #185
    May 29 2017
    Change of shoes
  26. #186
    Jan 10 2015
    Salinas, ca
    Heres mine :)
  27. #187
    Oct 01 2016
    isuzu pickup 1989
    cyprus
    Mine too but in the night🖤
  28. #188
    Senior Member Four Rings 4ringnut's Avatar
    Apr 04 2015
    2018 Audi S4, 2017 Acura MDX
    Woburn, Ma
    Heres mine :)
    Did you walk into Pep Boys and say "fuck my car up, fam!"
    Pedal Responce first responder.
  29. #189
    Jun 05 2009
    Ducati Panigale 1199S (Red of course)
    Denver Colorado
    ^ Some big meaty tires on there. 65 Series?
    Black B8 A4 Avant S-Line Prestige Package, CPMB Engine, Tiptronic 8 speed, JHM K04-R, V1 & Beltronics, Eurocode HFC, APR FMIC, Alu Kreuz, Vogtland Coilovers, Stoptech 380mm BB Kit, H&R Swaybar, APR K04 Tune, Rev. "d" DV, R8 Coils, Folding Mirrors, S5 Rear Brakes, 034 Street Density Mounts, OEM Facelift LED Brake lights, Forgestar CF5, and more mods to come!
  30. #190
    Apr 04 2015
    Woburn, Ma
    Quote Originally Posted by A4 Centaur View Post
    Wrapped on drag ricing wheels.
  31. #191
    Oct 01 2016
    isuzu pickup 1989
    cyprus
    Heres mine :)
    bro change those rims! they will look better on my 1989 isuzu! Lol
  32. #192
    May 29 2017
    Holy holy!! ROFL
  33. #193
    Active Member Two Rings glennnsanity's Avatar
    Jul 12 2017
    Nutley NJ
    RS4 grille and cheap rubber lip
  34. #194
    Jul 20 2017
    Rs grill and black emblems. Still need to get wheels and lower. Plus thinking about matte black racing stripe.
  35. #195
    Senior Member Three Rings Carlos74's Avatar
    Mar 30 2014
    Palatine, IL
    APR l CTS l EUROCODE l ECS l 034 l PODI l GFB l MAGNAFLOW l H&R l SPC l STANCE l SPULEN l HANKOOK l NGK
    IG: c_lowsB8
  36. #196
    Apr 05 2017
    Western PA
    Quote Originally Posted by glennnsanity View Post
    What lip is that? I've been in the market and am considering all options before buying one.
    PROGRESS
  37. #197
    Established Member Four Rings BeerBrent's Avatar
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    I'm offended by this racist thread.
    Awesome pics!
    I'm as cool as a cucumber in a bowl of hot sauce.
  38. #198
    Jul 12 2017
    Nutley NJ
    Quote Originally Posted by NathanGreatScott View Post
    Its just a rubber lip called ez lip from amazon.
  39. #199
    Oct 01 2016
    isuzu pickup 1989
    cyprus
    Sunrise at the beach
  40. #200
    Apr 26 2014
    San Diego, CA
    Quote Originally Posted by 4ringnut View Post
    build / instagram / flickr
