Three Rings
For those who are familiar with the snub mount assembly, your assistance please.
The front rubber mount metal bracket here: http://www.google.com/imgres?um=1&hl...9,r:1,s:0,i:79 gets bolted to another metal assembly that's bolted onto the car. It has the metal braces (2) that come from each side of the oil pan and bolt to it. This assembly on the drivers side is bolted to the car via an ~8mm allen bolt, and to the passenger side via a self aligning pointed stud and ~8mm nut around the crank pulley. It also helps secure what appears to be the ac belt tensor, so this stud is working double duty holding it and this assembly. This stud is my problem and questions are pertaining to it as it's currently my only trans, and I can't take off the entire front end of the car for inspection till I have parts to fix it as I'll be stuck home once I start to tackle it.
So, the nut is missing and the stud appears to be ~broken as it just spins. Whether it's stripped, or snapped off in the ~block has yet to be determined either way has to be replaced. So,
- Is this stud an actual bolt coming from the back side? If so, is it accessible?
- If a stud (and as I'm not going to find one of those) any idea of thread and pitch to run a bolt......or will the threads be backwards due to it being a stud?
EDIT: There's a link ~2 posts down that has a picture of that stud assembly.
Having a bucket that runs 12's is like saying you have a 200lb girlfriend but she's good in bed.
Senior Member
Three Rings
If I remember correctly, its just threaded into the bolt. I removed mine, when I was cleaning up my motor, and have no use for it since Im running a fmic and no snub mount. Honestly dont remember the thread pitch, but its not a reverse thread into the block.
1998.5 A4 1.8TQM / FrankenTurbo F4H-L / C2 Motorsports Tuning / 440cc Injectors / C2 Billet 3" MAF Housing / Cat Delete / Vibrant Muffler
2003 A6 3.0QA
Three Rings
Wut? You don't run a front motor mount?
So! I kinda found a picture:
http://www.ebay.com/itm/VW-B5-1-8t-A...7#ht_662wt_754
In the upper right is a groove (this actually sits with the groove pointing down), in this groove that stud comes through and you lock down an ~8mm nut. Anyone have other ideas about the studs replacement or if a bolt can just be run into it (and by it, I believe is the block itself)?
You can see this bolt laying there by the notch, that is the one I need.
Senior Member
Four Rings
Why the hell are you not running a snub mount? Do you like drivetrain slop?
Senior Member
Four Rings
I thought this would be a simple answer, but ETKA gives only mystery for this particular bolt. I found some photos that may help:
The first photo is during a build and the front plate is not installed. ETKA lists the front plate and says to "also use" the following parts:
8D0 199 228 B
N 010 241 18
N 011 008 30
N 900 577 03
The first item I cannot find any information on. That could be our mystery stud. The next 3 parts are a bolt, a nut, and a washer. I believe the nut and washer are probably for the stud. The part number for the bolt probably refers to the bolts on the upper left side that hold it to the block. As shown here in the larger yellow box:
For completeness, here is the same view of the right side. The small yellow box is the stud in question here:
*Credit photos from this thread: http://www.audizine.com/forum/showth...-Mount-Ordered
I'm quite disappointed in ETKA at the moment for making a big pile of fail all over this bracket.
2001 Laser Red A4 1.8TQM, 5-Speed Swapped, APR 93, Splitter, electronic oil pressure gauge, B6 Sport 17's, ST Coilovers,
Need to borrow a Cam Chain Tensioner Tool? $4 for shipping. PM me. *Unavailabe*
Three Rings
Well holy thanks batman! If that isn't a great response! Thanks!
Four Rings
walky usually has the answers i need. he is the wiki of technical data on these cars.
2001 A4 Avant 2.0t comp CT4 5858 Maestro Tune
2012 Volkswagen CC TSI 6 speed.
Senior Member
Three Rings
If you need that bolt/stud, Ill try to find mine and send it to you. As for no snub mount, its been gone for over a year now, and I honestly dont notice any difference without it.
2003 A6 3.0QA
Senior Member
Four Rings
Really? Wow, I would think it would be horrible slop. Mine is almost deteriorated and it is very noticeable.
Senior Member
Three Rings
With a 4cyl, I honestly dont think there is that much movement. I mean look at the majority of the V8 muscle cars out there making huge amounts of power, and they dont even have front mounts from factory. Thats just how I see it though. As long as your side motor mounts and trans mounts are good, I dont see too much fuss about it.
2003 A6 3.0QA
Registered User
Four Rings
The snub is pretty much just there as a pivot point, if the motor/trans mounts are stiff there isn't going to be much movement side/side or up/down just a twisting motion.
I used to run without a snub with my solid mounts, but then put one back on.
Registered User
Four Rings
Wow I thought those pictures looked familiar when I first saw them. lol
I was going to take more pics yesterday since my car was up on stands but didn't notice the bolt he was talking about.
Three Rings
Hey Mike, thanks for the call back regarding the Stern snub, unfortunately need to have one by the 1st. Next time...
If any one has that bolt I'm Paypal ready! That's something that can't be replaced at the local hardware store and mine appears snapped in half.
Senior Member
Four Rings
It is all just M8x1.25 equipment. You could definitely make something happen with stuff from the store if you wanted. Probably not quite as easy as using the stock stuff, because you'd have to come up with the right spacer thickness and such.
Three Rings
Well then, $5 with ~10 variations of M8x1.25 studs and bolts from Ace Hardware will work, return the rest afterwards. Thanks for the mm & pitch, with out it it's a fogetaboutit hassle, as it's a large guessing game.
- You may not post replies
- You may not edit your posts
Forum Rules
