Results 1 to 12 of 12
    Jul 23 2012
    Michigan
    2003 1.8t, rough idle, misfire codes, HELP PLEASE
    I have a 2003 1.8t, 140,000 miles. recently on a 200 mile trip it started to idle rought and the CEL came on. It read misfires on all cylinders and a lean code. I smoke tested it and found that the 90 degree elbow in the pcv system was leaking, fixed that, and it still is idling rough, but it didn't through the lean code any more, just random misfires. I cleaned and inspected the MAF, it seemed to be clean but i cleaned it anyways. that didnt change anything. I tried unplugging the MAF while it was running, still idles the same rough way. I'm at a loss as to what to check next. with the car running there is some suction on the oil fill cap, but nothing like what people say they experience when they had PCV problems. What possibility could cause the rough idle. Can a bad coolant temp sensor cause issues like this, how about o2 sensors. I plan on re smoke testing to make sure there is no more vacuum leaks tomorrow. i will also check the fuel pressure to see if the pump could be going bad. i really neeed some help with this one. thank you, and ps, the car runs fine when your driving, it only misfires when it idles.
    Feb 13 2004
    2007 Honda Element SC
    Silicon Valley, CA
    coils and plugs.
    Are you getting any CEL now and any codes? If you have a code on one particular cylinder, swap that coil to another and see if the code follows to that new cylinder. If not, do the same with the plug
    Kevin - Moderator, Audizine
    2011 A4 Avant Meteor Grey/Black, Titanium Package, Prem+ Nav, B&O. Euro LED Tail Lights, Tint, LED license plate lights, LED interior lights, custom sub, lots of VAG updates, Eurocode Alu Kruez, Hotchkiss F/R Swaybars
    Build thread: http://www.audizine.com/forum/showth...ead?highlight=
    Jul 23 2012
    Michigan
    i just replaced all 4 coils a month ago, new plugs 10,000 miles ago, and it shows its misfiring randomly on all cylinders. it will sometimes have a high idle, then drop back down to about 800 rpm and idle rough.
    Jul 23 2012
    Michigan
    i talked to a friend of mine who works at an audi and VW dealership, i noticed that i also threw a ECT sensor 1 code, high resistance. He said that i need to replace the coolant temp sensor behind the head, it sends signals to the ECU to help controll fuel and air ratios, and if its wrong, it will cause similar problems as to what I'm having. Has anyone else ever seen this problem?
    Jun 27 2011
    Items for Sale
    Faulty rear CTS is VERY common and could definitely be at fault here. If you're replacing it it would also be a good idea to replace the Rear Coolant Flange. Its just one of those "while you're in there" things. Yea its a pain but doing both at the same time saves some repetitive work down the line.
    Also just because your PCV isn't leaking, doesn't mean its functioning correctly. I was having rough idle issues until I replaced my entire PCV system with a full 034 Motorsports Silicon PCV kit and went through and replaced every check valve in the vacuum system. Its been idling perfectly ever since.
    Motor mounts and Snub mount could also be culprits for a rough idle, but in my opinion, the PCV stuff is most likely.
    -CP
    2008 Brilliant Black Unicorn (2.0t S-Line Ti 6MT Avant) - Bosch FR6KPP332S plugs - Q5 Rear Aero Wiper
    2012 Q5 2.0t - Stock Mommy Missile
    Former USP CLUB MEMBER #136
    Jul 23 2012
    Michigan
    I'll definatly replace the sensor tomorrow, the flange was replaced when i had my head gasket replaced but i dont think they changed the sensor. also how can i check if the pcv system is working? i was looking at other forums and I've seen many threads about people removing alot of the vacuum lines, and the pcv and prv valves. they had diagrams and everything and it looked pretty good and simple when its done. and i probably will see if the check valves are working right and if its still idling bad tomorrow after the sensor, I'll order the parts for the pcv system probably, I really hope the sensor fixes it though. The pcv system seems to be working right, slight vacuum on the oil fill cap, not dificult to remove cap at all, which seems to make since from everything i've read about the pcv system, it holds a slight vacuum in the crank case.
    Aug 26 2005
    Quote Originally Posted by irunktm View Post
    Common problem. Replace the sensor first.
    Unless you want to open a can of worms, and make the situation a lot more complicated, do not modify the vacuum hoses or the crankcase ventilation/PCV system. The CV/ PCV system needs maintenance regardless. Make sure all the hoses are tight, and that none are cracked or split. Clogging will cause problems with the PCV system also, evidenced by high crankcase pressure and oil leaks from the engine gaskets and seals. Leaking or clogged vacuum or PCV systems hoses and loose hose connections will cause hard starting and rough running engine problems also.
    Check the function of the several check valves in the vacuum system. Air flow through the check valves must be one direction only. If removed or replaced, make sure the check valves are reinstalled in the same flow direction as originally installed.
    The slightly negatibe pressure you described at the oil fill cap, indicates the crankcase ventilation system is working correctly.
    Vorsprung durch Technik
    Veteran Member Four Rings A4Maine-iac's Avatar
    May 03 2010
    2013 GLK 350 / Silver 08- A4 Kids Size - Kaylah Sticker Mod
    Maine to NC
    Also 10k on plugs? Which ones? I'd throw in a fresh set as well along with CTS.
    2002 A4 1.8T - sold
    2007 DTM S4 -JHM 93 Tune - JHM Spacers- :: EuropaParts.com :: B7 S4 Performance - Exhaust - CF S6 Shift knob (made) - CF center caps (made) - LED DRL's - Trunk Monkey
    Sound clip - https://www.youtube.com/watch?v=bGz60n-31jc
    Jul 23 2012
    Michigan
    well as it turns out, it is the pcv system, even though it wasnt like other people described, the crank case vacume was too strong, just by a little bit and it casued my problems. My question is when i pinch off a vacume line from the intake, that leads down to a t fitting thats also connected to the 90 degree plastic elbow from the oil fiter housing, what valve is bad? from my understanding there is a pcv valve and a prv valve, which one do i need to replace?
    Veteran Member Three Rings chad99's Avatar
    Apr 21 2012
    Fremont, CA
    thats the PCV area PRV is either on back of head or near tip...sometimes called pancake valve
    May 03 2010
    Maine to NC
    Scroll down to #5 post. Part #6.
    http://forums.audiworld.com/showthread.php?t=2380970
    2002 A4 1.8T - sold
