Results 1 to 9 of 9
    Senior Member Three Rings ken5018's Avatar
    Oct 17 2010
    B6 S4, B6 Passat VR6 Wagon
    Denver, PA
    Airbag light on after Steering wheel swap . . . HELP
    So tonight I decided to swap my OEM steering wheel for a b7 rs4 flat bottom. I followed the DIY step by step the only thing I didn't do was swap out the control module because the RS4 wheel doesn't have multifunction capabilities with a b6 s4 (I am pretty sure but could be wrong). So I go in and try and clear the airbag light but it doesn't go away. The code is 00588-001-upper limit exceeded. Anyone that can help?? I unplugged everything and plugged everything back in but it still doesn't go away. Any help is appreciate!
    -Kyle
    04 NOGARO S4
    JHM 93 Tune|FI non-res CB|Milltek Catless DP|K&N Air Filter|H&R Coilovers|Hotchkis F&R Sway Bars|18" OEM BBS CH|Tint|BiXenon Ecodes|Yellow Fogs|RS4 Flat Bottom|RS4 Pedals|RNS-E|Red Interior Lights|oCarbon Blue Trim
    Senior Member Four Rings Axel-'s Avatar
    Jan 29 2011
    Toronto, CA
    Hasn't it been established that putting a two stage airbag system into a one stage system is a bad idea?
    Sprint Blue B7 S4 Avant 6MT - 421whp/350wtq
    JHM Stage 1 Supercharger - Stern Motor mounts - JHM IM - JHM Stage 4 clutch - JHM LWFW - Stoptech ST-60 BBK - KW v3 Coilovers - Apikol Rear Diff Mount - JHM "Trio" shifter - Trexturk DP - Magnaflow CB - Hotchkis 29mm RSB - JHM Intake Spacers - TT-RS MFSW - 034 Adj. FUCA - RS4 Pedals - Zada Tech Gauges - STE Gauges - Dynavin D99 Android
    Senior Member Four Rings s4buckeye's Avatar
    Dec 21 2008
    '11 Cayenne S, '10 M3, '10 Yukon XL
    Kali
    Registered Member Four Rings B6JoeS4's Avatar
    Sep 13 2008
    Terminator Cobra
    Chicago NW Burbs
    Pretty sure you need to use the B7 ring
    Nov 09 2007
    Australia
    Go for a drive, find an open area then turn the wheel one way and do a 360 degree turn, then do a 360 turn the other way. Light should then disappear.
    Oct 17 2010
    Denver, PA
    billq - I will give that a try.
    B6JoeS4 - I did replace the ring but not the control module.
    Axel and s4buckeye - Yes I know I kept changing my mind for about a year and I finally decided to do the swap (Hopefully that won't be me in the picture) My S4 isn't my daily and I barely even put 5k miles on it a year so I figured chances are if I were to get into an accident it would be my daily. So yes I know I am taking my life into my own hands.
    -Kyle
    04 NOGARO S4
    Oct 17 2010
    Denver, PA
    Just tried what you suggested billq didn't work. Any other ideas out there?
    -Kyle
    04 NOGARO S4
    Nov 04 2011
    reedy
    Quote Originally Posted by ken5018 View Post
    HAHAHAHAHAHAHAHAHAHAHA Perfect
    Apr 12 2009
    Well everything is plugged into the control module, I would say you need the module. I just did a B8A5 wheel swap into my B6A4 and it worked perfectly, swapped the ring, module, did the coding and worked perfectly first time. Easy Peasy!
