Results 1 to 39 of 39
    Jul 08 2012
    United States
    2013 A4 non-nav, 2g/3g/MMI ....confused! (want a2dp)
    I am a proud new owner of a 2013 A4. Like a ton of other posters I am annoyed I don't have a2dp bluetooth music capabilities.
    I have found this http://www.audi-collection.com/Vehic...treaming-Audio, but cannot determine if it would work with my vehicle! Looks like there's a pain in the ass workaround to make it work on 3g MMI systems, but I just want to know which I have to do :)
    I have do NOT have navigation in my car 2013 A4, can I assume I have 2g MMI?
    I do have AMI in my glovebox with the ipod connector.
    Thanks,
    Active Member Four Rings Liquid Smoke's Avatar
    Dec 01 2011
    not sure about the rest but i think you have the 3G MMI, even on the non navs i believe from like MY2011 and on it was 3G, but i dont see why the 2013s wouldn't come with 3G
    2009 A4 Premium Plus+ / Phantom Black //
    Ridin' on 17's!! / Neuspeed 1.25" sport springs / 15mm rear spacers
    Active Member Three Rings dbX79's Avatar
    May 24 2012
    Atlanta,GA
    Yea you have to watch Audi they ala carte all the options. I have a 2012 i just got s month ago and I almost left with a car with the style package instead. The salesman apologized and redid my paperwork giving me the convenience package. If you want something be sure to let them know. Otherwise if I was you I'd take it back.
    Jul 08 2012
    United States
    Quote Originally Posted by Liquid Smoke View Post
    That's what it looks like from what I've found as well, but it's not the answer I want :P And I wanted a way to be sure before I buy one
    Quote Originally Posted by dbX79 View Post
    Thanks, but that's not really what I was asking. I knew I wasn't getting a2dp in my car...it was another 3k because you need the nav system
    I've found 2 solutions to getting bluetooth music in my car, one for MMI 2g and one for MM 3g. I'm just trying to determine which one my car has
    Senior Member Four Rings A4 Centaur's Avatar
    Jun 05 2009
    2008 Ducati 848, 1199 Panigale on the way
    Colorado Springs Colorado
    Black B8 A4 Avant S-Line Prestige Package, Tiptronic 8 speed, V1, Beltronics, Eurocode HFC, Vogtland Coilovers, H&R Swaybar, APR Stage 2, 91 & 93 ECU Upgrade, VMR RS4 Reps, and more mods to come!
    Senior Member Four Rings NPuter's Avatar
    Oct 27 2009
    2007 MBZ CLK 350 Cab
    Miami, FL / Boone, NC
    Completely incorrect.
    If you do not have nav, you do not have MMI at all. The non nav system is just a glorified radio with a large screen.
    2009 cars with nav had 2G MMI. 2010-2012 cars with nav had 3G MMI. 2013 cars with nav have the new MMI system. No nav means no MMI from 2009-2013.
    That dongle only works with 2G MMI, so it will not work with your car.
    Nick (NPuter) ~ Brilliant Black 2010 B8 A4 2.0T | Build Thread | S-Line Front Bumper Conversion | Drive Select VAG-Com Codes |
    flickr: NPuter | Instagram: nputer
    Dec 01 2011
    ah i see, sorry i was mistaken i just thought that system, nav or not, was the MMI
    Jul 08 2012
    United States
    Well that sucks. Do the custom jobbie ones still work though? Since my car has AMI
    http://www.a5oc.com/forums/a5-s5-top...o-via-mmi.html
    Oct 27 2009
    Quote Originally Posted by Nitrox View Post
    I do not believe so. IIRC, that solution only works with 3G MMI - however, it has been a while since I read that thread.
    Jul 08 2012
    United States
    All kinds of bad news here! Anyone know of a way to get bluetooth music then through my glorified radio?
    Oct 27 2009
    Theoretically yes, but it will involve a complicated setup.
