Results 1 to 35 of 35
    Jun 26 2012
    Sweden
    Question Time For Timing Belt Replacement...
    It's approaching Timing Belt service on the car now. (Audi A4 2.0T 2006 220Hk, BUL)
    What do you recommend you should change except for these parts:
    *06F198119A - Timing Belt, Timing Belt Roller, Timing Belt Roller, Timing Belt Tensioner, and some bolts.
    *06D903137E - Accessory Drive Belt.
    *06B903341B - Accessory Drive Belt Roller.
    *06B903133E - Accessory Drive Belt Tensioner.
    *06F121011 X - Water Pump.
    Should you change something more?
    Sep 03 2009
    San Antonio, TX
    Quote Originally Posted by tobias_sundin View Post
    Cam and crank seals. Might as well replace them while you're in there.
    MY BUILD
    Veteran Member Four Rings mcpcartier's Avatar
    Oct 14 2011
    do your thermostat while you're in there....definitely
    2007 2.0T Q 6MT, S-Line, Ti Package, BB
    Revo Stage 2 | JHM Stage 1 Clutch | K&N Drop in | APR HPFP | 034 HFC | AWE Catback | 034 SD Tranny & Motor Mounts | Neuspeed Snub | H&R Sport Springs | Bilsteins | Moog ACA | B5 Perches (removed) | RS4 RSB | ABT Drilled n Slotted Rotors | Redstuff Front & Akebono Rear | Podi Stepper Boost Gauge | Recaro's | H&R Spacers 15f/20r | Clear Corners w/Blackout | Smoked Frt Markers | Cupra R Lip | 20% Tint
    Veteran Member Four Rings shiro1745's Avatar
    Jul 26 2009
    South Jersey
    Items for Sale
    Quote Originally Posted by sa_seahawker View Post
    OP, you could change the camshaft seal, but leave the crankshaft seal alone if it's not leaking. It's such a big PITA to put it back properly.
    If you change any of the seals have in mind you need special tools to remove pulleys. If they're not leaking I would strongly suggest to leave them alone.
    I'm surprised you don't have the thermostat on that list, it's a must.
    Good luck!
    - Chip
    K0R-GT -- S3 injectors -- Maestro tune -- IE Drop-in rods
    "It took 4 bad crankshaft seals and lots of cursing to build my avatar"
    Senior Member Three Rings adamc514's Avatar
    Sep 01 2009
    Nissan Murano
    TN
    Items for Sale
    Quote Originally Posted by shiro1745 View Post
    Good luck!
    Hmm... I didn't know that myself. I used an ECS Tuning kit the first time around and I'm pretty sure I missed that. I will be sure to do it the next service.
    Rip on it...
    Jul 26 2009
    South Jersey
    Items for Sale
    Quote Originally Posted by adamc514 View Post
    Well, let me put it that way, it's not really a must but it is if that make sense haha
    Imagine your T-stat is fine when you do your timing belt so you don't change it and then it fails after 10k miles. It makes sense to replace it while you're at it, it's only a $50-60 part.
    - Chip
    Sep 01 2009
    Nissan Murano
    TN
    Items for Sale
    Thermostat part number is 06D121111G
    Rip on it...
    Stage 3 Forum Advertiser Four Rings ECS Tuning-Audi's Avatar
    Oct 02 2006
    Wadsworth,OH
    We have a few different kits available for your car! Check them out below.
    Click HERE to order or for more information.
    **Ultimate kit pictured**
    Jason
    sales@ecstuning.com | customerservice@ecstuning.com
    Customer Service Hours: 8:00AM to 8:00PM EST
    Sales Team Hours: 8:00AM to 11:00PM EST
    800.924.5172
    OEM Audi Part Number Search with Pricing<--- Click me!
    Oct 14 2011
    Totally agree...you're 90% of the way to the thermostat while your doing this...just need to move the alternator out of the way which is cake.
    But to rip everything apart just to do the thermostat is a lot of work. You'd be kicking yourself the whole time.
    Sep 01 2009
    Nissan Murano
    TN
    Items for Sale
    those are the 1.8T kits?
    Rip on it...
    Veteran Member Three Rings abzoni's Avatar
    Nov 13 2010
    get this kit and call it a day :)
    http://www.blauparts.com/proddetail.asp?prod=GH21129-1
    GT3071R, built motor, complete fueling system upgrade etc etc.
    Jul 26 2009
    South Jersey
    Items for Sale
    Quote Originally Posted by abzoni View Post
    That's what I got, they have the rental tools too.
