Three Rings
Will these wheels fit?
Looking at a couple different sets of wheels for my B7. Will either of these fit?
1. Audi y-spoke
18x8 et 40
with 235/40ZR18 95w tires
Anyone seen these on a B7? What do these come stock on?
2. Flik Wasp
18.7.5 et 35
These are just images I found on Google images, not actual wheels I am looking to buy.
OldYella: "Like many animals sense fear, this car can sense a fat wallet and goes in for the kill."
Active Member
Two Rings
Yes they should fit but not a fan IMO
Three Rings
Do you know what the first ones come stock on?
Got any better solutions of a wheel/all season tire package for around $800?
Thanks,
Senior Member
Four Rings
Four Rings
I know the Flik's will fit and should be super cheap.....
Cheers,
Jim
Senior Member
Four Rings
I believe B7s came with 18x8 ET43 stock.
Sprint Blue B7 S4 Avant 6MT - 421whp/350wtq
JHM Stage 1 Supercharger - Stern Motor mounts - JHM IM - JHM Stage 4 clutch - JHM LWFW - Stoptech ST-60 BBK - KW v3 Coilovers - Apikol Rear Diff Mount - JHM "Trio" shifter - Trexturk DP - Magnaflow CB - Hotchkis 29mm RSB - JHM Intake Spacers - TT-RS MFSW - 034 Adj. FUCA - RS4 Pedals - Zada Tech Gauges - STE Gauges - Dynavin D99 Android
Three Rings
I just found some RS4 reps that are 18x8.5 with an offset of et +38. They have 245/40/18 tires.
Does that work on a B7? Is there a guide anywhere of what fits on our cars?
Senior Member
Four Rings
Three Rings
 Originally Posted by Axel-
That'll fit just fine.
Thanks Axel! You must be the resident wheel expert
I have a broad scope right now, so I might ask a few more questions on wheel sizes.
Senior Member
Four Rings
Do you need new wheels? Because neither of those sets look better than the OEM S4 wheels.
Three Rings
No I was planning on selling my stock wheels. I do need new tires though, pretty bad, mine are cupping and making a pretty loud humming noise above 60mph.
I am just not a big fan of the Avus wheels on the B7 body style. If I had the BBS CH stock wheels I def wouldn't want to get rid of those!
Senior Member
Four Rings
#1 is almost a perfect fit versus stock wheels.
#2 is a bit narrow.
2011 S4 saloon S tronic
+ Stasis go-fast goodies
Senior Member
Three Rings
Agreed
Sent from my MB855 using Tapatalk 2
Three Rings
Alright another inquiry...
18x9.5 ET40 wheels with
215/40/18 tires.
If these would fit, would there be any adverse affects to my speedometer or handling? Since they are 1.5" wider and all...
Active Member
Three Rings
215 is pretty damn narrow, especially for a 9.5 wheel. For a 9.5 (unless you want a retarded amount of stretch) I'd stick with 255+.
I run a 235 on the stock 8" wheel for reference, I could prob go up to 245 or down to 225 and be OK.
Go to tirerack.com and look up the height conversion charts to see how the overall diameter changes when varying width/aspect, should give you an idea of the % change on the speedo.
2005 Nogaro B6 S4 | CF Trim | JHM Tune | Piggies | Magnaflow RS4 Catback | Apikol Snub, Rear Diff. Mount | 034 UCAs, Trans. Mount | K&N Drop-in/Airbox mod | Yellow Fogs
If it wasn't for bad luck, I'd have no luck at all...
Senior Member
Three Rings
Sometime, stock look best.
Three Rings
Sorry to ask another one...
I found a deal on NEW wheels and tires for a great price including shipping. I am a fan of the style as well, they are ASA GT1's, kinda like RS4 wheels I guess. Not sure on the fitment though.
18x8 et 35
225/40/18 tires
Is that pushing it with the offset?
Thanks guys!
Senior Member
Four Rings
Not pushing it at all. I have 19x8 et35 and I'm lowered AND running 245 wide tires. For 225 wide on 18", you'll be just fine.
(And for winter, I'm running 18x8 et43 with 8mm spacers (equivalent of et35) on 235 wide tires).
Three Rings
(And for winter, I'm running 18x8 et43 with 8mm spacers (equivalent of et35) on 235 wide tires.
Awesome! I think that I am going to work out a deal on these wheels. For NEW wheels and tires it is a killer deal.
As far as I understand, the lower the offset number the more the wheel will "poke" out toward the fender right? That is good then because I always thought the stock Avus wheels looked a little too sunken in, and they are 43 offset.
Thanks Axel!
Senior Member
Four Rings
That is correct.
Thanks Axel!
No problem.
Three Rings
One last question:
Do I need to worry about hubcentric rings or anything?
Senior Member
Four Rings
One last question:
Hmmm...according to Tirerack, that wheel isn't available for the B7. Are you sure they're the right bolt pattern and centerbore size?
Assuming they are, you need to check if they're already hubcentric or lugcentric. If they have the right centerbore size for the B7 AND they're already hubcentric, then you don't need a ring. If they're the right centerbore size but are lugcentric, you should get a hubcentric ring. However, you really should check what the bolt pattern and centerbore is before purchasing.
The B7's bolt pattern is 5x112 and the bore is 57.1
Three Rings
Well they are discontinued wheels, so finding specs on them isn't readily available. But I did find this spec sheet:
http://www.zinikwheels.com/specs.cfm?id=1283
It says that the bolt pattern in 5x112, offset is 35 and the bore is 72.20.
As far as Hub and Lug centric, not sure about that. Whats the best way to tell?
Senior Member
Four Rings
All of the newer Audis are still 5x112 but are now the 66 CB. You can just use an adapter on older cars.
Senior Member
Four Rings
Seeing as the wheel's centerbore is larger than the hub's centerbore, you'll need a hubcentric ring. Also, don't forget you'll need longer bolts to take into account the 8mm difference in offset from stock wheels and for those you'll need to find out whether the wheel uses ball seat or cone seat bolts.
Aren't wheels just a PITA :)
Three Rings
Seeing as the wheel's centerbore is larger than the hub's centerbore, you'll need a hubcentric ring. Also, don't forget you'll need longer bolts to take into account the 8mm difference in offset from stock wheels.
Shoot...
OK, where can I get the proper hubcentric ring that I need?
What are the length of the stock bolts? I know the place selling the wheels includes bolts, I can ask if they offer longer ones.
I didn't know that the offset affected the bolt... New thought to me!
Senior Member
Four Rings
IIRC correctly stock bolts are 27 or 28mm so you would need to add 8mm meaning a bolt length of 35 or 36mm (there's a small tolerance allowed. For example, my wheel locks are 34.5mm).
If you're buying them from a shop (rather than an individual), they should provide you with the proper bolts for that wheel (I think it's 14x1.5). Just make sure they take into account the need for something a little longer than stock (they'll also know if it's a ball seat or cone seat bolt that you need).
They should also be able to sell you a hubcentric adapter for your car.
If you're buying from an individual, you'll need to check with him whether it's ball or cone seat and then go to a shop and give them all the info.
Three Rings
I am having a hard time understanding the need for longer bolts. Don't you only need those if you have spacers? Otherwise the wheel should butt up to the hub the same as the stock wheel shouldn't it?
Senior Member
Four Rings
Yes, sorry. I was thinking of my spacers. Without spacers, you won't need longer bolts. Apologies.
- You may not post replies
- You may not edit your posts
Forum Rules