    A combination like this may work:
    3.5mm audi connector for you MMI - be careful, there are separate cables for MMI (nav) and non mmi (no nav) systems
    Bluetooth audio receiver (powered by USB) such as this one http://www.amazon.com/Miccus-BluBrid...pr_product_top
    Mini USB car charger
    Jul 08 2012
    United States
    Problem SOLVED!
    Went down to the dealership to buy the audi dongle mentioned in the first post, figured it'd just take a few minutes to see if it worked before I delved into other options
    Well...lo and behold, it works perfectly!! Took about 5 seconds to setup, and now I'm a bluetooth streaming monster
    Mar 11 2012
    Salt Lake City, Utah
    Problem SOLVED!
    great news. gonna go get this for ours
    Registered Member Two Rings Arvind's Avatar
    Jun 06 2012
    Chandler AZ
    Wow! Thanks for the update. I just got a 2013 A4 too and was scratching my head about bluetooth audio. I am glad this solution works.
    So please tell me if this assumption is correct.
    Even though the Audi collection website says it works only with MMI 2g you are saying that it works with you 2013 A4 (non-NAV) which is supposed to be non-MMI?
    Sep 30 2012
    Miami
    OP, thank you very much for doing this! I ordered mine after seeing this post. I also have a 2013 A4 Premium plus, it has the Bluetooth phone but no audio. I ordered the part & installed it a few minutes ago. It works like a charm, even though the website does not say it supports our vehicle.
    thanks again!
    Active Member Three Rings B G 8er's Avatar
    Sep 28 2011
    2011 A4 Quattro Premium 6MT, 2013 Q5 2.0 Prem.
    Valencia, CA
    Does anyone know if this dongle will allow Bluetooth audio streaming on my my2011 w/o Navigation?
    satin black grille & plate filler, led - xeon headlight mod, A4L fog grilles, side blades, rear lip, Stratmosphere Hyper Shift short throw shifter, Alu Kreuz, H&R OE Sport springs, Neuspeed RSE14's 19x9 ET40, Llumar 40 percent tint, RS4 pedals, black self dim mirror w/compass, saftey triangle w/bracket, luggage net, VAG COM.
    Jul 08 2012
    United States
    Quote Originally Posted by Arvind View Post
    Exact-a-mundo!
    For anyone curious if this will work for their car...just go to a dealership and buy one! If it doesn't work you can return it straight away, no risk in trying :)
    It's not as...smooth, as you would expect from Audi. Sometimes I lose connection and have to reconnect bluetooth, or unplug and plug back in the adapter. But all in all I'm very happy with it
    Jun 06 2012
    Chandler AZ
    Well that is good to hear. Thanks for the confirmation both nitrox and goose!
    But returning the device if it does not work might not be so easy. I live in Arizona and no dealership in Arizona has this part in inventory and say they cannot order it because it is now an obsolete part. So I called the nearest guys who have it (San Diego!) and they told me I could buy it from them but they WILL NOT accept it back if it does not work. It seems this no return policy applies to all electronics.
    But atleast now I can be sure that it will work with my car...
    New Member One Ring
    Oct 06 2012
    Avondale, Az
    I ran into same issue. Dealers in town said they dont even offer the part. I ended up ordering from www.audipartssuperstore.com for $190 shipped. Still waiting for it to arrive. Hopefully it works.
    New Member One Ring
    Oct 06 2012
    Avondale, Az
    Just installed mine. Part number (4F0051510J). Works flawlessly on my 2012 a4 non-nav, the sound is fantastic.
    Active Member Two Rings Maltitol's Avatar
    Jun 27 2012
    Rockville, MD
    Quote Originally Posted by Buffaluphagus View Post
    I'm having the same trouble getting this part. The dealers say this part is discontinued. I'll try the website you linked. Can you change tracks with it or do you have to do it on your device?
    Senior Member Two Rings B8Phil's Avatar
    Mar 13 2010
    Arlington, VA
    Quote Originally Posted by B G 8er View Post
    I have the kit... As long as you have the Audi Music Interface (AMI) and a 2G MMI, it'll work. Check my sig if you're interested, I'm selling mine... I'm looking at doing a full 3G+ retrofit.