    - Chip
    Stage 2 Banner Advertiser Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    Timing Belt Kit (A4 B7, 2.0T)
    Receive everything required to perform a high quality timing belt replacement in your Audi A4 B7 2.0T.
    Why you should buy your Audi A4 B7 2.0T timing belt kit from EuropaParts.com:
    • All parts in this timing belt kit are OEM (or better) quality and TüV/ISO 9001 certified
    • Our team carefully selected and tested every part to ensure the perfect fit and quality
    • You can customize the timing belt kit components to fit your needs (or just go with our recommendation)
    • Your complete satisfaction is our highest objective.
    Feel free to contact us if you have any questions about this Audi A4 B7 2.0T timing belt kit. We look forward to hearing from you.
    RECOMMENDED Timing Belt Kit Components:*
    1 x Timing Belt (2.0T FSI) +$39.15 (Continental, 06D109119B)
    1 x Timing Belt Roller +$39.15 (INA, 06D109244E)
    1 x Timing Belt Roller +$9.75 (NTN, 06B109244)
    1 x Timing Belt Tensioner +$78.35 (NTN, 06D109243B)
    1 x Crankshaft Seal (35x48x10) +$2.44 (Elring, 038103085E)
    1 x Water Pump (2.0T, Metal Impeller) +$48.95 (Geba, 06F121011)
    1 x Accessory Drive Belt +$17.59 (Continental, 06D903137C)
    OPTIONAL Timing Belt Kit Hardware:
    6 x Bolt (M8x16) +$5.59 (Genuine Audi VW, N91143901)
    1 x Bolt (M8x45) +$1.42 (Genuine Audi VW, N10268304)
    1 x Nut (M8) +$0.93 (Genuine Audi VW, N01100845)
    1 x Washer (M8) +$0.54 (Genuine Audi VW, N0152785)
    OPTIONAL Timing Belt Kit Components:
    1 x Thermostat (A4 B7, 2.0T) +$48.95 (Behr, 06D121111G)
    1 x Genuine G12 Plus Plus Engine Coolant (1 Gallon) +$21.51 (Genuine Audi VW, G012A8G1G)
    1 x Timing Belt Service Sticker +$3.42 (Genuine Audi VW, 059010158A)
    Hubert
    EuropaParts.com, Your Trusted Audi Parts Source
    Phone: 800.877.7033 x 101
    Email: hubert@europaparts.com
    Facebook: Like Us on Facebook
    Jul 17 2012
    2003 toycamse w/150kmiles
    Bowie/Maryland
    if a shop is doing it add the ferrera lifter shims, the camshafts' bolts, valve cover gasket, and chain tensioner. (everything else is apart, might as well, no?)
    Veteran Member Four Rings FraggyA4's Avatar
    Mar 03 2012
    Jeep Comanche
    Thief River Falls, MN
    Items for Sale
    I went with Europa and it was perfect for the job. The only thing that would have be nice would be replacement clamps and bolts. I highly suggest that you replace your clamps on your thermostat as mubea clamps are one time use, at least they are supposed to be. I had leak issues till the heat from the engine eventually sealed the hoses back up to the thermostat. Also check to see if your DV is up to date, if it isn't you should replace it then. makes the jobs super easy.
    Good Luck
    -Chadwick
    FULLY BUILT ENGINE!
    Mar 03 2012
    Jeep Comanche
    Items for Sale
    Quote Originally Posted by davvinchi View Post
    You shouldn't be removing any of the top end to do a timing belt change.
    -Chadwick
    FULLY BUILT ENGINE!
    Nov 13 2010
    Quote Originally Posted by FraggyA4 View Post
    judging by his posts over the past couple of days he's itching for an excuse to remove his top end lol
    Mar 03 2012
    Jeep Comanche
    Items for Sale
    Well don't let him see the thread by IE that has all the pictures of there upgrades, that shit is like heroin!
    -Chadwick
    FULLY BUILT ENGINE!
