Results 1 to 3 of 3
    New Member One Ring
    Jul 19 2012
    SoC
    Weird misfire!! Help
    So I have a 2001 A4 2.8 that overheated on me back in December. I did have a misfire on it back then that kept jumping around different cylinders in both banks.
    I found a used engine and replaced it the one I had with a 1998 2.8 engine (drive by cable) so I had to change quite a bit of parts over from the old one. Now I started up the car last week and it gave me a misfire and was running really rough since two of the coil wires were exchanged. After moving them over to the correct order everything was ok. I left it running for about 2 hours or more. I accelerated it and everything was ok no misfires or engine light. I took it for a drive and after 40 mph the light came on. Scanned it and it gave me an error of cylinders 4, 5, and 6. I was told that maybe resetting the throttle body might do the problem. So I did that and now it’s running even worse.
    I have been playing around with it and it seems that it is only when it is running. When sitting in Park I can rev the engine past the 5500 RPM but when it gets to the 6000RPM it would start flashing.
    When running the light starts flashing after 35 MPH when if I'm near the 3000RPM and continues to flash up until around 65 if I stay at a constant 70 MPH it will stop. If I continue to accelerate past the 70 MPH area it would start flashing again.
    Now if I slowly accelerate to 65+, keeping RPM's under 2000 it won’t flash and will be ok.
    The coil pack is new.
    The spark plugs are new
    Speed sensor is the one that I had bought before.
    Vacuum lines have been replaced.
    Breather valve is new.
    After testing it i disconnected the knock sensor and ran it like that for a while and i ran better. After 15 miles it started misfiring when i was running about 80-85 mph
    Hope what I’m saying is understandable. Let me know if not.
    Active Member Four Rings bman005's Avatar
    Sep 06 2011
    06 GTI
    Harrisburg, Pa
    Compression and leakdown tests would be a good start
    Gonna push this little K03 until it can take no more
    Oct 21 2009
    full time
    easton
    Change your primary o2 sensor. Just had similar issue. Comp test was good, swapped coil pack CCT. Cps plugs wires.
    Car did same thing fine sitting at idle in driveway out under load it would pop and misfire like crazy.
    Was loosing my mind ready to do what you did and swap motor.
    Swapped o2 out of parts car and life was good....
