Results 1 to 12 of 12
    Veteran Member Three Rings rage385's Avatar
    Sep 06 2012
    2001.5 Audi S4, 2009 Daytona 675
    United States
    Items for Sale
    Clearing fault codes and passing emission testing
    All,
    I have a 2001.5 B5 S4. Not one day after I bought the car, a CEL appeared. I took it to the dealer and they diagnosed it as a O2 and potentially at CAT problem. I am working with the dealer that I bought from to get the replacement parts (free of charge).
    Question I have is this. I just bought (in the mail as we speak) a V-Checker from ECS and the description stated that it can clear the fault codes.
    Ok so this is what I want to do. My temp registration is up on November 1st. Arizona law dictates that I must emission tested the car before I can register it. With that said, if I clear the codes myself, and bring it to the emission testing, will their equipment pick up any faults? Do you think I will fail emissions?
    Once I get the car registered, I will repair the car, as I was planning on replacing the O2 sensors and getting a full exhaust anyway.
    Thoughts?
    Senior Member Three Rings karrann's Avatar
    Jul 13 2012
    Nogaro Avant
    Im not sure about Arizona but I am in Washington and my friend got an s4 recently. He had a CEL and failed emissions. Checked with my vagcom and he had 12 codes. We cleared them all and got it tested again right after and it passed. The CEL came back 40 miles later obviously. These were his codes btw.
    Address 01 -------------------------------------------------------
    Controller: 8D0 907 551 J
    Component: 2.7l V6/5VT G 0002
    Coding: 06751
    Shop #: WSC 06325
    12 Faults Found:
    18032 - MIL Request Signal Active (Check TCM for errors too!)
    P1624 - 35-00 - -
    17866 - Exhaust Gas Temp Sensor 2 (G236): Short to Ground
    P1458 - 35-00 - -
    16486 - Mass Air Flow Sensor (G70): Signal too Low
    P0102 - 35-10 - - - Intermittent
    17869 - Exhaust Gas Temp Regulation for Bank 1: Implausible Signal
    P1461 - 35-10 - - - Intermittent
    16946 - System Voltage Too Low
    P0562 - 35-10 - - - Intermittent
    17930 - Camshaft Adjustment: Bank 2: Malfunction
    P1522 - 35-10 - - - Intermittent
    17927 - Camshaft Adjustment: Bank 1: Malfunction
    P1519 - 35-10 - - - Intermittent
    18010 - Power Supply Terminal 30: Voltage too Low
    P1602 - 35-10 - - - Intermittent
    17539 - Oxygen (Lambda) Sensor: B2 S1: Internal Resistance too High
    P1131 - 35-10 - - - Intermittent
    17868 - Exhaust Gas Temp Regulation for Bank 2: Limit Reached
    P1460 - 35-10 - - - Intermittent
    17545 - Fuel Trim: Bank 1 (Add): System too Rich
    P1137 - 35-10 - - - Intermittent
    17547 - Fuel Trim: Bank 2 (Add): System too Rich
    P1139 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    Sep 06 2012
    United States
    Items for Sale
    wow! Ya, I only had the P1454, P0421, and P0431. This is good news. Thanks for the help!
    Active Member Two Rings pharkwar's Avatar
    Oct 24 2012
    2001 S4 Avant, 2001 TT 225 rdstr, 2001 Golf TDI
    Kitchener
    Quote Originally Posted by karrann View Post
    ....18032 - MIL Request Signal Active (Check TCM for errors too!)...
    This is not a good sign.
    arizona, you need to pass rediness, so no codes and you have to have the emission components set. Had a friend in az recently who failed cause rediness was not set
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Senior Member Three Rings 1illA6's Avatar
    Aug 20 2012
    Arizona.
    Items for Sale
    what part of Az?
    anywho depends on how long the codes are cleared for, as you may know they shut the car off & turn it back on. As long as your codes are cleared when they turn it back on, you should be fine. Did it w/an old Nissan.
    Jul 13 2012
    Nogaro Avant
    Quote Originally Posted by pharkwar View Post
    Yup. Touque converter Stuck off.
    Senior Member Three Rings hcaudikeed's Avatar
    May 25 2009
    2000 A6 2.7t 6sp
    Around
    Most states, if not all, follow EPA guidelines regarding readiness. Cars MY 96-00 cannot have more than two unsupported/not ready components. 01+ no more than one. However, why not just go for inspection, fail, and then get it repaired? You'll be within the law, and have a certain amount of time to get the car repaired. And since you are, free of charge from the dealership, should not have any issues whatsoever.
    J-Fonz Tuned| F21's | CoolingMist Stage 2| Southbend Stage 3 Kevlar w/ RS4 PP| Fidanza LWFW | Bosch EV14 72# | DW300 Pump | SRM SMIC's | 034 Track Density Motor Mounts | 034 Street Density Trans & Rear Diff Mounts | 034 Bipipes | 034 85mm MAF Housing | 034 Snub Mount w/ Bracket | EFK | 710N's | Hartmann DTM 18x8.5 | 235/40/18 Cooper RS3-S's & 225/45/18 Dunlop Wintersport M3's | H&R Race Springs | Koni Yellow Sport Shocks | SSAC V-Band DP's | Milltek 2.5 inch Catback | S6 Doorblades |
    Sep 06 2012
    United States
    Items for Sale
    Ok, so you can call me a noob if you want after I ask this question......whats a readiness device?
    I would like to attempt to pass emissions so that I can essentially get it over with. Beside, I am going to register it for two years, and I would like to not think about it for that period of time.
    Sep 06 2012
    United States
    Items for Sale
    I am in the Phoenix area. I see you are in Tucson. Do you know of any independent Audi repair shops in the Phoenix or Tucson area?
    Quote Originally Posted by 1illA6 View Post
    what part of Az?
    Aug 20 2012
    Arizona.
    Items for Sale
    Quote Originally Posted by rage385 View Post
    the guys at Audis4parts! here in Tucson:)
    Brian can definitely help you out. Possibly just code out everything, to get you through emissions.
    Aug 05 2011
    Memphis, TN for now!
    Readiness means that the engine has run through certain engine diagnostics. Usually it means the engine must hit certain conditions such as warmed up and running at certain rpms for a little while. Just because the car is started and stopped and there is no CEL it doesn't mean that 'readinesss' is set.
    Take a look at the rosstech walk through on setting readiness: http://wiki.ross-tech.com/wiki/index...PB_Engine_Code