    Oct 14 2011
    Those kits are a great deal....I think I paid more without the thermostat way back when. Hopefully the prices holds steady until I need to to it again....about 60K miles to go :)
    Veteran Member Three Rings midnight407's Avatar
    Oct 21 2011
    Brilliant Black B7, '06 STi borrowed/stolen from the roommate
    Northcenter/Ravenswood Chicago
    my dad randomly sent me a conti t-belt kit....anything i should get besides what's in the box on that? From what I googled, "Kit includes: Water Pump with Plastic Impeller, Timing Belt, Tensioner, Idler Pulleys. Cam Seal and Bolt - (Interference Engine)"
    midnight407
    (Mine) 2005.5 Audi A4 2.0T quattro Tiptronic | Brilliant Black | Ebony | Stage 0+
    Stuff: 034 Motorsports | ECS Tuning | techtonics tuning | JOM | TSW | Forge| Zimmerman | Viper | Kicker
    (Hers) 2006 Honda Pilot EX 4WD | Steel Blue Metallic | Gray Cloth
    Stock
    Chicago, IL IG: @bobgraybar
    Nov 13 2010
    you're like the guy that goes to rehab to deal drugs xD
    Oct 16 2008
    South Florida - Ft Lauderdale
    Items for Sale
    Quote Originally Posted by Hugh@EuropaParts View Post
    Best and most complete kit on the market, hands down
    Phil
    Mar 03 2012
    Jeep Comanche
    Items for Sale
    I may have just opened pandora's box
    -Chadwick
    FULLY BUILT ENGINE!
    Veteran Member Four Rings A-BlacK_MambA-4's Avatar
    Jan 22 2011
    '05.5 A4 2.0T Tip Revo Stage 2; Wifes 2013 Chevy Cruze
    Ohio
    Surprisingly didn't see this posted yet, but a good bolt out kit is handy to have around as well. 4 of the 6 crankshaft pulley bolts stripped out on me during my TB job. Bolt out kit removed them all. Got my kit from Blauparts as well, very nice kit with instructions but nothing more detailed than what Phil posted in his DIY. Thanks again Phil, You Rock!
    -JOEL
    The Real Black Mamba
    Jul 17 2012
    Bowie/Maryland
    d@mit, what do I do!! I so want to get everything!!!
    Oct 16 2008
    Items for Sale
    Quote Originally Posted by A-BlacK_MambA-4 View Post
    Your welcome
    It seems that this specific DIY helped a lot of members. Might ask for some rights soon :)
    Phil
    Mar 03 2012
    Jeep Comanche
    Items for Sale
    Sorry...better get a second job to feed the addiction
    -Chadwick
    FULLY BUILT ENGINE!
    Jul 26 2009
    South Jersey
    Items for Sale
    Your welcome
    Phil
    It really helped, I used it too
    - Chip
    Nov 13 2010
    Phil
    Phil any reason why you'd get the Europaparts kit over the blauparts one?
    Oct 16 2008
    Items for Sale
    Because when I did my timing belt (by the way time to do it again soon), this was the only kit that was including the 6 camshaft bolts and the reminder sticker.
    Yes, you can call me anal :)
    Phil
    I have used 2 of the Blau kits on my car and everything was top notch.
    Jun 26 2012
    Sweden
    Ok thanks for all the great feedback.
    I will add the Thermostat and the Crankshaft Seal to my list.
    I will leave the car at the garage where i work,
    and will also buy all the oem spareparts there.
    Because i work as a Audi/VW certified spareparts dude or what you call it.
    Senior Member Three Rings Khaotic's Avatar
    Feb 21 2011
    2001 Audi A4 Avant 1.8T Quattro
    Sweden
    Phil
    +1
    Got my kit from EuropaParts just a few days ago, great service even to Sweden! :)
    2007 Audi A4 Avant 2.0 TQ 6MT S-Line
    Exterior: Bi-Xenon Retrofit | 30% Tint | KW V2 Inox | 19" VMR 701
    Interior: LED Lighting | Black Headliner | RS4 Shiftknob | oCarbon Trim | TTS Steering Wheel | Audio build
    Engine: REVO Stage 2+ | STaSIS Exhaust | R.A.I HFC | Custom CAI | AWE FMIC | HPFP Stage 1 | RAI Catch Can | JHM Flywheel & Clutch | USP Metal Slave & Clutch Line | JHM SS Trio
    Jun 29 2013
    okc
    i am sorry but when do we change the timing belt? the owner i bought the car from i said i dont have to since it is made for the lifetime of the car. I got b7 2006 with 60k miles. i think the seller lied to me.
    Mar 24 2013
    A7
    Griswold, CT
    These belts are most definitely NOT lifetime parts. Audi service interval is 110k IIRC. The general consensus is to change them earlier than that. You're still fine at 60k, but you will probably want to change it in 20-30k miles. The seller either lied to you or was just ignorant.
    -Adam