    ***Update, kit has been sold***
    BASE: 2009 A4 2.0T Quattro Prem+ w/Nav
    MODS: APR Stage II, S4 shocks & rear sway, Eibach Pro-Kit, BFI 15/20 spacers, Eurocode HFIP, Eurocode inlet hose, aFe Pro Dry S, SPM street edition downpipe, Stoptech rotors, Posiquiet pads
    **FOR SALE**:
    2009 Quattro A4 with Nav/loaded $21,500
    http://silverstar-media.com
    New Member One Ring
    Aug 09 2010
    Australia
    And just to clarify....
    As has been said in this thread, generally if you don't have NAV you don't have MMI.
    The actual difference is that your car has MMI if the audio controls are mounted flat on the console, aft of the transmission shifter.
    On the other hand, if your audio controls are in the upright section above the climate controls and below the centre air vents, you have a "non-MMI" car.
    The "correct" Audi name for this is the "infotainment system", and will be labelled just above the cd slot as either Audi concert (radio with single CD) or Audi symphony (radio with 6 CD stacker).
    Now I am not as familiar as I should be with the 2013 cars - clearly if you have ordered the nav you have a "new generation MMI". This is clearly a significant upgrade on the previous 3G MMI. On the other hand if you don't have this and have the concert or symphony, can anyone confirm that this is exactly the same as the 2012 and earlier cars, or is this somehow new and different too for 2013?
    cheers,
    ..Neil
    Active Member Two Rings Cody Maverick's Avatar
    Sep 28 2011
    2012 A4, 2004 R32
    PA/MD/DE
    wait.. im so confused.. so is there or isnt there a way to get bluetooth on my 2012 with nav?
    2012 A4 S-Line, Phantom Black, B+O Sound, Advanced Key, Rotiforms 19x8.5 front, 19x10 rear, H&R Sport Springs, 38% Carbon Tint
    2004 R32, Koni Coils, Roll Bar, Helix HIDs, AEM Intake, EIP Shortshifter, Navi, Zenders and More
    Sep 30 2012
    Miami
    Quote Originally Posted by moonan View Post
    cheers,
    ..Neil
    I have 2013 without nav & like you said Audi Concert or Symphony, can't remember at this moment, and the bluetooth A2DP adapter sold at the dealer worked flawlessly in my car.
    hope that clears it up.
    Also my dealership did not carry or want to special order the part, so I searched & found Tom Williams Audi had them in stock.
    Jul 11 2012
    Philadelphia
    For those of you who have successfully installed the Audi Bluetooth dongle for the AMI only system, can you please describe the functionality? Does the system function similar to when my phone is plugged in? Do songs and playlists still load on the screen? Any details would be great before I go out and buy one of these things.
    Registered Member One Ring Transporter99's Avatar
    Sep 01 2009
    BMW Hartge/Dinan 328i - Sold :(
    Wow, this is looking bleak. All SD dealerships are permanently out of stock of the dongle.
    Brian ~
    ______________________
    2009 Audi A5 PP/ Nav/B&O/6MT - current
    1999 Dinan/Hartge 328i/Jet black - Sold
    1988 325iS Eurosport (greymarket) - Sold
    Jun 27 2012
    Rockville, MD
    I can't find the 4F0051510J part anywhere on the net. Does anyone know why this ( http://www.audia2dp.com/index.html ) doesn't work with 2g AMI?
    I have non-nav basic radio 2g on my 2013 S4 and I want something to wirelessly pass music into my glove-box where the AMI cable sits. At the same time though, I don't want to have to worry about charging anything so I want to use the AMI cable to give power too.
    Why the hell didn't Audi just put a 3.5mm jack in the center console?
