Page 3 of 3 FirstFirst 123
Results 81 to 103 of 103
  1. #81
    Jun 14 2007
    Connecticut
    Quote Originally Posted by Josh@J-Fonz View Post
    We didn't run a 12.38@116 on k03's with 93+meth by playing in the efficiency range :)
    Where and when did you run that?! Awesome driving by whoever and that is a sick trap for K03s.. That may be the record no? Bertwerks @ JHM held the ET record for K03s for a while now, the trap must have been right around there.
    Piggie Powered Stage 3 B5 S4 | Flickr | Videos
  2. #82
    Active Member Four Rings Meow's Avatar
    Mar 08 2012
    MI
    holyshitballs
    that is faster and quicker than what I ran with rs6's... balls to the walls driving with a good 60ft and shifts and a hell of a tune I guess to get that time out of little old k03's. Bet they wont last long at that power level though hahaha.
    Threads, Videos, Events:
    2000 BB B5 S4 | Videos | NoWö @Facebook: Northern rthersee |
  3. #83
    Senior Member Four Rings
    Feb 26 2011
    las vegas
    17psi on k03's isnt THAT bad.
    Silly Rabbit, what a stupid name!
  4. #84
    Senior Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Brilliant Black 2001.5 S4
    Pittsburgh PA
    Quote Originally Posted by itguy View Post
    20-21 is lol
    brilliant black 2001.5 s4 built bottom end stage 3+ on e85
    Can't we all just be happy.
  5. #85
    This is my buddy dave's run on the old Ft F4's... let off at the end cause the car didn't feel right. Blew a wg line at the end of the run, great time, just explaining the relatively low trap.
    Username Dave @ savage motorsports
    Car - b5 s4 full interior.
    Trans- 01e 6 speed
    Oct - 93+meth
    Tune - J-fonz basefile/ Dave @ savage motorsports dialed it in on the dyno
    Downpipes/Catback-custom 3" dp's ssac twin
    Turbos - Frankenturbo f4h
    Shot - n/a
    1/4 ET- 11.768
    1/4 MPH - 116
    60' - 1.68
    Other Mods-driver mod
  6. #86
    K03's @23psi
    93+meth
    2.5 in. dps' and catback
    upgraded smic's
    J-Fonz tune
    one hell of a driver.
    pass was from last year.
    Run @ empire Dragway in NY
    Turbos with 130k on them previously GIAC chipped lasted 6k miles on this file before they blew.
  7. #87
    I personally was running around with a 21-22 psi file on my s4 for about a year..
  8. #88
    Jun 29 2010
    Ottawa
    I pm'd one of you guys at jfonz, can whoever is online send me a pm to talk about some turbos i need
  9. #89
    Aug 18 2010
    ROC New York
    WG line, 2 coil packs, and three injector seals were destroyed on that run. Antilag is bad lol
    Trans- 01e 6 speed
    Oct - 93+meth
    Shot - n/a
    1/4 ET- 11.768
    1/4 MPH - 116
    60' - 1.68
  10. #90
    Quote Originally Posted by Watson View Post
    Pm replied
  11. #91
    Jan 06 2007
    01/02 S4, '04 Mazdaspeed MX-5
    Virginia
    Typically we start at 22 psi on the base file for reliability/ shakedown of the car. The recomended boost levels are 23 taper 22 as the comp map is a little nicer to work with.
    How are you determining the PR to plot on the compressor map?
    Stock -> APR Stg1/2 -> GIAC Stg2 -> APR K04 Stg3 -> EPL/TiAL 605 -> V̶A̶S̶T̶ EPL/Frankenturbo F4H -> In Progress
  12. #92
    Stage 2 Banner Advertiser Four Rings Doug@FrankenTurbo's Avatar
    Oct 19 2009
    Gary Fisher Sugar 2+, Trek HiFi 29er
    Westchester County NY
    ...as in "how can you know what the pressure is when above 22psi"? Or are you speaking to the plotting method?
    FrankenTurbo
    Let's Do This
    AKA: slappy_dunbar
  13. #93
    Jan 06 2007
    Virginia
    Quote Originally Posted by slappy_dunbar View Post
    As in, how do you know what the vacuum is at the compressor housing inlet and the pressure at the compressor outlet at any MAP sensor reading? I basically am guessing when I plot on the compressor map because I'm assuming what the pressure losses are pre and post turbo.
  14. #94
    Oct 19 2009
    Will the Zeitronix accept a second MAP pressure sender? If so, tap into the charge piping ahead of the intercoolers. That's where your true compressor outlet pressure lives.
    FrankenTurbo
    Let's Do This
    AKA: slappy_dunbar
  15. #95
    Feb 26 2011
    las vegas
    im doing this next week, yes they take 2 sensors.
  16. #96
    Jan 11 2007
    SLC,UT
    Beat me to it ha.
    ** GT2860R-7 S4 Build Log--
    FOR SALE:
    --JHM DELRIN SHIFTER STABILIZER BUSHING (LATE STYLE)**
    --RS4 AIRBOX--
    LOOKING FOR:
    --Your Fuel Tank Lid and Fuel Pump Baskets--
  17. #97
    May 16 2008
    WA
    Quote Originally Posted by Sales@J-Fonz View Post
    then did they finally let go, or you just ended up going bigger at that point?
  18. #98
    Senior Member Three Rings Angular's Avatar
    Oct 25 2010
    2002 S4 Avant
    Area code 253 (WA)
    Bent fins, looks like FOD (foreign object damange) to me.
    2002 S4 Widebody AvantFOR SALE: Front-front Lower Control Arms (2 pcs) for steel uprights, PM for details
  19. #99
    Mar 08 2012
    MI
    Quote Originally Posted by Angular View Post
    the fins are notorious for damage when used at high boost for prolonged periods of time. lots of 22 psi time on k03's will bend the fins/damage them. This is is a pic of one damaged due to pushing the limits of the stock turbo IMO. though FOD can look very similar.
  20. #100
    Quote Originally Posted by Meow View Post
    Yep, if you notice there are no chips or gouges on any of the fins.
  21. #101
    H20 time is closing in!!!
  22. #102
    Senior Member Four Rings topquarkpc's Avatar
    Aug 03 2009
    PNW
    will there be H2O sale for the tunes??? like you had the July / August sale...???
    TIA...
    01 Casablanca White Avant (stage 2+) Auto for Her...01 Imola Yellow Avant (stage 3) 6-Speed for Him...
  23. #103
    Oct 06 2009
    VW Passat 1.8T GT30R
    Hull, United Kingdom
    How much to ship these to UK
    B5 S4 Franken Turbo
