Results 1 to 17 of 17
    Registered Member Two Rings Kinzik's Avatar
    Apr 07 2012
    Florida
    Die chrome die!!! couple of pics
    So i decided to plasti dip the chrome window trim today
    as is
    took about an hour to tape because i didnt wanna get any over spray... maybe to much newspaper? to little? meh...
    sprayed about 3 coats.. everything was looking good
    i finished up the first side. i was very please with the result. very oem looking and clean. i thought i did a good job. then i open the passenger door.... the whole top piece came with it... i guess the plasti dip had stuck to inner door frame so when i opened it, all my hard work came with it. i dont have a pic of the messed up finish. i got pissed and took it all off cause it didnt look right with just the bottom black. guess ill try it again on my next day off. live and learn i guess... so pissed tho.
    74 Nova SS built 355+nitrous
    07 A4 6mt Q 2.0T
    Senior Member Three Rings AudIIan's Avatar
    Jul 06 2010
    bagged b7 a4 s-line
    toms river/new jersey
    Im selling oem titanium edition trim on monday when its removed from my car if all goes well it should be able to be re used on someone elses car, it only has about 2000 miles on it only reason im switching it is because im moving on to rs4 trim..msrp for it was 650 but i can def cut a deal on anyone interested on scooping it..pm if your interested and want the real oem thing
    Senior Member Four Rings A-BlacK_MambA-4's Avatar
    Jan 22 2011
    '02 Chevy Cavalier w/ Drift Body Kit, Weapon R header & CAI, 18" ADR 5 Spoke--'05.5 A4 2.0T Tip
    Ohio
    I did this as well unfortunately I didn't make a thread, I posted in the "What did you do to your B7 today" thread. I ran into the same problems. Our rubber door seals mate up to the car too flush (if that is a possible statement lol). It doesn't create enough of a gap for the plasti-dip to tear neatly. I was given a bit of advice that I should allow the plasti-dip to dry a bit longer and that is the reason it didn't tear cleanly (not sure how long you let yours dry? but I only let it dry for about 30-40 minutes). Anywho on the second try I cracked the doors about 5-6" and taped everything on the inside of the car of to prevent overspray.
    Here are some pics of my results:
    Now I'm just pic whoring
    -JOEL
    REVO Stage 2 | RAI Testpipe/Downpipe | ST Coils 24"FTG | Treadstone TR18T FMIC with eBay Piping | Custom Front Routed Intake with Fujita F5-300S Filter | Podi Mechanical Boost Gauge | AudiUp Race Red Snub Mount | NGK BKR7E Plugs | Custom Trans Am Hood Vents | Rota Grids 18x9.5 et38 245/40/18 | DIY Water/Meth Kit
    Next Mods: Custom Exhaust
    May 13 2012
    CO
    The top half of the trim should be sprayed with the doors open and a plastic drop cloth taped around the door frame.
    Active Member Three Rings NickDaQuick's Avatar
    Apr 14 2012
    Ventura, California
    You can never have too much newspaper....looks good! Was very happy with the results of mine as welll
    2006 Ibis White A4 2.0T
    Mods: 18" TSW Valencia ~ Street Edge Coilovers ~ AEM CAI ~ Custom Catback Exhaust ~ Magnaflow Mufflers ~ 20% Tint ~ RS4 Grille ~ Euro Plate ~ S4 Valance ~ Blacked Out All Stock Chrome ~ Tinted Headlights ~ CC Mod ~ Roof and Trunk Lips ~ Debadged ~ Hardwired Passport Escort 8500 x50 ~ Custom iPhone Dock
    Senior Member Four Rings DRAKLORE's Avatar
    Oct 14 2009
    '81 Mk1 VW CADDY rabbit :-) yamaha fz6r
    Robins AFB, GA
    3M Scotchprint on the exterior trim FTW + satin black door pillar
    And before that I had removed it all and done a mettalic gunmetal spray job :)
    Old:
    Older with gunmetal door pillar
    And I'm not sorry for pic whoring :)
    Senior Member Four Rings wildcat333's Avatar
    Feb 25 2011
    2009 Suzuki GS500F
    Seacoast NH
    drak I do not like those old yellow calipers.
