Results 1 to 14 of 14
    Oct 04 2010
    Kearneysville West Virginia
    engine rebuild help
    Will a 06a block work for a awm engine rebuild?
    Dec 05 2007
    The AWM is an 06A block. ATW and AEB are 058.
    I hate it when my car acts like a little bitch, treating me like the bitch
    Oct 04 2010
    Thought the awm was a 06b
    Senior Member Four Rings howardfootball's Avatar
    Oct 20 2010
    '57 Ford Thunderbird
    Naboo
    Quote Originally Posted by Scottydo View Post
    No such thing.
    Tyler
    Buy My GTI!
    Instagram: @itsbigty
    Senior Member Four Rings redline380's Avatar
    Oct 30 2008
    2000 Chevy 3500 454 w/9'2" boss vplow
    St. Cloud, Minnesota
    ^yes such thing. but for op, as far as i know, any 06a block will work. this means you are open to jetta's, beetle's, passat's, and newer a4's. i currently have an aug block out of a passat in my car. although the engine codes are different, the blocks are the same. its the stuff that attaches to the block that is different.
    Look dad, it's the good stuff, none of that pussy skoal- Joe Dirt
    Registered User Four Rings
    Feb 08 2011
    B5 A4 2 liter GT35r and trailer
    Phoenix, Arizona area
    Quote Originally Posted by howardfootball View Post
    no such thing.
    2.0t FSI/TSI = 06B
    Oct 20 2010
    Naboo
    Quote Originally Posted by M-Hood View Post
    2.0t FSI/TSI = 06B
    Maybe I should spend some more time in the B7/8 forum. I have never heard of anyone talk about an 06B before.
    Tyler
    Buy My GTI!
    Oct 04 2010
    Another question i had was once i rebuild the engine how do i set the timing on it?
    -scott
    Oct 30 2008
    same as everyone else. ha but really if youre briging the head in to the shop to get checked, have them install the cams. it will save you a ton of hassel. then set the crank to tdc and the cam gear to tdc. its pretty simple as long as the cams ar set, which can be tricky
    Oct 04 2010
    Got ya I have no problem setting the crank setting the cams is what is confusing me
    Dec 05 2007
    I am currently semi-rebuilding my engine (new rods, pistons, piston rings, rod bearings, hone, cylinder pressure test, cylinder deck, surfacing block myself, short block still in engine). Dropped the cylinder head off to the machine shop today, and he is doing that part for me (dismantle and reassemble for pressure test). I marked on the cam gear with a mark on my belt. Did the same for my crank gear. This way, can't really goof on setting the timing correct. Told the machinist about my mark and not to remove it. He understood completely.
    Oct 30 2008
    yeah the cams are fucking tough. i tried doing it myself, with a homemade tool, and when i finally got the damn things in there, i was very unsure of whether or not there were 16 links in between the marks. keep in mind, the 16 links isnt actually alwasy 16 links. its confusing. i just said fuck it, im takin the head in to get pressure tested anyways, ill just have them put the cams in while they are at it. next time, i'll buy the actual cam chain tensiion tool. it would make it a whole hell of a lot easier
    Oct 04 2010
    okay so i guess the appropriate question is since my crank and my block are new how do i ensure my cams are matching up to tdc on my crank? Mabey ill go down to stasis and have them do it.
    Senior Member Three Rings thenj3's Avatar
    Dec 25 2009
    North Jersey
    Once the cams are properly set, you lime up the mark on the crank gear to the mark on the block and the mark on the cam cover to the mark on the valve cover. it would be like following a timing belt job
    2001 2.0l ct-5858 build in progress- ringer racing, full race, comp turbo, maestro= hopefully 500wheel
    Turbo Lag = The amount of time the competition can see you laughing before you spool up and pass them.
