5 Bar FPR vs Crushed 4 Bar (GIAC J31)
I have a 2000 A4 1.8tqm with a K04 and GIAC J31.
I do not have the recommended 5 Bar FPR. I was curious if I could try to have a shop "crush" mine, or buy a "crushed" one instead of an actual 5 bar one, in the interest of money... As the actual 5 bar ones are quite pricy.
Can anyone confirm/deny if this would work with my setup?
Forum Moderator
Four Rings
Do any other Audi/VW's have the 5 bar from factory?
BetaAlphaTau Member #12 01' A4 1.8TQMS 5spd swapped GT2871R|CTAPP MAFless|034 EM|Godspeed FMIC|APR 2.5"|EVO MS DV|CM FX400-LWFW
My 5-Speed Swap DIY
- B6 USP
Four Rings
We crush the Fuel Pressure Regulators all the time on our Toyota race cars (read: Corolla's) to richen them up. It is very easy to do. You just slap a pressure gauge on the rail, pop off the vac line, and crush to spec. For the Bosch ones I think you need a sort of dimpled or cone shaped object to do it, but it should be pretty simple.
2001 Laser Red A4 1.8TQM, 5-Speed Swapped, APR 93, Splitter, electronic oil pressure gauge, B6 Sport 17's, ST Coilovers,
Need to borrow a Cam Chain Tensioner Tool? $4 for shipping. PM me. *On Loan to 01audia4*
Senior Member
Three Rings
Do you have a pic?
Four Rings
A pic of what? The crushed Corolla FPR? Or a pic "mid-crush"? I haven't done a Bosch one.
Senior Member
Three Rings
Of the crushed Corolla FPR, I'm curious. Thanks
Four Rings
Will snap a pic this evening.
Four Rings
Dang it. Forgot to take that pic. Will do today.
My car does have what appears to be a crushed 4 bar on it. With a 5 engraved over the 4. So it was probably bought crushed
Do you have any specs to check if its equal to a 5good bar?
And I can get a pic of it if your curious un1ko
Senior Member
Three Rings
Cool! Thanks
That would be great! I never heard of this, but I've had the one 034 sells (see pic) I didn't like it.
Is this what you guys are talking about? That's crazy I haven't seen this before.
http://www.034motorsport.com/fuel-in...bar-p-535.html
This can open more options for me, I got the Maestro 7 and my plan is to use 1000cc injectors for my build, if I ever finish it. lol! If I can tune it with a 5 bar it pushes the injectors to - 1280-1300 cc/min (5 bar)
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
