Results 1 to 8 of 8
Thread: Fuel Question
    Jun 13 2012
    VA, USA
    Fuel Question
    I was reading the manual and recommended fuel type is 91 or higher. For a stock 3.0 T with no mods, does using 93 octane fuel make any difference?
    - 2011 A6 3.0
    Active Member Four Rings SinCityA6's Avatar
    Jul 17 2011
    Sin City, USA
    On a stock motor, there is negligible difference between 91 and 93. Generally, both are not available in the same area anyway.
    '09 A6 3.0t Ibis White/Black Int; Clear Bra, 15% Tint, Smoked Corners, DeBadged w/Black Rings, Tinted Tails, Roc*Euro Intake, H&R Springs/Sways, Adams Rotors, Akebono Pads, Interior/License Plate LEDs, € OEM 4 Spoke Steering Wheel w/Paddles, S6 Door Blades
    VAGCOM'd: "ROW" Rear Turn Signals, Windows Up & Down w/Key Fob, Gauge Sweep, Fogs w/Highbeams, Lap Timer/Hidden Menu, Seat Belt Chime Delete
    Next: ECU Tune, Exhaust, oCarbon Trim
    Senior Member Three Rings OmaHahn's Avatar
    Apr 07 2011
    1964 1/2 Ford Mustang, 2012 Limited Tucson
    Omaha, NE
    +1 AND..... make sure there's NO crap Ethanol in the gas!!!! Most of the 93 Octane fule has 10% Ethanol which is the EXACT same Octane percentage/ratio you will find in a 91 Octane with NO Ethanol.
    2009 A4 Premium Plus 3.2
    https://www.youtube.com/watch?v=hujY4dBQt1I | S5 Wheels | General G-Max Tires | H&R OE Springs | License Plate LEDs | Hoen Endurance Fogs | LED Interior Kit | Under-door LED Units | VCDS Mods | Programmed Tails to ROW w/Amber Signals | 20% Window Tint | Carbon-Fiber Audi License Plate Brackets
    Jun 13 2012
    VA, USA
    Quote Originally Posted by OmaHahn View Post
    I think all 93 octane fuel around my area has 10% ethanol. I will have to pay closer attention. Thanks for the heads up.
    - 2011 A6 3.0
    Registered Member One Ring pesticidal's Avatar
    Aug 02 2012
    2005 Porsche Boxster S, Yamaha V-Star 1100
    Fargo, ND
    It's nearly impossible to find non-ethanol fuel here. In Minnesota, it's mandated. grrr.
    Active Member Two Rings MojaveA4's Avatar
    Nov 15 2007
    2008 Corvette
    Temecula, CA
    I was going to say the same thing for California. Good luck
    May 20 2012
    '13 A6, '12 Fiesta, '08 Mazda3, '07 Odyssey, '00 Accord V6
    As posted here in another thread...http://pure-gas.org/
    Senior Member Two Rings ChipB's Avatar
    Nov 04 2009
    '12 A6, '11 335i Convertible, '07 Cayman S
    Naperville, IL
    I don't understand what you're trying to say. 93 octane is 93 octane, end of story, and ethanol actually has higher octane than gasoline. The only real issue with ethanol is that it has lower energy content than gasoline, so a 10% mix of ethanol will give you about a 3% decrease in gas mileage. But there's no issue with the octane rating.
    To the OP's original question - as long as you use fuel rated to the car manufacturer's minimum octane recommendation (which is 91 of Audi in the US) you will optimize performance. There is no gain in buying 93 octane over 91. One other point - Audi recommends the use of gas brands that meet "Top Tier" guidelines - see: http://www.toptier
    '09 S5: Tech Pkg, Nav, B&O Sound, STaSIS/Ohlins SL Suspension w/ Adjustable Coilovers