    Senior Member Four Rings jlaudio's Avatar
    Mar 26 2009
    Canton, CT
    Quote Originally Posted by Maltitol View Post
    http://audi.dealerfit.com/store/audi...1151_31502.php
    http://www.jimellisaudiparts.com/pro...F0051510J.html
    you can always buy a 12v cigarette accessory at walgreens or cvs for 5.99 and use your iphone charging cable or your phone cable
    09 B8 A4 Prestige
    "We as a group now have a greater moral responsibility to act than those who live in ignorance, "Once you become knowledgeable you have an obligation to do something about it!" - Ron Paul
    Previous: 06 S4 6MT, 07 A4 6MT, 02 A4 QM, 99 A4 QM
    Jun 27 2012
    Rockville, MD
    Quote Originally Posted by jlaudio View Post
    I saw both of those retailers, but am weary of their credibility. I'll try Jimellis.
    Mar 26 2009
    Canton, CT
    jim ellis is an audi dealership in atlanta. i doubt you'll have any problems with them
    09 B8 A4 Prestige
    Jun 27 2012
    Rockville, MD
    Yeah emailed them last night and they also no longer sell it. I've checked ebay for them with no luck. I might have to settle for something else. :(
    Mar 26 2009
    Canton, CT
    genuineaudiparts.com had them on the accessory catalog a few weeks back... i meant to order one but forgot about it. now i need to find one too. maybe call them? i'm sure they can locate a few..i think they are two guys that work for the san diego audi stores parts department.
    i need it for my 09 prestige so i can stream music
    09 B8 A4 Prestige
    Sep 01 2009
    This is nuts, guys. So I pass by an Audi dealership in LA on Friday night to pick up some items and randomly ask (rhetorically, almost) if they had the 4F0051510J BT kit. "No" was the quick answer....but then "hang on..." turned into a quick phone. Revealed; one BT kit was ordered and abandoned by a customer in Canada (wtf?). Long story short, Audi Vancouver transferred it, I bought it and I just installed it. Major, major luck out. :)
    Brian ~
    Jan 24 2012
    IA
    I just returned mine from Carousel Audi Iowa City. Didn't like the fact that I couldnt' see the track info. Sound quality was great though. Paid $215 + tax for it. If someone is looking for one, I would call them up.
    Jun 27 2012
    Rockville, MD
    Quote Originally Posted by hanyoung View Post
    I just returned mine from Carousel Audi Iowa City. Didn't like the fact that I couldn't see the track info. Sound quality was great though. Paid $215 + tax for it. If someone is looking for one, I would call them up.
    Thanks hanyoung! I ordered the last part they had from Carousel Audi. It arrived and works as intended. Unfortunately for everyone else I think I got the last one in the continental US.
    New Member One Ring
    Dec 20 2012
    WA
    My SO has been the happy owner of a 2013 A3 since August but is disappointed by the lack of A2DP support in her car.
    I'm considering remedying this situation over XMas but I'm not 100% sure I'm getting the right part and even less sure about what the installation procedure would be...
    The local dealership is clueless. The place she got her car from (supposedly one of the last off of the assembly line) is not answering my emails...
    She doesn't have the Nav system, and Concert is mentioned on her CD player so this 4F0051510J accessory looks correct, right?
    How do you hook up the accessory to the stereo though?
    I don't see a connector in the glove box? Was that an option?
    There appears to be room for a CD changer in the trunk but can't see a connector...
    Will I have to pull the stereo out? How straightforward is that?
    Do I connect the part directly to the stereo, or do I need a harness of some kind?
    Thx in advance...
    New Member One Ring
    Dec 16 2012
    Atlanta
    Does anyone have an alternate solution to this or know of where I might find one, just got a 2013 A4 prem + (non-nav) for xmas and would like less wire clutter in the cabin
    Aug 06 2012
    Parker, CO
    Not to dig up an old thread... but I have a 2013 allroad (B8.5 A4 platform) and just read over the window sticker. It lists my system like this:
    "Audi MMI Concert Radio w/o Nav"
    There is a the MMI (radio without Nav) and MMI w/Navigation Plus.
    Becasue... even the basic system in the 2013's control radio, cd, AMI and phone. Multi-media stuff.
    Vehicles: 2013 Ibis White allroad & 2006 Campy White Touareg