    2008 Audi A4 2.0T Quattro | Light Silver | S-Line | Automatic-Tiptronic | GIAC Stage 1 | Autotech HPFP | 135 bar PRV | 35% Tint | KW V1 Coilovers | RS4 RSB | Evolution Thor Skid Plate | 6000K Bi-Xenons | Clear-Corner Mod | 6000K LED City Lights | LED DRLs | Paint-Matched Sidemarkers | 6000K HID Fogs | Interior LEDs | Rear Plate LEDs | Drilled/Slotted Rotors | Akebono Ceramic Brake Pads | Goodridge SS Lines | Spacers: 17.5F/20R | Sirius Satellite Radio Tuner | Hardwired 8500 X50
    Senior Member Four Rings fordyoz's Avatar
    Apr 20 2011
    Boston
    apologize for your pic whoring
    OP - i suggest vinyl for the door trim
    Borg Warner EFR6758 B7 A4
    Active Member Two Rings Infamouz627's Avatar
    Mar 26 2011
    Quote Originally Posted by Kinzik View Post
    as is
    Just a thought...would you have been able to run a x-acto knife along the door seal between the trim and the door to separate the two and avoid this from happening?
    06 B7 A4 2.0T Q Tip
    APR Stage I / Koni Eibach Pro FSD / 18x7.5 HD MSR / Adam's Rotors Cross Drilled and Slotted / Tyrolsport Caliper Stiffening Kit / Hawk Ceramic Pads / R8 Style Bi-xenon / DDM Tuning 6000K HID Head and Fogs / Apikol Snub / Podi Electronic Boost Gauge / Clear Side Markers / Custom Front Filler / Upgraded Piston DV / RS4 RSB / Dice Electronics iPod Kit / SEAT Cupra Lip
    Car is FOR SALE if anyone is interested feel free to PM me.
    Veteran Member Three Rings grizzles's Avatar
    is nonexistent
    Louisville, KY
    Quote Originally Posted by Infamouz627 View Post
    That works but really it's better to do it with the door open. I plasti-dipped all of my trim, decided I didn't like it a day later and ripped it off and went with vinyl, never looked back.
    Active Member Three Rings A410's Avatar
    Feb 29 2012
    2004 Pontiac GTO
    Baltimore, MD
    Also, from my experience with plati-dip, it's not the BEST material to use a razor blade on... it would prob help some, but with its "rubbery" texture, the razor will more than likely PULL the plasti-dip than it will cut it... but it's def worth a shot to prevent the same thing from happening again.
    Edit - Atleast until the plasti-dip is FULLY dried, which takes a few days.
    2008 A4 2.0T Quattro / APR Stage II / RAI Test Pipe / Custom 3" Exhaust / Spintech Mufflers / TR-11 FMIC / 034 Motorsports TIH / Custom GSG CAI / AudiUp Race Snub / 640 Mod / Various VAG Mods / New South Boost Gauge / REV E Red Coilpacks / NGK BK7RE / 200+ Lbs Weight Reduction / 18x8 GT1's / 10mm Front Spacers / 20mm Rear Spacers / RS4 Rear Sway Bar / ST Coilovers / Cupra Lip / LED Taillights / ECS Filler Plate / 20% Tint / Headlight Armor / Yellow Fogs /
    May 13 2012
    CO
    Exactly how hard is it to remove the door/window trim?
    is nonexistent
    Louisville, KY
    Quote Originally Posted by Amarao View Post
    From what I read some time ago the majority of it isn't so bad, it's the triangular windows that are a PITA. From what I remember they are riveted in and you basically have to break the old one to get the new one in.
    Apr 07 2012
    Florida
    I considered vinyl but after I've seen how clean the plasti dip looks I'm gonna try it one more time. I'm gonna use a razor blade along the seals right after a i spray the first coat(before it dries at all) and rinse and repeat each time. Hopefully it breaks away clean. I'll post some pics up when i get it done.
    07 A4 6mt Q 2.0T
    Jan 22 2011
    Ohio
    I tried a similar tactic and it didn't work. To be able to cut the plasti-dip it has to be completely dry. Otherwise it will just tear and won't be a clean line like you are hoping for. Just trying to save you the headache, the only way that worked for me was to crack the doors and tape the door openings off to prevent overspray. Good Luck!
    -JOEL
    May 13 2012
    CO
    Here's how mine came out when I sprayed with the doors open.
    Senior Member Four Rings Mc Suly's Avatar
    Aug 20 2010
    AUDI B7 slowpoke
    MONTREAL, QC, CANADA
    looks good!
    just be careful with high pressure washers, it's gonna chip!
    FLAT Black is beautiful
    APR HPFP|AWE FMIC|AWE Exhaust|RAI Motorsport 3"DP/HFC|DW300 LPFP|145Bar Rail Valve|Meth Injection Kit|034Catch Can|Stasis Coilovers|RS4 Rear Sway Bar|JHM SS|034 STUDS|S4 BBK|STOPTECH SS LINES|Stage 2 Southbend Clutch
    Unitronic: Stage 2 HPFP
    DRAKES PERFORMANCE
