Results 1 to 18 of 18
    New Member One Ring
    Jul 22 2012
    Jax Florida
    Is this an original Timing Belt?
    Bought a 2003 A4 1.8T Quattro 5 speed with 107,000 miles on it. The CarFax was clean and looked like the previous 2 owners kept up with regular scheduled maintenance. However I'm still not sure if the timing belt has been replaced or not. I'm not sure if timing belts replaced by the dealer use VW/Audi parts? I can tell by the cracks on the "green" part of the belt that it will need to be replaced sooner rather than later. But any help with this issue would be greatly appreciated. Thanks in advance.
    -J
    Senior Member Four Rings Greedo's Avatar
    Oct 26 2009
    It has cracks - replace it.
    *** WANTED: B6/B7 FLAT door blades (moldings). Preferably in light metallic silver. And not warped. ***
    **Stuff that you must have - http://www.audizine.com/classifieds/...9779&protype=1**
    Senior Member Three Rings Charlie240sxt's Avatar
    Mar 28 2010
    95 240SX SE Ka-T,02 Chevy 2500 HD
    tulsa,ok
    X2 replace asap.
    04 A4 1.8 Quattro, 02 Chevy 2500 HD, 95 240sx Ka-t
    ........Daily..............Tow/Haul...........Shop Ornament..
    Active Member Three Rings
    Dec 15 2011
    2004 1.8T A4Q
    Edmonton Alberta
    tick... tick... time bomb!
    -Richard-
    2004 1.8T A4Q Tip. 1961 VW Beetle Canadian Std. 2008 Chevrolet Silverado.
    Darsh Import/Dubsport Inc... My very own Vw/Audi parts and service shop
    Senior Member Four Rings walky_talky20's Avatar
    Jun 30 2008
    Erie, Pennsylvania
    The cracks and genuine markings pretty much guarantee it's original. But the cracks themselves are the least of your worries. It is often the teeth that fall off. Those cracks are on toothed side of the belt and you can't see them. I wouldn't even start that car again. At 107k and 9 years on that belt, you are on some seriously borrowed time. I've seen these belts fail at 10 years/75k miles or less.
    2001 Laser Red A4 1.8TQM, 5-Speed Swapped, APR 93, Splitter, electronic oil pressure gauge, B6 Sport 17's, ST Coilovers,
    Need to borrow a Cam Chain Tensioner Tool? $4 for shipping. PM me. *Unavailabe*
    Active Member Two Rings f1torrents's Avatar
    Apr 27 2012
    guelph
    Get that replaced with a full kit ASAP.
    belt,tenshioner,water pump.
    Seriously do it tomorrow.
    2004 B6 1.8t Quattro 6sp - k0mpresd tune- ECS boost gauge - 008 DV - B7 Key & Console
    Spoiler - RS4 exhaust tips - S-Line style pedals - Cupra R lip - GTI FSI Coils -
    I make complete VW/Audi keys. MK4-MK5-B5-B6-B7-TT-A3-A6-A8-Beetle ETC... PM me for details
    Senior Member Three Rings Unum's Avatar
    Dec 14 2010
    Metro Bus
    Holy hell.
    -Chris
    No car. Putting money in the bank for home #2.
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    02A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    2nd dont even think of commuting in that car other than to get it fixed. I would have it towed if I didnt know how to fix myself... Just Sayin.
    If that was a FL car??? This might have saved it from breaking earlier with no extremes of temp and not to forget - humidity???
    'SOFTWALKER MODS
    Do u have the Bentley or Dealership Manual & Tools it takes to work on YOUR car properly? Or...
    Are u just going to continue to wing it & keep expecting manna to fall from AZ?
    Apikol>Snub/Diff APR>ExhTIP-TB hoses,Stg3 AWE>DV
    JHM>ShortShift-the works
    Misc> 18x8x9 235/265;HSport S4 barsTT225;Bosch-F6DTC;CarbonioV2+V6Intake Inlet;HFC;Podi-P2;ATP mani;GPopK04;034mounts
    SPEC>Stg3+,LWFW
    STaSIS>328/305mm,40/60,SL
    Personal Motto>Walk Softly Carry a Big Stick
    Aug 26 2005
    Quote Originally Posted by USN View Post
    -J
    Have any Audi dealer check the service history via the VIN, if the TB has been replaced at a dealership, then there should be a record of the service and the mileage. Regardless, that belt on the car now is done, as already stated prior by others. Without a replacement record you can safely assume the belt installed now is the OE belt.
    Vorsprung durch Technik
    Mar 27 2008
    Some tools.
    Denver
    Lord.
    -Jace-
    RogueEuro
    WTB: B7 Split Spoke Center Caps
    Atlas FTW
    Senior Member Four Rings imnuts's Avatar
    Aug 12 2009
    Dolphin Grey Audi A4 3.0 Q 6MT
    PA
    Does it matter if it's the original belt or not? For any belt, I would say cracks equals replace immediately, regardless of how old it is.
    Retrieve your SKC for use with VCDS
    3.0 JHM Tuned, Zingo Airbox Mod, 6-spd, quattro, Vogtland Jr. Suspension, Single Xenon E-Codes, Apikol Snub, 034 Motor and Trans Mounts
    Jun 30 2008
    Erie, Pennsylvania
    Something interesting to me, which I didn't mention before, is how intact the printing is on the belt. By 107k, you would usually expect the printing to be very faded, if not gone altogether. I don't know if that is indicative of anything specific, but just interesting.
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    I just replaced a timing belt that had 30k on it because my water pump started leaking. I'll pull it out of the trash when I get home tonight and take a look (it's pouring in Orlando, so the belt will be soaked). Pretty sure it had those "cracks," too. By no means am I suggesting that you not replace it immediately - especially if you have that many miles and there's a chance that it's original - but could those cracks just be crackling of a printing coating or something?
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Dec 28 2006
    '09 CC VR6 Sport
    Here's one with 50k on it:
    [IMG][/IMG]
    I would say replace it for sure.
    Still have all my hoses and check valves and proud of it!
    Active Member Four Rings Charles.waite's Avatar
    Jun 27 2011
    2004 A4 1.8TQ 6MT USP • 2006 A4 Avant 2.0T tip
    here's one with 50k on it:
    [img][/img]
    i would say replace it for sure.
    nein! Achtung! Nicht nicken!!
    -CP
    2004 A4 1.8TQ 6MT USP - APR Stage 1 - FSI Coils - BKR7EIX-11 - 034 Silicon Breather - 034 Rear Swaybar (Soft Setting) and Solid Spherical Endlinks - B6S4 Front + B7A4 Rear Brake Setup - Failing Clutch Mod
    2008 Black Unicorn (2.0t S-Line Ti 6MT Avant) - BRK6EIX-11
    SOLD -- 2006 A4 2.0TQ Avant Tiptronic stocker - Failing TC Mod
    Dec 28 2006
    '09 CC VR6 Sport
    It's my belt and I'll damn well bend it if I want to!!
    May 13 2008
    NoCal - EBay
    Nicht knicken = Do not crimp
    So ur in the clear to bend away on that old belt; old guy...
    'SOFTWALKER MODS
    SPEC>Stg3+,LWFW
    May 03 2008
    Orlando
    Here's 30,000 miles (no cracking):
    Kevin W.
