Results 1 to 18 of 18
    Active Member Two Rings NewB7's Avatar
    Nov 15 2011
    Bay Area, Ca
    Anyone else hear the weird rubbing noise?
    Whenever I turn my steering wheel either far right or left, as I reach the end of the turning radius (for example when I park or I'm coming out of a parking spot) I hear a weird rubbing noise. Like a rubber on rubber noise. I just had my upper control arms replaced on both sides cuz they were shot. I thought this was the root of the noise but it's still there. My power steering fluid is filled properly. Anyone else experience this rubbing noise? What the hell could it be?
    Ibis S-line, APR Stage II, 034 HFC, Carbonio CAI, 034 mounts, Apikol Snub, 034 CC, STaSIS exhaust, Zimmerman cross drilled rotors/Hawk HPS pads
    Active Member Four Rings seal66's Avatar
    Aug 05 2011
    2008 Audi A4, 2005 Wrangler Rubicon
    CO-WY
    I get the same noise. I have no idea either what this is.
    2008 Audi A4 2.0T
    in progress......
    Veteran Member Four Rings DoThisMyWay's Avatar
    Aug 24 2004
    B6A4, B7A4
    Sacramento, CA
    I hear it on both of my A4s but they both have over 115k miles. I'm thinking they both need all new control arms up front.
    2006|A4 Avant 2.0T Quattro S-line
    2005|A4 3.0 Quattro UltraSport
    Registered Member Four Rings Rodmar's Avatar
    Jan 29 2012
    None
    Colorado Springs
    I hear it sometimes too and lately I "think" ive been hearing like a clunking of some sort possibly but maybe im hearing things...maybe my control arms are shot too??? How do you really know???? im only at 68k miles i mean these parts arent cheap lol
    BB DTM B7 A4/10% tint all around/Vortex splitters/Sonic Tuning LM Reps/Red painted Calipers/Hawk HPS Pads/Koni/Eibach Pro Kit/Kenwood DVD Headunit/REVO STG 1,Soon REVO stage 2/RAI DP/HFC/AWE Catback Exhaust/Show N' Go Plate holder/Ebay Mirror caps/Podi Mechanical Boost Gauge/Piston DV/1080 Carbon Fiber Wrapped Interior Trim/Krauto LED Interior Lights/B7 S4 Recaro seats/TTs flat bottom wheel/RS4 Pedals/S4 Door Blades/Drilled&Slotted Rotors/rs4 RSB
    Senior Member Three Rings Audi_509's Avatar
    May 20 2010
    2008 A4
    Eastern WA
    I took my car to get checked out for the same type of noise you're describing. Dealership said it was my tires.
    "I got a a4 b7 what size rims should i get? I dont want 18's to be too little or @0's to be too big. What should i do?" - BiGGMuRRay
    "Did you just try to capitalize the number 2?" - youngcotter
    Senior Member Four Rings DRAKLORE's Avatar
    Oct 14 2009
    '81 Mk1 VW CADDY rabbit :-) yamaha fz6r
    Robins AFB, GA
    Problem
    Solved
    Active Member Two Rings DrZEUS's Avatar
    Aug 18 2011
    B7 A4 Quattro S-Line, 1.8T Jetta Wolfsburg
    Mississauga
    ^ what did you do exactly?
    Aug 24 2004
    B6A4, B7A4
    Sacramento, CA
    Interesting... I'll have to look up there but I only hear the noise for the first couple turns. After everything is all warmed up, the noise is gone.
    Senior Member Four Rings groundround's Avatar
    Jun 19 2009
    07 a4 2.0T S-line TI pack
    somerville ma
    yea i hear it now also, prob because I am 23 1/4" GTF :)
    but maybe throw a small spacer on if it's rubbing in the inside where it arch's
    Senior Member Four Rings wildcat333's Avatar
    Feb 25 2011
    2009 Suzuki GS500F
    Seacoast NH
    yes. it makes people think my car is going to fall apart and that I don't take care of it, which sucks. but yeah, I have no idea. I don't know what is hitting what. And Draklore - pic is worthless without explanation.
    2008 Audi A4 2.0T Quattro | Light Silver | S-Line | Automatic-Tiptronic | GIAC Stage 1 | Autotech HPFP | 135 bar PRV | 35% Tint | KW V1 Coilovers | RS4 RSB | Evolution Thor Skid Plate | 6000K Bi-Xenons | Clear-Corner Mod | 6000K LED City Lights | LED DRLs | Paint-Matched Sidemarkers | 6000K HID Fogs | Interior LEDs | Rear Plate LEDs | Drilled/Slotted Rotors | Akebono Ceramic Brake Pads | Goodridge SS Lines | Spacers: 17.5F/20R | Sirius Satellite Radio Tuner | Hardwired 8500 X50
    Jun 19 2009
    somerville ma
    Quote Originally Posted by wildcat333 View Post
    Yea that rub mark is from a totally different wheel size, and height prob. The pic though is basically behind the tire, that rubber boot is the steering link.
    Oct 14 2009
    Robins AFB, GA
    Sorry guys, yeah that pic is the inner wheel arch.
    I had a rubbing noise as well during slow or extreme turning in parking situations. Pulled the tire of and noticed the tub spot.
    I can't remember if it was a wheel size or low factor though that caused it.
    Active Member Two Rings CHAUHANspeed's Avatar
    Jul 23 2012
    Bartlett, IL
    i also hear this noise in parking lots and slow turns. it feels like rubbing and i also hear it from the rear of the car!?
    Nov 15 2011
    Bay Area, Ca
    Thanks for the picture & description draklore. I'll go check mine out now
    Quote Originally Posted by DRAKLORE View Post
    Nov 15 2011
    Bay Area, Ca
    Quote Originally Posted by Rodmar View Post
    Rodmar, the noise wasn't due to my control arms as I still hear the noise now after having had them replaced. The clunking noise you are referring to could just be the front wheels fighting the rear wheels as you turn since we have all wheel drive. I usually hear a very low clunking noise when doing a u-turn. Like gears that are engaged and spinning.
    Senior Member Three Rings Mister W's Avatar
    Jan 29 2011
    2002 Jetta 1.8T
    Otterburn Park, QC
    I hear it too. But no rubbing mark inside well. CV? i'ts an AWD, it have to sound a bit like a 4x4.
    Buy my B8 S4 caliper carriers!
    2006 A4 Avant 2.0t FSI 6spd silver/blk
    Unitronic stage 1+, black Recaro, S4 front brakes, RS4 swaybar, 18" A8 wheels, Koni Yellow + eibach (not installed yet). K&N drop in, APR snub mount, latest DV revision with Forge spacer, CIM vent boost gauge, B8 style led headlights with xenarc HID... retrofit: sirius, trip/menu wiper stalk, RNS-E, oem BT,..
    Aug 24 2004
    B6A4, B7A4
    Sacramento, CA
    Changed the sway bar end links in on my B6 and no more rubbing noise. Problem solved for me.
    Aug 24 2004
    B6A4, B7A4
    Sacramento, CA
    Best thing to do is get the front end on stands, start the car and have somebody turn the wheel and look/listen for the noise. I was surprise to find that the little bushings on the sway bar end links made such a loud rubber binding noise.
