Results 1 to 6 of 6
    Oct 23 2011
    Washington DC
    Tips to keep a 1.8t in the higher miles?
    Basically, I bought a 2004 1.8t quattro manual in November and I've already put 15k on it. Now it's at 125k. The car was in great shape when I bought it and it is still doing well. Although, I've done a bit of work since I got it to prevent future problems (Rear brakes, axle, flex pipe, radiator temp sensors, crank sensor, all front control arms, and tie rods). I have no problem doing this work, and I do it myself, but I want to make sure it will last. Is there anything outside of fixing a problem when it occurs, such as preventative maintenance? What are the more notorious issues that I can run into at higher miles on this car?
    I'm just worried that it won't last me for a few years more and I want to be sure it will by doing the right thing early.
    Dec 28 2006
    '09 CC VR6 Sport
    Good approach! There are a few items that will probably fail in the next year or so (if the haven't already been replaced). All are relatively straight forward DIY's. In no particular order:
    • Timing belt, tensoiner, water pump, accessory belt.
    • J plug (Go ahead and replace the t-stat while you are down there.)
    • Rear coolant flange.
    • Valve cover gasket.
    • SJP
    Take a look at this thread for a lot of really good info: Clicky click
    Still have all my hoses and check valves and proud of it!
    Active Member Two Rings ZachB5's Avatar
    May 26 2012
    Longboard!
    Sacramento, CA
    Do your best to change oil at 5000 mile intervals and use VW/Audi Approved Synthetics (Typically 5w-40 and some 0w-40 for the 1.8T)
    As far as preventive maintenance goes, OCI is big because the 1.8T is prone to sludge due to small sump and turbo.
    Timing belt is a big deal too. When was yours done? I think most people recommend a TB job every 60k miles. The belt tensioner will give out due to wear and fail or a belt will snap. Usually this results in a damaged head, so don't slack on this one!
    Those are the big two. When engine mounts get worn out they can put stress on other things connected to engine and when engine moves to much those things (Exhaust flex pipe for example) can be damaged.
    Thats all I can think of. You got the control arms done, that's a good start! I need to do mine. All my front control arms are original @162k, still drives well though
    Oooh almost forgot. Clean out all your PCV pipes and valves if they haven't been cleaned. They get filled with nasty oil gunk and clog up. Look for DIY's as there are plenty on here.
    2001.5 VW() Passat 1.8T
    Senior Member Three Rings Satummoo's Avatar
    May 04 2009
    Boulder, CO
    Great thread, subing for later, my car has 128k on it
    2003 A4 5speed, no sunroof, cloth seats
    GT71R, Genesis II 500 injectors, Moteza Tune
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    Audi A4 1.8TQ usp
    Paradise Valley
    Always have $500 on hand. After 100k I had to replace my fuel hose, crank sensor , power steering hose and both hoses were $ a couple hundred bucks each. At that mileage there are several parts that are at the end of its life span.
    Diztek USP CLUB MEMBER #90
    Apikol Snub Mount-GIAC FX04-Siemens 380cc-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Dension Icelink-Podi Boost Gauge-Stasis SS Coilovers-ECS slotted rotors.
    Senior Member Four Rings waldo1324's Avatar
    Apr 06 2009
    the Ghost of the Princess, 2007 Ford Fusion, 2006 Honda Accord
    The StL
    try not to look at it cross eyed. and remember to bow and bless the 4 rings.
    fuel filter
    check valves (US Plastics)
    ""GHETTO MODIFIERS"" member #1
    The Princess: SOLD.. i love you, please forgive me
    "I agree with Waldo 100%" -1997GTX
    ..psst if you have a USP 05 or a 2003+ 225 TT, email me..wally.iverson(at)gmail.com
    aaand somebody buy my g'dam Ferodo Rear Pads FFS
