I used these tools :
8mm socket
10mm socket
small flat head
cutter
philip screwdriver
First Open the Fuse Box
connect the black wire (from the turbo timer) to the nut for ground
you will see the first bolt. (there all 3 bolts)
Second Bolt (located above the hood release)
Third Bolt (located above the gas pedal)
[IMG]http://us.f2.yahoofs.com/bc/42504c7b_820d/bc/tt/bolt3.jpg?
BCgPRlCBp47Qft.c[/IMG]
Once you take down all 3 bolts. Pull toward you and it will release.
then find the obd 2 connector
Connect the Green wire (from the turbo timer) to the black / blue wire. The Green wire is the IG1 output from the turbo timer.
The Blue wire you can cut it off or just leave it. (Don't needed)
From there look inside and you will see these :
look for the red wires (about 5 or 6 is connected to one bolt)
Take your Red Wire (from the turbo timer) splice the wire and connect it to the bolt. (that bolt is 10mm)
When thats done go to the rear seat
Take the ashtray out
You will see the brake sensor it has 3 wires.
Take your gray wire (from the turbo timer) and connected it the brown / white wire.
Now open the hood and located the coolant reservor
use the philip screwdriver to take the nut out.
(slightly lift it up and pull it toward you.)
The O2 sensor connector is the far right.
Take your white wire (from the turbo timer) and connected it the red wire.
After doing that install the turbo timer (where ever you want)
now start the engine and enjoy your apexi turbo timer.
